Question about Dryers
Hi, I have a electric LG DLE2516W dryer, that runs, but does not heat, here's what i've been able to determine: 1. verified ac 240vac to terminal back of dryer 2. vent clear, blowing only cold air 3. heater element resistance reading red/blue=20 ohms, red/yellow=20 ohms, blue/yellow=40 ohms 4. HI-limit Thermostat open Before purchasing (item 3 & 4) wanted to ask the experts if my analysis seems on track. Thank you, Line Dry is rough
  • ksw08 Oct 05, 2008
    Thanks for the quick response MNTECH, I'll change the three thermostat's and thermistor.
    I just got this dryer 2nd hand, it was sitting in storage for the past five months unused and was informed it was working prior to being stored, so not sure of the original setup.  I did notice that the part numbers and description you provided are different from what I thought based on the little wiring diagram pasted on the inside of the dryer and a replacement parts list I got from the web (see below) and just wanted to make sure I have the correct name/part number association.
    On Element Assembly
    HI-Limit Thermostat - 6931EL3003D (this is thermostat that is open, red wire from heater connected to one terminal, other terminal to Safety/Thermo thermostat)
    Safety/Thermo Cutoff Thermostat - 6931EL3001E
    On Blower Assembly
    Thermistor - 6323EL2001B
    Blower/Outlet Thermostat - 6931EL3002A
    Thanks again for you help
  • Anonymous Mar 19, 2014
    IT TURNS ON AND IT WORKS BUT ISTS NOT DRYING
  • 1,543 Answers
Sure, looks like the high limit is your problem, but why did it fail? If your vent is good as you say, the dryer should cycle on the operating thermo (thermistor sensor in this case), and the high limit should never trip. I'd replace the 6323EL2001B thermistor too (back side of the blower housing), along with the 6931EL3003D and the 6931EL3001E which are mounted on the element assembly. Non heating issues can also be caused by a bad relay on the board or a bad centrifical switch in the motor.
Posted on Oct 05, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Oct 05, 2008
    You are correct. I somehow only listed three items, missed the 6931EL3002A.
    If this was in storage as you say, you might want to look it over for any wires chewed on by mice also. (usually none to be found, but not unheard of)
I have a Roper Electric Dryer. It quit heating
If your dryer runs, but does not heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare.
If you need further assistance, please post back with your complete model number (located on a nameplate around the door opening) and let me know. I hope you find this information helpful.
Dec 29, 2009 | Dryers
Dryer will run but want heat up
repairclinic.com
Dec 24, 2009 | Kenmore 62602 Electric Dryer
My whirlpool dryer (Duet) will not heat. What
Replacement parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop and compare.
If you need further assistance, please post back and let me know. I hope you find this information helpful.
Dec 23, 2009 | Whirlpool GEW9250 Electric Dryer
Electric whirlpool dryer works but no heat, turns works fine but no heat
If the dryer runs, but does not heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
Replacement parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
If the model number is correct, the part numbers you may need are:
Thermal Cut-Out/Hi-Limit Thermostat Kit - 279816
Heating Element - 279838
If you have any questions, please post back with your complete model number (usually located on a nameplate around the door opening) so that I may be able to provide you with better assistance. I hope you find this helpful.
Dec 02, 2009 | Whirlpool LER4634J Electric Dryer
I have an electric dryer. it tumbles but is not blowing any heat
If the dryer runs, but does not heat, the following link explains how to troubleshoot an electric dryer with a no heat problem:
If the model number you have this listed under is correct, the part numbers are as follows:
TCO/Hi-Limit Thermostat Kit - 279816
All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
All your heating circuits are accessible in the rear of the dryer by removing the back panel.
If you have any questions, or require additional assistance, please let me know. I hope you find this helpful.
Oct 23, 2009 | Whirlpool LER4634J Electric Dryer
DRYER WILL RUN BUT NOT HEATING
Oct 16, 2009 | Whirlpool LEQ9858L Electric Dryer
The dryer still spins, but doesn't get hot MOD LER6636pw1
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
If you have any questions, please let me know. I hope you find this helpful.
Oct 15, 2009 | Whirlpool LER6636PW Electric Dryer
Dryer does not get hot
If you have any questions, please let me know. I hope you find this information helpful.
Oct 12, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Dryer does not heat up.
The following link explains how to troubleshoot an electric dryer with a no heat problem:
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer will exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, generally, the Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace. All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
Sep 25, 2009 | Kenmore 84072 Electric Dryer
My kenmore electric dryer wouldn't heat up this morning it is still running, but there is no heat
The following link explains how to troubleshoot a dryer no heat problem:
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum. All Kenmore dryers are not constructed the the same. Regardles of location, the Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace. All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com.
Aug 26, 2009 | Dryers
Dryers Logo
545 people viewed this question
Top Dryers Experts
