Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Vertical multicolored lines covering the whole screen
My Grand Wega has vertical multicolored line covering screen
  • echao Apr 20, 2009
    TV takes a minute or two to warm up (green flashing light) and then I only get randomly colored vertical lines covering the whole screen. No sound, and no visible response from changing sources, etc. Doesn't seem like a lamp issue as I'm at least getting a picture. Thanks for any help on this.
  • Any Guy
    Any Guy May 11, 2010
    Does the OSD (on screen display) work or the menu display?
Just a shot in the dark, but if you are using component video cables, double check that they are in the correct inputs and outputs. If this doesn't work or you are not using component video cables then I don't have any other ideas as of now.
Posted on Nov 27, 2008
Got colored lines vertical whole screen
Check the cables and amke sure everything is connected properly.Red, Green, Blue cables the broadcast the HDTV signal. Does the problem the same when you play the VCR? If so then the tv is having problems.
Mar 18, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a blue line problem with 50 inch sony wega.
Take to TV repair shop. contact Sony get RMA first for warrenty work! so free work gets done!
Oct 09, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Green line running vertically along the edge of picture
If its a LCD projection TV (such as Sony Wega, Hitachi, Epson, Philips, and some Panasonic, some Mitsubishi), and the green image is in the whole screen or just one part as a blob or a line. Is most probably that one of your LCD Color Filters is damaged (burned out or starting to get busted), I don’t know if you can just replace the color filter, I believe you need to change the whole light engine system or the optical block. There are some places around, I found some on ebay but you should definitely try on discountdashmerchantdotcom their price range $260.00 - $330.00
Jun 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue Vertical Lines on the screen
It means the optical block is going bad. Contact Sony support. They will sometimes warranty these even after the 1yr warrany has expired. Have your model and serial numbers handy.
May 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony WEGA has multicolered vertical lines
OK, much as I have reservations, let's try service mode. To enter service mode, you MUST have the original Sony remote. You need to press these buttons in order, with the TV off. You have about 2 or 3 seconds to complete the series of buttons. Press:
Display
#5 (the 5 on the number keypad)
Vol + (volume up)
power
Then, after the screen is lit, press the "jump" carefully 3 times. If the word "penle appears in the upper left corner, the optical block is OK and it's probably a Q-box problem. It COULD also be the LVDS cable that sends the signal to the optical block. If you press anything else, IMMEDIATELY TURN THE TV OFF AND START AGAIN. The TV should reset to the original values.
Oct 21, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
SONY GRAND WEGA KDF-60WF655 - VERTICAL LINES
This seems to be common problem with Sony projection tv. I have the KDF-E50A10 that lasted only 2 years. It's sitting in a corner now until I figure out what to do with it. I am not going to spend another grand to repair it!! Never Sony again.
Jun 16, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Blue vertical lines
Yes...your light engine/optical block is shot... 1500 dollars.
Jan 25, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Vertical lines
IF the area of the OSD (on screen display) displays the same vertical blue lines as the rest of the screen, then it is most likely the optical block assembly at fault. It's part number is A1606006A and should cost close to $2,000. I'm assuming the set is out of warranty. I know many people are hooked on Sonys, but as a technican that works on them, I wouldn't want one in my home.
Dec 08, 2006 | Sony Grand WEGA KF42WE610 42" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
308 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
