Question about Symbol LS9100 Hands Free
Symbol LS9100 cable DIY
is there a schema for assemby the data cable of my Symbol LS9100 for ps2 interface or rs232?
best regards
How I can transfer my files from a Acterna 5100E OTDR to my laptop? It only has a standard internal flash drive and 9 pin output. I have the original software.
This devices interface is extremely old technology the 9 pin connector is most likely a rs232 serial interface . If your laptop has a 9 pin rs232 interface you may need a DTE to DCE adapter .
if you do not have this old rs232 port on your laptop I think this device a usb to null modem rs232 DB9 Serial DCS Adapter Cable with FTDI.
http://www.startech.com/au/Cards-Adapters/Serial-Cards-Adapters/USB-to-Null-Modem-RS232-DB9-Serial-Adapter-Cable-DCE-FTDI~ICUSB232FTN
https://en.wikipedia.org/wiki/Null_modem
from my reading of the manual a null modem may be needed
Nov 16, 2015 | Cell Phones
I have symbol ls9100 400bc it read barcode but does not display out put
Seems like you need to setup the communications protocol. You need to setup the type of communication that the device you are connected too if serial port then RS232 plus baud rate data bits parity etc.
Nov 10, 2014 | Zebra LS9100 PEARL WHITE HOLDER ROHS
Symbol LS 9100 does not transmit data
after scanning the defaults barcode you just scan the "Enable LS 9100 Communication" on this manual on the link above.https://docs.symbol.com/manuals/1536503c.pdf
May 11, 2010 | Symbol LS9100 Hands Free
Garmin GPS 76S USB interface data cable
The convertor has a microchip in it to do two way signals. Not a DIY project.
Others are available online for less than $5-10.00. Try Ebay.
Good Luck
Mar 05, 2010 | GPS
Hello! I have a problem with scanning bar codes by ls2208 scanner. This device uses rs232 serial port, and when I try to read some bar code, the scanner is reading, but there is no number in notepad. How...
The scanner is sending the data to the serial port. You need an application to pull that data in off of the COM port. You can test using HyperTerminal. The scanner defaults to 9600 baud, 8 data bits, 1 stop bit, no parity and no hardware or software handshaking. Point HyperTerminal to the correct COM port (most likely COM1) and set it to the settings I just listed. When you scan you should see the data show up in the window.
If you want the data to go into Notepad or any other program expecting keyboard strokes I would recommend the Motorola (formerly Symbol) USB cable CBA-U01-S07ZAR or the CBA-K01-S07PAR keyboard wedge cable.
Jul 13, 2009 | Symbol LS 2208 Barcode Scanner - P/N...
Have a look at the HOST setting in your defaults. I set one of these to default and had the same result. I'm guessing it's because the HOST is blank on Default settings.
Feb 07, 2009 | Symbol LS9100 Hands Free
Scanner doesn't turn on
Hello Loverboy,
the scanner turns on automatically as he he receives power from the host interface.
Please check the cables and connection. For RS232 interface would you need an external power supply. USB can power the scanner without external power supply. By Keyboard Wedge installation please connnect also the Keyboard.
Nov 09, 2008 | Symbol LS2208 Handheld
Ls9100 to er600 cashregister
I don't believe CRS provides pinouts for that scanner and cash register combonation. It would be easiest to just buy a cable from them or a local dealer.
Sep 10, 2008 | Symbol LS9100 Hands Free
Symbol LS-9100-4008A
Hi I'm trying to find keyboard wedge Configuration to re-program my scanner
It's a symbol LS-9100-400BA and connections if you can fax to 1-956-546-8752
Aug 28, 2007 | Symbol LS9100 Hands Free
QS6000 Plus barcode scanner
you can not change a qs6000 from ps2 to usb by just changing the cable. the interface inside the unit needs to support usb, to check this look at label with the serial number and if it says "I/F=KBW/RS" your our of luck, and can only use ps2 or rs232. if it says "I/F=UW" then you can just scan 3 barcode from the manual to set the interface to usb
Aug 28, 2007 | PSC QS6000 Plus Handheld
Symbol LS9100 Hands Free Logo
568 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
