Top half of screen is darker than bottom half
On my sony lcd tv that i have the top half of the screen seems to be much darker than the bottom half. I have tried resetting the settings, and adjusting the contrast all the way up. I also noticed that the when adjusting the screen pic it will sometimes staticy/flickery on the edge. Almost like the graphics driver for the lcd is going bad, like a bad video card in a computer. I know alot about desktops/laptop computers, but the insides of an lcd tv i am more or less clueless overall.
Any help would be great appreciated
Thank you
  • 1 more comment
  • Raven1708 Oct 05, 2008
    Its a sony KDL-40S20L1 40"
  • guest12312 Apr 09, 2009
    I have same problem with brand new Samsung 2443BW monitor.
  • Anonymous Mar 30, 2014
    banner appeares across the top and then across the bottom of the screen.
The problem is most likley the TV backlight - it is very unlikley to be the graphics card or video input or any other circuitry within the TV.
Also, the problem can be manifested by flashing or flickering of one or both halves of the screen, and sometimes it is a left/right split rather than a top/bottom split, depending on where the lights are positioned. Before failure, you sometimes hear a very high frequency buzz for a few weeks before it fails - the frequency can't be heard by most adults as it ranges from 15kHz-25kHz, but children\animals can usually hear it.
Generally you will need to replace the backlight tube or the invertor that drives it. Generally you can identify the backlights as thin glass tubes buried deep within the panel itself usually with one wire going to each end of them - they are very fragile. The invertor is connected to the backlight tube and looks like a circuit board, often containing a high voltage warning. Usually there are two or four conductors connecting the invertor to the tubes, which can be identified as thicker individual wires as opposed to the flat ribbon wire used for data for the actual image displayed on the screen.
On some screens you may be able to unplug\swap one or both tubes to identify if it's the tube or inverter.
Posted on May 03, 2009
Why half screen is ok, other half I.e. bottom part horizontal lines are seen.
Your LCD or Control Board is damaged. You can replace the LCD or the Board or have someone do it for you.
Aug 03, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Sony bravia kdl-40s2010 top half of screen is fading
Most sets use two boards (each drives the image on half the screen) some combine both into a single larger board but if a even half of the screen is doing something the other half is not that is where the problem likely is.
Different makers use different names for this like T-Con or Y out etc.
You if interested might Google the model number with "parts" which may provide you a list of the boards in this set along with prices in some cases.
Dec 17, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
Lcd half darker than the other
your always welcome here in fixya..
May 18, 2012 | Samsung Televison & Video
The top half of my Sony Bravia 32" screen plays as
I'm sorry, it sounds problem with lcd panel (screen) that is defective and causing lower half distorted image. If tv is under warranty then call number written on warranty documents for warranty cover or lcd panel (screen) replacement would cost you approx 80% of new tv price.
Hope these info will help you.
Thanks.
Nov 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Asus AL2216W top half screen got darker. Lamp problem ?
When the lamps are bad, the screen will shut down if the inverter cricuits is sensing open (lamps will not fire up and conduct, or lamps are drawing too much current). You should open it up and inspect the caps in the power supply first, lamps in this monitor are ntoeasy to replace (screnn will to be complete,ey disassembled.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 24, 2010 | Acer AL2216WBD LCD Monitor
Darker fatter letters every 2 inches apart from top to bottom
it is called phase you can attempt to let the lcd monitor auto set or you can disconnect the power over night then plug in and then do not auto set this default usually seems best some times
Nov 29, 2008 | Proview PL926WBi 19" LCD Monitor
Samsung LCD television screen fault
My new TV LCD Samsung LC32C530 Series 5 has one half darker and with less contrast than the other.This is noticeable now always. There is a distinct and clear division down exactly half the display which separates the dark and light sides.. Any ideas?Thank you.
Jul 08, 2008 | Televison & Video
One half of screen sees darker than other
Problems described are related to Backlight.It is possible that backlights of affected area have become weak.
You may need to contact the company for repairs and Yes the Repairs may not be cheap.
Samir
Nov 01, 2007 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
1,655 people viewed this question
Top Televison & Video Experts
Electro Med Services...
