Question about HP Photosmart 3310 Printer
Hp photo smart 3310 all-in-one
It prints only part of the letters in a line. for instance it may leave off the top of the letters or the bottom or the whole row
  • suzy4me Oct 05, 2008
    I clean the printer heads , which didn't print out well and I also tried to align th printer which could not align and the message was alignment failed. refer to device documentation for details
    Scholar:
  • 125 Answers
You need to check your printers nozzles. Should find it under Properties of the printer and then you can select clean nozzles where you printer will clean the nozzles. Also do a Head alignement.
Posted on Oct 05, 2008
Printer cutting off words
Is this happening with every program you use to print? If it's just a single program, try changing the line spacing. It sounds as if you've got the line spacing too small for the current font and it's cutting off the bottoms in order to print the next line.
Jun 10, 2013 | Canon Pixma Mp530 Office All-In-One Inkjet...
Efforts to print 4x6 borderless print result in only top part of photo paper being used and top third of photo being cut off
First thing to try (and I'm assuming you're attempting to print a photo within HP Image Zone & have already selected the 4x6 photo tray? Hint: can be done via printer, properties, printing shortcuts) is to change the 'more options' directly below where you'd selected the 4x6 image size and then change to 'shrink to fit' vs. the default 'crop to fit'... Additional thoughts includes rotating the image (can be done directly on the preview screen...)
Dec 18, 2010 | HP Photosmart 3310 Printer
I have a hp 3310 wireless. It prints in colour well but if you print in black most will be not clear although a line every so often is printed clearly. If you print the same document the same lines...
What you are trying to print is created in RGB. This means it is a photo that has been created in a color format that will ONLY print if you print it in full color. If you try to print your photo item in only black, it will only print what it sees in TV Colors, a combination of RED GREEN BLUE. This is why you will only get part of the image printed when only in black.
The only way to change it to print the whole image in all black, is to open the image you are trying to print in Photoshop or another professional grade photo program, and to change the settings of the image to CMYK, effectively, Cyan, Magenta, Yellow, Black. Then, change the image once again - to GREYSCALE. This will effectively change all the colors to a SHADE OF GREY, in different HUES.
Save the picture as a JPEG, and then print from the desktop, from your picture viewing software that came with your computer, and you will see everything print out from the black ink, in greyscale.
Nov 16, 2010 | HP Photosmart 3310 Printer
The black ink on my HP Photosmart 3310 printer does not print. All the colour cartridges print with no problems.
Black printer ink in HP Photosmart may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Sep 14, 2010 | HP Photosmart 3310 Printer
HP 5740 Printer skips top half of several lines
try a letter with brown letters to see if it is the black ink cartridge Refilled cartridges do that from time to time
Sep 12, 2008 | HP DeskJet 5740 InkJet Photo Printer
Every third or fourth line does not print
test it by changing your font color and prove it either way that is all I can say yiou do not check it this way I have no other ideas
Sep 04, 2008 | HP DeskJet 5740 InkJet Photo Printer
My HP Deskjet F2100 All-in-one printer/scanner will not print a photo which is only post card size at less than A4 size when I use photo paper. It prints the correct size when I use plain paper.
just leave your paper type as Plain Paper,
and if your printing out a 5R size photo or photo sizes not exceed on Letter size paper, just leave the paper sizes using Letter,
print on both sides set as OFF.
then just customize the printing quality for a good printing result.
then load or place your photo paper properly on the paper tray to avoid jam.
Aug 24, 2008 | HP Office Equipment & Supplies
Lowest part of every line won't print
Even though your cartridges are newish it sounds like some of the nozzles are blocked. If you go through the menus on your printer and hp driver on your machine and try to find something like a nozzle check (all inkjets have them) and see if the graph prints out perfectly. If there are any gaps (particularly at the bottom) then you have blocked nozzles. These can be fixed usually by running a few printhead cleans which can usually be found in the same menu as the nozzle check.
Feb 11, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP Photosmart 3310 Printer Logo
700 people viewed this question
Seeker5211
Seeker5211
