I have a Canon MP210 printer. When I ran out of black ink, I replaced the ink cartridge with the correct PG-40 Black FINE Cartridge, and the printer is printing just fine again in black. However, it will no longer print in color. The color light is on, but it was on when the black was flashing, even though at that time, it was printing fine in color. It doesn't even try. I just get nothing. What should I do, short of trying a new cartridge, which I don't think is the problem since I don't use color very often. Thanks for your help.
    Sergeant:
  • 197 Answers
Is it a possible setting on your printer? many have the option to print black or with color - should be in the menu... This may help...
http://gdlp01.c-wss.com/gds/5/0300000025/01/mp210_qsg_en-us_v1.pdf
Posted on May 06, 2017
SOURCE: Printer won't print color only black and white
Reinsert the color cartridge. Give print command for page. Open Preferences in print window. Open the Color tab. Click on Print in Color. (It may have been set for black only.) Try printing.
Posted on May 24, 2008
SOURCE: refilling of canon ink fine cartridge pg 41
reset the cartridge from the printer. there are a few steps to follow
Posted on Jun 24, 2008
CWChar
  • 14 Answers
SOURCE: Error Number : 1485 The following ink cartridge cannot be recogni
Nope! Canon played a little nasty on re-fillers and made these cartridge virtually un-fillable. Not that they can't be refilled, they can. They just won't be recognized in your machine.
They have done a couple of strange things with the software and the cartridge.
1. Software writes to the cartridge to actually marry it to the machine. This encodes id numbers on the cartridge so that another machine cannot use the cartridge.
2. They have placed a "fuse" of some type in the cartridge which is actually "blown" when the "out of ink" message is displayed. This renders the cartridge un-usuable for another cycle.
I like the Canon product. Just not these particular ones. The ones that take cartridges 30/31/40/41/50/51. I have seen too many of them come into my shop for repairs after barely 2 years of use. They are un-repairable regardless of their issues.
I suggest you look at a different Canon product, one that takes the individual ink tank cartridge PG-5 and CL-8 series. These are much better machines and the printer itself will last longer.
Just be aware that you will have an added cost in the print head which is a consumable that will need to be replaced every 3 years or so!
Posted on Nov 15, 2008
KingDWS
  • 1606 Answers
SOURCE: MFC-790CW; will not print the black color..
You probably have a plugged print head or the black ink feed is plugged.
Depending on how bad it is you may find it easier or even cheaper to replace the printer.
If this is a ink caused problem you stand a chance of fixing it if you are patient but you might go through half an ink cartridge to get it working, If it is stubborn it can take 20 or 30 cleaning cycles before you see any black. You can try using household vinegar (dissolves the dried ink) on a qtip or lint free paper towel to try to clean the print head. To do this you remove the ink cartridge and very gently rub the towel with the vinegar on the print head. This might require you to move the print head to one side so you can see the actual print area (where the ink comes out). Keep doing this until the towel starts to come clean ie not as much ink coming off. Then run a few print cycles and if this works your printer will print as good as the first day you had it.
The next stage would require filling a old clean ink cartridge with vinegar and running cleaning cycles. Usually can be pretty messy and you should rethink buying a new printer but will really clean things out.
It is also possible that the print head has picked up clay or paper lint from the paper and this has hardened like a cement. That means replacement.
Posted on Aug 17, 2009
SOURCE: Printer not recognizing pg-50 cartridge
I had exactly the same problem. I called the Canon helpdesk and apparently the PG-50 is not compatible with the MP210. I then bought a new PG-40 which works fine.
Bit annoying as I have wasted £35 or so on the PG-50. This is also a bit misleading from Canon as the PG-50 fits into the MP210 perfectly, and when you are looking at it on the shelf it looks like a long-life version of the PG-40.
But there doesn't seem to be any way around it that I have found. Just bite the bullet, write it off to experience and buy a new PG-40.
Posted on Aug 18, 2009
How do I fix e07
I assume you have a Canon copier based on the E007 error code. The Fuser fixing film is torn and the Fixing film assembly or the entire fuser should be replaced. Very common issue.......You cannot reset that code without first replacing the part causing the code.
Dec 03, 2014 | Office Equipment & Supplies
Is MP210 the ink for a printer
No The Printer Is A Canon Pixma MP210
The Ink Cartridges that it takes are :-
Standard :- Canon PG-37 (Black) & Canon CL-38 (Colour)
Or
Extended Use :- Canon PG-40 (Black) & Canon CL-41 (Colour)
Apr 02, 2012 | Canon PIXMA MP210 Photo All-In-One Printer
Can i use pg-40 ink for my canon mp480
Sorry you can't use PG-40 on MP480. Canon MP480 printer takes only Canon PG-510 Black Ink Cartridge, Canon CL-511 Colour Ink Cartridge or Canon CL513 Colour Ink Cartridge (this one is high yield colour cartridge).
Feb 02, 2011 | Canon Pixma MP480 All-In-One InkJet...
My canon pixma iP 1800 does not recognise refilled colour cartridge. Can you suggest a fix?
