Desktop compter problem
My computer freezed. Since the one who is using that time is a child what he did was pull the plug then put it back. I don't know if it has something to do with it but when he turned it on again it does not start. When I check it there is power, it seems it booting properly, though there is short beep at the start of the booting but the monitor remains black. When I check the monitor it is properly working. I tried to clean the memory but with the same result. What could be the problem? Thank you very much.
    Sergeant:
  • 268 Answers
Well since he pulled the plug you may want to check all the connections on the back of the computer from the monitor , he may have knocked something out a bit causing your monitor not to work....also check the connections on the back of the monitor....
Posted on Oct 05, 2008
I have dell computer and the green light is lit on the power supply put the compter won't come on
When did this happen? Have you checked the monitor cabels if they're properly plugged in?
Aug 07, 2014 | Dell Computers & Internet
HP DESKTOP
Hi had this same problem. unplug computer tower an use another screen, i used my tv. plug vga into tv an turn on computer. go to Control panel and then Devices. look for your monitor an uninstall it from computer. then shut down the compter unplug an replug back into your lcd monitor it will automatically reinstall it for you. hope that works. just a pain havin to move it!
May 07, 2013 | Computers & Internet
Is there a external CD Rom drive for a HP Pavillion a1410y desktop computer
Why not just replace the CD drive in the PC? Don't be afraid to pull the cover.Turn the PC off,but leave it plugged in(the grounded plug will prevent static damage).Disconnect the drive,pull it out,put in a new one.(Don't forget to match the option pins on the back of the drive to set it for "slave" or "master".
Sep 07, 2012 | HP Computers & Internet
Clear cmos p4b266
Looking at a picture of the mother board, the cmos battery is located by the 4th (counting from the bottom) PCI slot. This battery is round like a watch battery. Make sure the power is unplugged from the computer and then pull the battery. You will see a silver tab holding the battery in, a small screw driver will let you move the tab over and the battery will pop out. Let the computer sit like this for about 30 mins (some models require far less time, others more, but 30 mins is a good average) then put the battery back in and plug the compter in. When you turn on the computer of get into the BOIS you should see the date and time are way way off. This indicates the cmos has been cleared.
Hope this helps
Apr 01, 2012 | ASUS P4B266 Motherboard
I need to restore my compter to facotory using system recovery and I don't have the disk. I have a Emachines EL1850G-42W
Hi christoph73030
You have three choices..
1...Try to do a system restore to an earlier date.
This will take your comuter back to an earlier time when it was operating good, pick one of the darkened dates before your troubles started..
To do a restore: Start>All Programs>Accessories>System Tools>System Restore
2...Buy a restore disk from Emachines
3...Buy and Install a new operating system...
Sorry for the bad news
Please take time to rate me
Sep 05, 2011 | Acer eMachines Black EL1850G-42w Desktop...
My mouse keep freezing up for periods of time and i have a restore cd that don/t do anything when i put it in
I wouldn't use restore cd
I would:
Press CNTRL + ALT + DEL, when the mouse freezes
Then i would look in the task manager and sort the columns by CPU % usage
See if a program is taking up all your CPU
Post back here the name of the program
You can then remove or fix the program casuing your system to slow
Apr 05, 2011 | E-Machines eMachines Desktop PC
G 60 White screen and freezes
You can try to do a System Restore the laptop and bring it back to the state that it is working properly or you can also use the Recovery CD, You can do a Clean Install as well. The computer might be infected by a virus, spyware or malware that messed the compter
Thanks for using Fixya
Aug 01, 2010 | HP G60-230US Notebook
All my usb ports won't work
- Under device manager delete all usb controller.
- Reboot system, check if the usb controller will auto install, then try to check if this resolved your issue if not.
- Last option -Back-up data - Reinstall windows.
Oct 08, 2008 | Computers & Internet
Will not start up normally (freezes )
shift prees then mouse buten click for startup freezes icon then uninstaLL
Jun 24, 2008 | HP Media Center m7060n PC Desktop
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
