Question about ASUS A8N-SLI Deluxe Motherboard
IDE Hard Drive
I just put in a new IDE Hard drive, motherboard sees it, but will not allow me to get to windows(XP was installed on previous machine) in amy mode...
  • Brackstone Oct 06, 2008
    Welli it is a start, however, the computer is not reading from the XP disc either.
  • David
    David May 11, 2010
    Have you installed windows on it
  • ASUS Master
  • 787 Answers
If this hard drive was in another machine and windows was installed on it, that will usually cause a problem unless both machines have very similar motherboards. Windows is very touchy about hardware and you will probably need to do a repair install and worst case scenario a full install - with a full install you will loose all data on the drive unless you have backed it up.
Posted on Oct 05, 2008
    Genius:
  • 1,148 Answers
What ur sayin is ,,the windows xp thats on the hdd ,,was put on the hdd while in another cpu,, now its in that computer,, if thats the case,a lot of times when thats done,, its tryin to load the other cpu,, in other words ,, its sein things are diffrent ,, causing problems ,,ur best bet is 2 reboot ,,load ur windows disk and fresh copy on that hdd,, ,,,,hope that was helpful,, thanks
Can't install windows on FSB 800 motherboard its showing no hard disk installed in your computer but showing in the bios kindly help
If you are installing XP on a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 18, 2013 | Computers & Internet
Tip
INSTALLING WINDOWS XP ON A SATA HARD DRIVE
SATA HARD DRIVE ? XP INSTALLATION
The FIX.
If enabling the SATA in the BIOS does not allow the computer to boot up with SATA hard drive then change the BIOS back to what it was previously.
on Mar 14, 2010 | Computers & Internet
Problem with HP pavillion ze4900 harddrive. bios says no IDE device when trying to find hard drive.
You can try to boot from CD/DVD drive with XP cd to see if the install program can find the hard drive. Try to use default setting in the BIOS.
Sounds to me like your hard drive crashed. I had one that did this and same thing. You can either replace the hard drive, use an external hard drive/flash drive (load the os and download laptop drivers) or use a cd based OS like Knoppix.
If you need help with the XP CD let me know.
I hope this helps!!!
Jan 22, 2013 | Computers & Internet
Hi, My Laptop is a Eurocom D900T, and I tried to make a fresh install to have a Windows XP Professional. I checked that the order of the booting sequence is : CD-ROM first, IDE HD and then...
When I've had that issue in the past, it was because the hard drive controller on the motherboard had the ACPI setting enabled. Windows doesn't have the necessary driver built in to see the drive in ACPI mode, so going into the BIOS of the system (usually F2 or F10 during POST) and disabling ACPI in the advanced settings has made it work for me in the past
Mar 01, 2011 | Eurocom PHANTOM D900T Notebook
No login screen
As soon as you get past the bios screen, start clicking F8 to get a boot menu. Boot into Safe Mode.
Then right click the C:\ drive and tell it to do a full disk check with repair.
It will say it has to do it on reboot. Reboot, allow disk check to run and see if the problem is fixed.
If not, put your Windows disk back in and click Start > Run > then type sfc /scannow and clikc OK.
When finished, run windows update and reapply all service packs.
Jun 25, 2009 | Microsoft Windows XP Professional
I've XP Pro installed on Seagate IDE 80G hard drive about 4 years ago. 4 days ago, when I boot up and it shows the Windows\system32\Config\system is missing. I tried to reinstall XP without format but was...
you will need to repartition the 40gb drive and set the partion active once again for the computer to be able to utilise the disc appropriately.if it has an OS on it i would recommend a full low level format and then using disc management set it active etc.
if this answers your query please rate my answer accordingly
regards
Apr 05, 2009 | DFI /LAN PARTY NFORCE4 ULTRA-D/...
Asus m2n-mx se plus windows xp wont boot
All you need is the hard drive manufacture's setup software. Flashing you're bios is not the answer. On each drive (SATA & IDE) is the name & model number. Go to the Mf's site & download the free setup software, tools & utilities. Most sites will list software you can download to creat a bootable floppy disk or software to creat a bootable CD. Run the software on the SATA drive. Than unplug the SATA data cable & connect one IDE at a time. Again down load the Mfg's setup software. Do the same for the other IDE. Disconnect the data cable for the IDE drives. Do a fresh install of windows. (DO not allow windows to format the drive)! Just install windows & the motherboard drivers. Than update windows. Durring reboot press & hold the power on button on the PC untill it powers off. Connect the two IDE drives. Check the pin settings on the IDE drives. Set AS; Primary IDE drive 1 as master with a slave. Set IDE two as a slave drive.
Check the bios Boot setting. Make sure the SATA drive is listed in the boot order. Save & exit the PC. Windows should boot just fine.
Good Luck!
Still have an issue, post the trouble here with a description.
Mike
Jun 27, 2008 | ASUS M2N-MX Motherboard
Replace A Hard Drive On E-Machines ?mperial motherboard glve
First, check the jumpers on the back of the drive to ensure that it's set for master. There will be a legend on the drive label explaining where the jumper needs to be to achieve this. If it has been used as a system drive previously you won't need to worry about this.
Second, physically fit the drive into the tower and connect the IDE ribbon cable. The motherboard end of the cable should connect to the primary IDE slot. To identify which one is primary look closely next to the two slots, they'll be marked IDE 0 and IDE 1. IDE 0 is primary. Connect a molex power connector to the back of the drive from the PSU.
Since this drive has been used previously you should now be able to install your chosen operating system from a CD or DVD. XP and Vista both have options for creating/deleting and formatting existing partitions during setup.
These are simplified instructions and assume that it is an IDE drive and not SATA and that no second hard drive will be installed on the same IDE bus. More detailed instructions can be found here:
http://www.helpwithpcs.com/upgrading/install-hard-drive.htm#install-new-hard-drive
Hope this helps,
erch.
Mar 14, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Windows xp
kgprakash, Did you check your BIOS's Main Page to see if the board is reqognizing the drive correctly? If so did you change from Master setting to Cable Select or vice versa? Some drives don't like to play nice. Have you access to a differnt drive, just to see if XP finds it. If you have SATA or Raid capabilities on the board read the manual this messed me up for awhile (the Asus I use has 6 internal Sata ports and one IDE legacy connector). If you only have IDE, are you in the connector marked or known as IDE0? Just some thoughts.... Pcdok
Oct 21, 2007 | ASUS P5S800-VM Motherboard
ASUS A8N-SLI Deluxe Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
