Iphone 4 juat suddenly automatically off by itself. Tried to switch it on but it wont start. Tried the dual buttons pressing but nothing works. Not even a logo appeared. No indication of any life even when we tried to charge the battery and redo all the steps for more than a minute. Anybody knows what went wrong? Fyi, we just bought it less than a month and never drop it.
is the pink screen permenant? if yes than its a problem in the screen itself, and u should change it , its not necessarily to pusrchase an original one ;)
press the home button and power button at the same time, for 15-30 seconds release the home button and keep pressing the power button until you'll see the apple sign on the screen. if still doesn't work plug to charger.
I believe you will have to reflash your device, using the restore feature on iTunes and the CFU mode in you iPhone.
To restore your iPhone, you will have to enter to CFU mode:
1. turn off your phone, or wait it get turned off by itself. 2. press and hold the power button for exactly 3 seconds. 3. whithout leaving the power button, press the HOME button for another 10 seconds exactly. 4. after 10 seconds leave the power button but still, keep the HOME button pressed.
try all these steps, of course, while you iPhone is connected to your computer with the USB cable and the iTunes software is on.
Hello !
I was in panic attack !!! did everthing and nothing seems to wake up my iphone.
I forgot to charge it so battery went full empty, then I plug it on the wall charger, and nothing happend. I let it all nite, and next morning,... surprise !!!!! still the red icon, No battery, the iphone didnt restart!!!!
How I fix it?
1-unplug it from the wall charger
2- press middle button and startup button, same time
3-when red battery dissapear, plug the charger.
4_ do this many times. Didnt work for me the first time, but at the end it works !!!!
NOW MY IPHONE IS WORKING GREAT !!!!!
GOD BLESS YOU ALL !!!!!!!!
Here are the steps to reset the iPhone. You probably performed the first reset, try the other resets.:
If iPhone won't turn on, or the display freezes or doesn't respond
Press and hold the Home button for at least six seconds, until the application you were using quits.
If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets: Try This: 1. Remove Sim Card 2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears 3. Replace Sim Card 4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this: 1.) Shut down the iPhone 3G. 2.) Start up iTunes 3.) Hold down HOME button on the iPhone 3G 4.) While keeping the HOME button depressed, plug in the Sync cable 5.) A message will pop up to ask if you want to reset. 6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
we need more info on the phone itself, has it recently been subjected to abuse water or physical? if so maybe the battery itself is damages also try to bull the battery and leave it out for a full minute! if you can get power and just not on the screen then maybe the lcd digitizer is damaged and needs replaced! (please write back with any result or questions)
