Question about Gateway Computers & Internet
When starting computer it states that no signal is found 5 minutes later my screen freezes up.
  • 749 Answers
Check the cable from the monitor to the computer. Make sure it is connected completely.
Posted on Oct 05, 2008
Touch screen freezing Sony vaio
It could be overheating. That will cause problems such as freezing and crashing. Make sure that there is airflow from the exhaust.
Sep 02, 2014 | Sony Vaio Fit 15E 15.5" LED Corei7 2 GHz 8...
Was playing Super Smash Brothers, played 1 5 stock 1v1v1v1 against 3 computers, then went and started a second round. It lasted for about a minute or 2 and then it locked up... i hit the reset button, and...
Well I think that the expansion pack has died I had a problem while I was in the middle of perfect dark it would freeze and then 2 seconds later the screen went black and than it went to the tv screen saying no signal. the expansion packs make it look like it died but it didn't.
Nov 01, 2010 | Nintendo 64 Console
My computer is only left on for about 5 or 10 minutes and it freezes up to the point where I have to reboot it and it usually takes 4-5 times of rebooting for it to come up to "start windows normally"...
CorruptedSystem Files
Your computer freezes due to corruptedsystem files. System files corruption is one of the most responsible causes forcrashing the entire computer. Deleting or moving the system files may crashyour computer.
1. Insert the Microsoft Windows Installation CD ROM.
2. Click Start ' Run.
3. Type SFC/ ScanNow and press ENTER.
4. Follow the instructions on your screen.
Corrupted Registry
System registry corruption leads to runtime errors and your computer crashes.Windows Registry is very complex and not easy to repair manually. Hence, athird-party Registry Cleaner and PC Optimizer software is recommended.
1. Download a Registry Cleaner and PC Optimizer software such as Reginout.
2. Click Registry Cleaner tab.
3. Click Start Scan.
4. The registry scan will start. Wait till it is finished.
5. As per the results, click Fix Now button to start repairing you registry.
Often good registry cleaners include built-in Backup & Restore centre thatlets you recover from an unforeseen situation by simply restoring the state ofyour registry.
Faulty RAM
Your computer freezes due to problemswith the computer memory. A faulty RAM may result in Blue Screen of Death(BSOD).
In such a case, remove the existing RAM and clean it using a soft cloth. Then,connect it again. The problem may not persist..
Incomplete Installations
Your computer freezes because of a previously failed or incompleteinstallation. An incomplete or failed installation creates junk registryentries and thereby system crashing problem.
Repair the registry entries created by a failed setup and delete the files thatstill remain on your hard disk. Delete the contents of C:\Windows\Temp folder.
Disk Space Allocated by Unnecessary Files
Your computer freezes if the operating system has no adequate free disk spaceto perform its operations. Temporary files, temporary internet files, logfiles, browser cache and other files may occupy a large amount of your diskspace and thus generating runtime errors that crashes your system.
Using Disk Cleaner, delete the junk files from your hard disk. The steps are asbelow:
1. Click Start ' All Programs ' Accessories ' System Tools ' Disk CleanUp.
2. Follow the instructions on your screen
Oct 01, 2010 | Acer Aspire T690 (AST690UP820A) PC...
I have a dell latitude laptop my problem is, it takes over 5 minutes to power off. I click shut down screen goes to desktop screen no icons about 5 minutes later it says its shutting down screen goes black...
There may be nothing running in task manager that you can see but there is still something running,My advice is to take it to your local Geek Squad or preferred computer tech you most likely have a virus that is slowing down your computer process.
Sep 24, 2010 | Dell Latitude D531 Laptop Computer PC...
Computer turns on, however after 2 minutes
Corrupted Registry
Faulty RAM
2. Follow the instructions on your screen.
May 10, 2010 | Acer Aspire 5500 5570-2609 Laptop
Computer freezes after about 5 minutes of turning
Looks like the Laptop is running some backend program which could be either a service, an application running at the stealth mode, or a driver program that seems to seize the Memmory resource allocated to the Kernal. Did you try check the system log by going to Start - Run - eventvwr.exe wherein you will find two heives namely Application and system. On the second start try to go through this event viewer which is opened as i said before and find out if you can locate any memmory related critical error or any application related critical error which lead it to a hung state and a restart registered later.
If you cant find that please boot in a safe mode and see if this is happening. It should not happen ideally speaking. Still if this is happening, try to restore the OS or run the repair disk of Acer Aspire. This should resolve the issue. Still if you cant resolve this issue its surely due to a hardware problem. I would advice you to go ahead tappering the chances of problems starting from an OS monitoring to Hardware Troubleshooting as per the steps i have explained here. Good Luck.
Feb 14, 2010 | Acer Aspire 5610-4648 Notebook
Zig-zag screen that freezes, then no signal on reboot
I would try the video card on another system with a different monitor and see if it is working ok then check the monitor and so forth
Jul 20, 2009 | HP Pavilion a6600f Desktop PC
Gateway laptop 450ROG freezes up after it gets hot & screen frzs
This definitely sounds like a heat problem. The system fan should cool it, but there may be a lot of dirt in the heat sink or along the path that the fan blows air. The first thing I would try is to get a can of canned air and blow it into all the vents under and on the side of the computer. If it is dusty, keep your face away.
You didn't say, but if you let the system cool down for a while (maybe 15 minutes or so) and start it up again and the same thing happens, it['s definitely a heat issue.
Feb 08, 2009 | Gateway 450ROG Notebook
DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Feb 08, 2008 | Samsung DLP HL-P5663W 56" TV
No Signal problem
your lcd need a tech who could help you to repair the power failure.
Nov 30, 2007 | Acer AL1913 19" LCD Monitor
Computers & Internet Logo
22 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