  1. For the not-so-tech friendly, installing ink cartridges in printers can be messy and time-consuming. Although companies such as Canon are constantly trying to make designs more convenient for all users, there are still several tips that can help new printer owners install Canon PG-40 printer cartridges without mess or hassle.
  2. Compatibility
  3. Although many printer cartridges are specific to only a few models, the Canon PG-40 printer cartridge was designed for use with many models of the Canon Pixma and even some of the Canon fax machines. As of September 2010, the Canon PG-40 ink cartridge can be used with the Pixma iP1600 through iP1800 printers, the iP2600 printer, the MP140 through MP190 printers, the MP210 printer, the MP460 and 470 printers, the MX300 and MX310 printers and the JX200 and JX210P fax machines. This versatility allows users to stick with the same type of ink cartridge over the life of several printers and allows small business offices an opportunity to buy one type of cartridge for all office printing requirements.
  4. Refill
  5. Replacing printer cartridges can be expensive and, if it is possible, as it is with the Canon PG-40, refilling is a cheaper and more environmentally friendly option. Refill the PG-40 by gathering a 10 cubic centimeter syringe with a 1.5-inch needle, a pair of latex free gloves, an MIS Yellow Drill Tool, Scotch tape and black ink. Remove the label from the top of the cartridge and use the yellow drill tool to open the vent hole that was covered by the label. Next, load the syringe with 20 CCs of black ink and inject it into the ink hole (where ink leaves the cartridge for the page.) Make sure the needle reaches the bottom of the ink tank and then slowly inject the ink into the cartridge, stopping when the ink begins to well up at the needle insertion point. Now remove the needle and clean the top of the cartridge off to avoid color contamination. Put a small strip of Scotch tape over the vent hole and poke a small hole in the tape with a pin. Now reinsert the cartridge and run up to three cleaning cycles to calibrate the printer.
  6. Resetting the Ink Level
  7. While refilling ink in a PG-40 can save money, it can also cause difficulties when using the automatic ink level sensor. Reset this sensor by removing the cartridge after the printer has been calibrated and placing a thin strip of Scotch tape on the line of gold-colored leads nearest the ink hole on the bottom of the ink cartridge. Replace the cartridge and wait for the computer to display a warning about the ink cartridge being loaded incorrectly. Remove the cartridge and move the tape from the first to the second level of leads and replace the cartridge. When the PC displays a message that the cartridge is not recognized, remove the cartridge and replace without the tape. The ink level will be reset.
Jan 09, 2011 | Office Equipment & Supplies
Please describe your what size ink cartridge do i need for pixma mp160 printer problem:
The following cartridges are compatible with Canon MP160:
Canon PG 40 Black Ink Cartridge Black Ink Cartridge
Canon PG 50 High Capacity Black Ink Cartridge
Black FINE Cartridge, High Capacity
Canon CL 41 Tri Color Ink Cartridge
1 Cartridge of Cyan, Magenta, and Yellow
Canon CL 51 High Capacity Color Ink Cartridge
Color FINE Cartridge, High Capacity
Nov 23, 2010 | Office Equipment & Supplies
Is MP210 and MP240 the same? can i use the same cartridge?
no both are different
Here are the list of cartridges u can use
MP210
PG-30 Pigment Black
PG-30 Pigment Black Ink Cartridge
PG-40 BLACK
CL-31 Color FINE Ink Cartridge
CL-41 Color
MP240
PG-210 Black Cartridge
CL-211XL Color Cartridge
CL-211 Color Cartridge
PG-210 XL Black Cartridge
Nov 28, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP210 getting E5 message with PG-50
Sadly Canon cripple many of their printers so that they will not accept the high yield cartridges such as the 50 & 51. As a result your printer the MP210 will only accept the 37 or 38 cartridges which are only half filled, or the 40 and 41 which are fairly full, but don't contain as much as the 50 & 51. All I can suggest is that you could try to sell the 50 on eBay, and send a strongly worded email to Canon.
Aug 15, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Price of catridge of cannon ip1300
these are the cartridges used in 1300
CL-41 FINE Colour Cartridge
PG-40 FINE Black Cartridge
click here for cl 41 prices
http://www.google.com/products?q=cl-41
Click here for pg-40 prices
http://www.google.com/products?q=pg-40
Let me know if you need anything else.
Thanks,
Ekse
Mar 05, 2009 | Canon PIXMA iP1300 Printer
Mp145 ink
Canon PG-40 Black
High Capacity Canon PG-40 Black Ink Cartridge
Pixma Series: iP1600/ iP1700/ iP1800/ iP1180/ iP1200/ iP1300/ iP1880/ iP2200/ iP2500/ iP2580/ iP2600/ MP150/ MP160/ MP170/ MP180/ MP450/ MP460/ MP470/ MP470SE/ MP140/ >>>>MP145<<<<
MP210/ MX300/ MX308/ MX310/ MX318/ iP6310D
Canon CL-41 Color
High Capacity Canon CL-41 COLOR Ink Cartridge
Pixma Series:
Jan 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Ink cartage
This printer will take either the PG-30 or PG-40 (larger size) cartridges for black ink, and either the CL-31 or CL-41 (larger size) cartridges for color ink.
Jul 26, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
48 people viewed this question
k24674
jasbo
jasbo
