Samsung DLP HLN507W color wheel sensor
Hello, my color wheel has been acting up, it doesnt always start when I power the TV up, I noticed the wires from the sensor module were fried badly, brittle etc, I suspect the sensor and wheel may have been damaged, at least I am hoping its not the DMD module
I replaced the sensor wires and stuck the wheel assembly in the freezer a few times, and it started about 6 times before it stopped agian on one attempt, the wheel itself sounds ok when it runs, it has 4 and 8 ohms across the ribbon cable at different spots so I am focusing on the sensor now
Those two square components on the sensor board what are those led diodes? does anyone know what they are maybe diodes and if so what type and rating? I am hoping I can find a match for them if thats the trouble, I just want to get the thing to run long enough to test the DMD module and Light Engine
Any info would be appreciated Thanks
  • erikinfenix Oct 29, 2008
    My sensor seems to be fried as well. My tv freezes with an negative black and white image. I am hoping that the sensor is the culprit. Right now I am waiting for a phone call from samsung for they are trying to locate which sensor I am looking to replace. Is this thing easy to find at a local electronic store?
  • Yohon Nov 09, 2008
    The fact that my colorwheel didnt always start afterall was not the wheel or sensor, it was scrammed logic due to shutdowns caused by an Osram replacement lamp that was either bad or incompatible with this 5 year old set
    I think the switching power supply was also messed up from the hundreds of starting atemtps I had made trying to figure this out
    After I installed a Phillips OEM lamp it started working eventually after the logic and power supply stabilized
    another thread with good info Samsung DLP problems http://forum.ecoustics.com/bbs/messages/...
  • 74 Answers
SOURCE: DLP DMD board
BP96-00249A $937 at partsore.com i hope that isnt the problem
Posted on Sep 22, 2008
SOURCE: Proscan PS60690
First of all I take it that your TV is a PS60690 model. Unplug the TV and let it sit for a few days because there is approximately 3,300 volts at the splitter. You’ll have to remove the front lower panel. It is held in by clips around the top. I removed it by hand. Once you get your fingers to pull it away a bit the clips should release and then you can just lift the piece up and out of your way. Next you will have to remove the convergence panel in the center. Remove the bolts that hold it in and un clip the four wire connectors (2 on each side) and set the panel to the side. The splitter is now visible by looking into the hole and up to the left. It is held in by 2 bolts one in the front of the splitter and one in the back of it. Don’t remove it until you have all of the wires removed. Remember to be very careful here because of the potential voltages. The voltage should bleed themselves off over time but might not! I used my electrical meter to test for voltage before I touched any bare wire. What I did was remove the wire with the red grommet that holds it up into the splitter. There are 3 green grommets and a black grommet. They might be hard to see the colors because of the dust …. Just wipe them off. The red one is the one on the far left of the wires that are 4 in a row. I used a screwdriver from the front and lightly pushed the retaining clip towards the back of the TV while gently pulling the wire downwards. Watch out for the little bushing that is around the wire. Try not to lose them because you will need them to put the splitter back together. Now I took the red lead from my tester and touched it to the exposed wire end that I just removed and touched the black lead to the metal part of the TV chassis where the splitter is actually mounted. Once you’ve established that there is no voltage present, label all of the rest of the wires so that they will be put back in the right places when you are ready. Test each wire the same way before touching them. Remember to be careful and capture all of the little bushings You will need the splitter before you do this so you will have to buy it. The RCA part number is 205064. I have to run right now but I will send you any info that you might need ……. Just ask …… I don’t mind helping out if I can. There is more.
Posted on Oct 06, 2008
welcomejee
  • 10594 Answers
SOURCE: Please help!!! Problem with JVC DLP TV
How old is your TV?
Lamps in DLP TV has specific working hours and physically lamp will look good but won't give light ( actually consume more current and protection circuit stops power supply)
Thank you.
Posted on Dec 05, 2008
  • 1694 Answers
SOURCE: Samsung HLP 4663W DLP TV 3 lights blinking
Color wheel is the biggest failure part in Samsung DLP...
A little technical to replace...............T.
Posted on Jan 24, 2009
SOURCE: DMD Board failure on Samsung DLP
Try here:
http://www.partstore.com/GetModel.aspx?MfgName=Samsung&BrandName=Samsung&ModelNumber=HLN5065WX&PartCategoryName=&Keywords=board&Page=1&SortBy=price&SortDirection=asc#PartsearchSKUList
Posted on Feb 02, 2009
There is a humming in back of tv.the sound always good but picture doesnt come thru and i get a green screen someetimes blurry with distortion.color wheel or dmd chip or lamp starting to go out
as my experience, the most possible reason should be the color wheel or its photo sensor board.
firstly try to clean its photo sensor board, or have to replace a new wheel.
i just have this wheel, when you need to replace it, contact me freely
May 02, 2016 | Televison & Video
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
I took my Samsung HLN507W apart to replace the color wheel fan... is there a schematic somewhere in the TV or online so I can now put it back together?
You Tube have video by somebody take out the old colors wheel and steps by steps and a replacement of a new colors wheel put into the DLP tv.
May 08, 2011 | Samsung HLN507 50" Rear Projection...
My Samsung DLP model HL-P6163W keeps turning on and off and now lights are flashing. We replaced the color wheel last year and about two years ago the lamp.
could still be the lamp but it could also be the Ballast for the lamp has failed. I've replaced a lot of Ballasts on DLP machines.
Nov 17, 2009 | Samsung 61" Slim-Depth DLP HDTV
Buzzing noise
COLOR WHEEL OR COOLING FANS
Mar 28, 2009 | Samsung HLN507 50" Rear Projection...
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
657 people viewed this question
Top Televison & Video Experts
Electro Med Services...
