Wireless router i lost my power cord to wireless router befw115. i need to replace it. where can i go or get the specifics. thank you
  • 749 Answers
Model Number BEFW11S4
Standards IEEE 802.3 (10BaseT), IEEE 802.3u (100BaseTX),
IEEE 802.11b (Wireless)
Channels 11 (US and Canada)
Ports One 10/100 RJ-45 Port for broadband Modem
Four 10/100 RJ-45 Switched Ports
LED Indicators Power, Wireless-B, Ethernet, Internet
UPnP able/cert Yes
.Net Support No
Modulation CCK, QPSK, BPSK
OS Support Windows 98SE/Me/2000/XP
Network Protocols TCP/IP, NetBEUI, IPX/SPX
WEP key bits 64-bit and 128-bit
Environmental
Dimensions 186 mm x 154 mm x 48 mm
(W x D x H) (7.31" x 6.16" x 1.88")
Unit Weight 1 lb. (0.45 kg)
Power Input External, 12V AC, 1A <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Certifications FCC, CE, WiFi
Operating Temp. 32ºF to 104ºF (0ºC to 40ºC)
Storage Temp. -4ºF to 158ºF (-20ºC to 70ºC)
Operating Humidity 10% to 85%, Non-Condensing
Storage Humidity 5% to 90%, Non-Condensing
I could not find the polarity of the plug listed on any chart, but the majority of these are "tip positive".
Posted on Oct 05, 2008
  • Jeff Strader
    Jeff Strader Oct 06, 2008
    that means the adapter supplies 12 volt AC power at 1 amp...hope this helps
  • Jeff Strader
    you might take your old ac adapter and the new one to radio shack, have one of the guys there test them with a volt meter for proper voltage. make sure they now the specifications here so that they set there meter up correctly.
    Doing this can tell you if the problem is with the ac adapter or the router itself.
Lost power cord for N1 Vision router -where can I replace
GOT TO THIS LINK https://www.google.com.pr/search?q=router+power+cord&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-beta#hl=es-419&sugexp=frgbld&gs_nf=1&pq=router%20power%20cord&cp=29&gs_id=t3&xhr=t&q=router%20power%20cord%20REPLACEMENT&pf=p&client=firefox-beta&hs=NlV&rls=org.mozilla:en-US%3Aofficial&sclient=psy-ab&oq=router+power+cord+REPLACEMENT&aq=f&aqi=&aql=&gs_l=&pbx=1&bav=on.2,or.r_gc.r_pw.r_cp.r_qf.,cf.osb&fp=b0a8639c8d8799d9&biw=1920&bih=963
Apr 10, 2012 | Belkin N1 Vision Wireless Router
I have a Linksys E1000 wireless router. It has been working fine. The power cord it is on was unplugged briefly last night. Now when I plug it back in, all the blue lights are flashing and I can't get...
have you tryed turning off computer, router, and modem if you have one. then unplug all connections from router (phone line, ethernet net cable and power cord). Then wait 2 min then plug all back in, and turn on modem, router, then computer. We lost power yesterday for 3 hrs and I needed to actually turn in all off and unplug power cords then turn it all back on to rest and reboot them to get them working properly. Hope it helps.
Sep 25, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Lost my power cord is there a universal power cord I can buy or do I have to order a new one?
Check out BestBuy or RadioShack if they have one, but i doubt it, usually it always included on the equipment. If your leasing the equipment from your service provider might as well ask them to replace it.
Aug 30, 2011 | 2wire (2701HG-B) Wireless Router
Linksys wrt150n wireless router won't connect to internet. Power, Wireless and security lights are on, but not internet light. I've unplugged power cords, ethernet cords, pressed reset button on router,...
1)If internet light not on then login to router and check the summary!!!and try to diagnose the test which is there in router!! and check for ppp is it active or down? Might be authentication credential is not correct that could be the reason?
Sep 18, 2010 | Linksys Wireless-N WRT150N Router
LOST D-LINK CONNECTION
try resting the router and also making sure your lap top or wireless desktop isn't the problem.
To reset the unit - -unplug all but the power cord - straighten out a paper clip and find the tiny hole marked RESET - hard to see - then - with everything unplugged but the power cord and the unit turned on - push the paper clip end into the RESET for 10 SECONDS - then unplug the unit for 10 seconds and plug it in - turn it on and re attach all other cords as needed. Be sure your pc is plugged in to the first pug or LAN - this will make a difference if you have more than one wired pc on the network.
If that fails - please =- find the disk or go online and call D-LINK - they are the best - the BEST -service EVER - of all the units for Tech-- the BEST .
May 07, 2010 | D-Link DIR-625 (790069292637) Wireless...
My rabbit chewed through my power supply cord to my dlink router and I need to replace it. Where can I purchase just the power cord?
For the power cord replacement you can go get one of those from any electronic or computer store near you and just provide them the model of your router so they can provide you the correct power cord.....
Nov 25, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Just moved
You need to hook up the AC power supply to your router, hook up your cable modem to your router, there should be a specific port on your router, most likely yellow in color, you'll hook the modem to the router using the supplied ethernet cable, it looks like a big phone cord.
Apr 21, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I lost my CD
You can reset your Netgear router/wireless MR814 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless MR814 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Feel free to get instant online Netgear router support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Oct 17, 2007 | NetGear MR814 Wireless Router
What are the wireless specifications of the 802.11b Wireless Router (F5D6231-4)?
F5D6231-4 802.11b Wireless Cable/DSL Gateway Router Output Power +13dBm-20dBm (50mW) (max.) Range (ft/Meters) 11 Mbps 5.5 Mbps 2 Mbps 1 Mbps Outdoors 590 ft (180m) 980 ft (300m) 1475 ft (450m) 1800 ft (550m) Indoors 50 ft (15m) 125 ft (38m) 150 ft (46m) 300 ft (90m) Reciever Sensitivity -76 dBm -80 dBm -80 dBm -80 dBm
Feb 16, 2006 | Belkin Wireless Cable/DSL Gateway Router
Computers & Internet Logo
224 people viewed this question
David Payne
David Payne
