Question about Mitsubishi VS-5043 50" Rear Projection Television
Tv does'nt Pwr up
When the pwr on button is pressed the green indicator lights up for about 5 seconds then shuts off...HELP ...need to know if it's worth fixing it ..(10yrs old) Thanks....
  • Mitsubishi Master
  • 19,396 Answers
The TV shuts down because it goes is in protect mode.
The TV does not turn on because there is an internal problem, like a short, a bad voltage, or more commonly a faulty component (IC , capacitor etc.).
The tv is in protect mode, try first unplugging power cord for one hour, and see if this solve the problem.
When this happen, the main Chip inside your TV detects that there is a fault, and send the TV in protect mode, activating a safety switch that prevents TV from turning on. The switch keeps turning off the tv, and that is the clicking noise that you can hear.
Unless you have experience as a TV repair, try first keeping TV unplugged for one hour or more. This will reset TV circuts draining power completely, and sometimes can wake up the TV from protect mode.
If it does not work, that means that there is a defective component inside the TV. In this case I suggest calling the phone number listed on the user manual to get support from manufacturer.
Posted on Oct 12, 2008
    Scholar:
  • 125 Answers
Hey Poncho I have heard of many problems regarding Mitsubishi Rear Projection Television and truth be told you should look into buying a new television. A ten year old television has run its and its not worth fixing. I would invest in a new HDTV.
Posted on Oct 05, 2008
  • Mitsubishi Master
  • 13,433 Answers
Will need to be taken apart to figure problem. check fuses and for any burned component. possibly if no high voltage.. not worth fixing.
  • Ekse Oct 05, 2008
    problem is possibly in the power circuitry... without inspection, possibly fixable by replaceing or repairing the powerboard if faulty. it debends.. i feel you need to have a professional look at the set
Hitachi 65SWX20B no picture/sound, 4 out of 5 green LEDs on, red LEDs on, green B+ LED is off. Pwr Relay clicks on, TV only turns on/off. IP02 location/How to check for 14-20V on terminal 4 of IP02?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 20, 2016 | Hitachi Televison & Video
Sony bravia shuts off
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 30, 2014 | Televison & Video
How make reset factory dell 3110
For the 3100cn, once the web password has been set, you need to do a deep NVRAM reset to clear it.
Before doing anything, print a Printer Settings page so you know what your printer settings are, espcially page count. I might advise dating and saving this for possible future reference
Here's how to deep reset NVram for the 3000/3010/3100cn printers:
1. Pwr Off
2. Hold the Left + Right + Menu buttons while you Pwr-on (release them when display = DIAGNOSING...)
3. At the PASSWORD prompt, press UP, UP, [enter] (enter=center button)
4. Down button to INSTALLATION SET; [enter]
5. Down button to NVM Init; [enter]
6. OK?, [enter]
7. After completion message, Pwr off, wait 5 secs, then pwr on
After pwr on, the LCD displays "Init NVram" & "Initializing", then completes POST with "Diagnosing".
After printer completes POST, the toner level indicators on the LCD may show empty. The printer will need to be Pwr'd Off/On once again to correct display.
The procedure for the 3110cn is nearly identical. Let me know if you have problems figuring it out.
Jan 02, 2012 | Dell 3110cn Laser Printer
How to turn on lg hbs 200 bluetooth
  • Press and hold the "PWR/Talk" key on the side of the headset until you hear a beeping noise indicating that the unit has shut down.
  • 2Press the "PWR/Talk" button for 5 seconds. When you hear a short beep from the headset and see a blinking light, the headset is in pairing mode.
  • 3Access your phone or other device's Bluetooth menu, then select the option to search for devices.
  • 4Enter "0000" if prompted for a passkey, then press "OK" to pair the devices.
Jul 22, 2011 | LG HBS-200 Bluetooth Headset
PWR light is on dash, what does this mean ?
This light usually indicates that you have selected the power option for your transmission shift pattern(normal or pwr)
There is a button on the center console or the shifter that selects pwr or normal trany shifting, if pressing the button again does not change the light than the button or wiring may be defective and require further diagnosing
Mar 22, 2010 | 1996 Toyota Camry
My Sony VAIO VGC-RB43 PC cannot reboot there is a green light blinking in the back and i want to know how to reboot my computer.
if able u can reboot by accessing start button and clicking turnoff and choosing restart. some pc's have restart button under power button. if not you can shut it down by holding pwr button for 10 seconds. some computers will not reboot if your hardware abstraction layer (HAL) was corrupt. if so you have to reinstall it. u can just follow help options in your pc help by pressing F1 and seraching for HAL.
Nov 27, 2009 | Sony VAIO VGC-RB43 PC Desktop
How do i program this remote to a mitsubishi tv?
  • Manually turn on the device you wish to scan for (e.g. TV)
  • Perform Power Scan by pressing and holding (approximately 3 seconds)the desired DEVICE MODE button TV, VCR, CBL, DVD or SAT until the status indicator light begins to blink.
  • Press and release the PWR (power) button. The status indicator light will stop blinking and stay ON at this point.
  • Press and release slowly and patiently the blue UP ( ? ) button to scan forward through the code database. To scan backward through the code database, press and release the blue DOWN ( ? ) button. Each time you press the up or down arrow, the remote will try and turn off the device (TV, VCR etc) you originally selected.
  • When the device (TV,VCR etc.) responds by shutting off, press the ENTER button. This will store the code
  • in memory and you will see three blinks of the status indicator light to confirm the code input. Be patient, there are over 100 codes to search through.
Oct 20, 2009 | Big Button TV Universal Remote
TV Wont PWR UP
I had recently had a problem with the Video block or Light Engine as some call it. The TV had blue blotches and streaks in the lower right side of the screen. I sent the light Engine in to TSM INC. in Evansville, IN and they rebuilt it for $300.00. I just got it back yesterday and when I reassembled it I forgot to plug in a connector thus the failure code of 4 red light flashes. I took it back apart and discovered my mistake, corrected it, reassembled it and the TV works perfectly. If you need any help with this process, let me know.
Jan 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF-55WF655 Won't Pwr up
There's a fan in the optical block (light engine) You may also have either an intermittent fan or a bad connection from the fan(s)
michtech
Televison & Video Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
