Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
LCD won't power up, laser works
I have a rather new moultrie game spy d40 (4.0) and I replaced the batteries but the LCD display won't power on. The laser beam alignment device does turn on though??? Thanks
  • 7 more comments
  • jaetrae Oct 25, 2008
    Still no luck. Thanks
  • Anonymous Oct 26, 2008
    Same Problem-- Cheap cam- I also have another one that take way to many pics
  • waybrighter Oct 30, 2008
    Moultrie GameSpy 4.0 LCD won,t power up, laser works
  • scot319 Nov 03, 2008
    Just got my camera and the lcd screen will not power up but the laser light comes on,I can not set the date and time. I keep punching the on & off it comes on and right off.I have brand new batteries in it. Can you help?
  • Anonymous Nov 14, 2008
    Just received the same type of camer and all that will work is the laser light. What do I need to do. It also did not come with any papers!!!
  • bowanna Dec 15, 2008
    I have one and it will not take pictures. It will count down the DLY time and then appears to power off. The handheld will take pictures, IR AIM and Laserworks. Worked fine last year. Surely it isn't that hard to turn on and take pictures. :) Would love to use it. Just haven;t been ble to this year. Barely a year old.
  • Anonymous Feb 11, 2009
    My LCD screen is goofy and won't display
  • Anonymous Mar 08, 2009
    I have the same problem with my LCD display. PISSED OFF !! didnt make it six months, two hundred dollars, please help!!
  • dhartzell Mar 19, 2009
    I have the same camera, along with 6 others-two more of them moultries. Put new batteries in but will not power up- has been acting up for 6 months but now will not run at all- not problems with the other two which are infra red. Alabama
I have same camera, I assume that you have the switch to setup, hold the on/off button for 10 secs
Posted on Oct 24, 2008
I have a M100 camera and it uses batteries in a day even with my moultrie power panel
Are you sure that power supply is coming fine from that power panel? Otherwise it should not use Battery.
Apr 24, 2014 | Moultrie Game Spy M80 Infrared Digital...
"Trail card lock"
I have the exact same problem with my M80XD. I have a request in with Moultrie. I will post their answer.
Jan 10, 2013 | Moultrie Game Spy M-80xt Game Camera...
How can I fix the LCD menu display on my moultrie I60 game camera
You can buy a new display from Moultree for about $18, install it yourself and it might last a month or 2. Best thing is to go buy a real camera from somebody who want's your return business.
Jan 01, 2012 | Moultrie 6.0 Game Spy Infrared Camera...
Moultrie D50 game trail camera won't take pictures in dark
Does the flash work? Could be flash circuit or day/night sensor.If you have another D40/D50 camera that flash works but has other problems,swap out the sensors.If not the sensor but the flash circuit then most likely one of the large charge capacitors which has to be soldered in.I use a digital multimeter with I/O capacitor test function..these caps should be about 250mfd.
Nov 21, 2011 | Moultrie MFHDGSD50 Game Spy Camera D50
The camera worked for two months and took a lot of pictures. Now the LCD screen will not display. I replaced the batteries and installed a new SD card. I reset the camera and it still will not work. The IR...
It's probably the small ffc(ribbon cable) connections from control panel to main board...remove top to access control panel;remove 5? screws and CAREFULLY lift control panel from camera...ribbon cable is obvious...it connects at both ends to zif(zero insertion force) connectors...EXTREME CARE HERE...the small brown part lifts to remove pressure to cable and cable can be GENTLY removed...try re-inserting cable CAREFULLY to align conductors with contacts.
Sep 07, 2011 | Moultrie Game Spy I-45 Ir Game Camera...
I have a L20 moultrie digital game spy camer, when i turn it on it flashes busy on the lcd screen and reset does not take care of it and when i plug it into the usb slot my laptop isn't registering it? ...
I had the same issue with my L-20, replaced it with a new camera, same model, and the same condition started.
Solution: turn off,remove card,remove batteries,wait 1 minute...,install battery and turn on,in auto mode should read no card,insert sd card.
If this happens,replace card with a different one.
Helped me on the spot.
Nov 14, 2010 | Moultrie MFHDGSD50 Game Spy Camera D50
Have new battries no power
battery swing-out door may be warped in middle...found this a lot...due to tension from center battery spring
Ron L
Sep 28, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
692 people viewed this question
Top Moultrie Cameras Experts
AZBen
AZBen
Steve
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
