Question about Polaroid 7" Two-Screen Portable DVD Player
DVD player does not read that there is a disk SAY " NO DISK"
  • chat2kirsty2 Dec 06, 2008
    download a episode and convert it int dvd from an avi file, then i burn it onto a blank dvd and try and play it on my dvd player, when i do that i always get the message bad disc. I could really use som help, thanks
  • Richard Day
    Richard Day May 11, 2010
    ref: BAD DISK- If your player plays store bought DVDs, then your player and burner are not matching up. another words, your player might not be designed to read "your" recorded disk. This does happen in some units. If a solution is possible, it would be to replace you laser drive assembly.
    ref: BAD SPINNER- I can check and repair the laser if you send it to me. You can contact me through Ebay Seller search as "richards_resale". I repair and resale portable dvd players.
Although this is not an answer to the problem, it may help us find one. I have some of the same problems with my player just spinning trying to look for the DVD or it will say bad disc. Sometimes it will start playing and just skip a lot. I think the problem is with the drive motor that spins the DVD. I have opened my player and "jimmy'ed" the door actuator and then spun the disc with my finger. It starts to play fine. I am on the path of looking for a replacement motor or someone to repair it.
Posted on Oct 30, 2008
Dvd player says no disk
does it read other disks?
try a few difference DvD's.
if other disks work, the disk you want to read is broken.
if other disks do not work, your dvd player is broken and you should get a new one or contact JVC if it is still under warranty.
May 02, 2011 | JVC XV-N320 DVD Player
Incert dvd read out sats NO
This usually happens when the DVD or laser lens pick-up has become dirty.All you need to do is
1. Check the disk for scratches.
2. Make sure the disk you are using fit the correct format specified by your DVD player.
3. Clean the laser lens with a DVD laser cleaning disk.
4. Insert a correctly formatted undamaged disk into your player,listen to see if it begins to read the disk,if it continues to make no sound.
5. Open the DVD player carefully and clean the lens with isopropyl alcohol and cotton swab.
6. If none of these solutions works out then a professional repair technician will be able to tell you if fixing your DVD player is worth the money.
Jul 13, 2010 | Toshiba SD-K760 DVD Player
Program says dvd+r incompatible with toshiba dvd player
Some DVD players will read 'DVD-R' ("minus-R") disks.
Some DVD players will read 'DVD+R' ("minus+R") disks.
Some DVD players will read "both" types of disks.
So, if you're burning onto a DVD+R disk, you won't be able to "play" the disk on your Toshiba DVD-player.
Instead, buy "blank" DVD-R disks, and write on them.
Apr 05, 2010 | Computers & Internet
Suddenly my DVD player is saying "no disc" after trying to load DVD. Why isn't it sensing the DVD has been loaded?
When a DVD goes into DVD player it has to spin it and read it. If your DVD player is not reading the disk. The disk could be dirty. The DVD player might need to be cleaned. You could be trying to play a PAL disk on a NTSC player or Visa Versa. or the region coding might be wrong. Try playing a clean disk that you have played in it before. That might tell you if you need to clean the DVD player.
Mar 03, 2010 | GoVideo DV2130 DVD Player/VCR
Why does it read bad disk? i've tried two disks, that work perfectly on another DVD player. But reads as Bad disk on the GPX D2816
its the disk laser sensor is to sensetive that why it canot reads with an ordinary disk or a pirated disk or a disk that has a small scratch.
Nov 07, 2009 | GPX D2816 DVD Player
The dvd player is not reading disk
is it a burned disk?.
some dvd players can read a disk You burned/made but only if the DVD player has AVI or DIVX logo on it.otherwise they Will Not play a burned movie/DVD..
Aug 12, 2009 | Samsung DVD-P230 DVD Player
Does not read disk
My portable dvd player turns on and the disk does not spins but the screen turn light blue and does not read the disk
Aug 03, 2008 | Liquid Video MVBG45 Portable DVD Player
Does not read the disk
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Jan 07, 2008 | JVC RX-DV3SL DVD Player
Polaroid 7" Two-Screen Portable DVD Player Logo
939 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
