Question about Maytag MDG16CS Gas Commercial Dryer
Maytag MDG16CSBWW heating problem
Dryer strat fine but after 15-20 sec. heat goes off. If i open the door and close and start again ----- same thing - works for 20 sec. and heat goes off.
Drum is working fine - just heat is going off.
maytag MDG16CSBWW - vent clean - new T - stat hi limit , new Flame sensor , new Gas valve with coils - and still the same problem ---- any ideas ? please help.
  • 943 Answers
HI thanks for the question. well ,you changed all the parts you needed to. but clean the venting from back, to the outside. thanks. please rate my answer. thanks.
Posted on Oct 11, 2008
I have a Miele Novotronic T560C. The tumble drier is working fine except the air circulating is cold - it does not heat up at all. What could the possible reason for this and/or solution?
Posted on Oct 05, 2008
Ignation element to replace
Posted on Aug 17, 2010
4 Suggested Answers
Washer_tech
  • 164 Answers
SOURCE: I HAVE A MAYTAG ATLANTIS GAS DRYER STOPS HEATING ABOUT 5 MINUTES IN
the flame going out is normal. the heat cycles on and off as called for by the thermostat. If the heat doesn't come back on i would start by changing the gas coils.
Posted on Nov 04, 2008
Healeyman
  • 1198 Answers
SOURCE: maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Posted on Apr 28, 2009
iwillfixforu
  • 619 Answers
SOURCE: maytag gas dryer will heat for about one minute
The gas coils on the gas valve have gone bad. These are located on the gas valve and will be 2 solenoids. Replace them both and should be able to get as a set. 12001349 should be the number and cost less than 60.00 for the set. Good luck and thank you for using Fix Ya.
Posted on Feb 24, 2010
Gas dryer wont light with door closed
Check the exhaust to make sure that it is not clogged.
Jul 07, 2013 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer running fine but just stopped heating. lint traps all clean.Maytag Neptune MDE5500AYW. HAVE THE DOOR AND FRONT PANEL OFF ALL ELEMENTS LOOK CLEAN AND ATTATCHED. No problem with home power...
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 23, 2011 | Maytag MDE5500AYW Electric Dryer
My Maytag gas dryer is not drying my clothes Model MDG 9316 AWW. I opened and realized that the ignater works, glows and starts the flame, but only stays on for a few seconds and turns itself off, after a...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 19, 2011 | Dryers
I have a maytag mdb5130 that the soap is caking in the dispenser so not going out and cleaning dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Apr 17, 2011 | Maytag Dishwasher
My Maytag dryer lites then goes back out after a few seconds. It will lite again then goes out again. Model MDG7600AWW
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 21, 2010 | Maytag MDG7600AW Gas Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
I have a maytag gas dryer that when turned on it will heat up right the first time (apx. 20-30 sec. after turning on) then it won't heat up again at all.
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Check the lint filter in the dryer and clean it every load.
Now go outside and check the opening where the the dryer blows outside!
There is usually a screen at the out side or a flap like door. They both are there to keep small animals from getting in!
if the screen is blocked even half way you will not have heat enough to dry! Or the door type flap is stuck closed the same results!
If this does not solve the problem, you will need service!
Here is the service company I refer my appliance customers to0!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments!
1(800) 905-9505
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 27, 2008 | Maytag Dryers
No heat
When you open the door on the dryer there are two screws on the left and right of the door opening (4) total . The front will loosen up and come forward this will expose the internal parts . do not remove the door . The door will close with the front off .
Start your dryer and look for the igniter turning on . If the the dryer is electric look for the heating element to glow. this where I would start
Mar 13, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Electric Clothes Dryer Problem
if the dryer worked fine before with the element not staying on when you open the door, etc, then what you have done is a very common mistake to make, you must have dislodged a wire off, or maybe placed one back in the wrong place, its a very easy error to make, which is why when removing parts for repair on any appliance you must make very detailed notes, better still take digital photographs with a digital camera double check any wires etc, don't worry i am a retired appliance engineer and even we can make this mistake
Sep 29, 2007 | Dryers
Maytag MDG16CS Gas Commercial Dryer Logo
379 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
