High pitched whining
Ok...my tv worked great before i moved into my new home. We finished everything and plugged in my television and nothing happens, all i get is a horrible, high pitched whining sound...........any ideas? proxy
  • 87 Answers
Sounds like a tube TV . If so I believe the tube is cracked not hard to do during moving Ive done it before. it can be replaced for around 125$ to 200$ look at how much your TV is worth and if it does not exceed the value of you unit . Then locate a repair shop in the yellow pages.
Posted on Oct 05, 2008
Tv dead. high-pitched whine when plugged-in.
Sounds like the back-light inverter board has damaged. Check it.
May 21, 2013 | Emerson LC391EM3 39 in. LCD HDTV
RCA F32650 production May 2003. Was working fine. Turned it on the next day, got no picture and a high pitched whining noise.  Please let me know what I should do to fix it.
If it weren't for the high pitch whining noise. I would say it probably is an internal fuse inside the chasis. It is rated at 1.5 to 2.0 amps. With the whining noise it sounds like a trouble shooting bench
job. Problems occur when a electrical/electronics device is turned on and turned off. Inrush voltage,
when it is turned on, can go up to three times more than normal. This also happens at turn off. Solid state components usually fail at this time. I don't feel that this is a problem that can be fixed in the home.---BBB
Jan 25, 2009 | RCA F32650 32" TV
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). The sound comes from the flyback unit.
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
It may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Thank you for using FIXYA!
IrishDruid
Oct 04, 2008 | RCA F32650 32" TV
High pitched whine
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection board..it basicaly a large coil of copper wire....you can take silcon and put on the coil...in effect damping the ocillations...hope that might help
Mar 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
High pich whine from CT-36D32 36" TV
jdosk-the high pitch noise you hear is generally from the horizontal output being shorted,the horizontal output is usually near the flyback transformer,get a digital multimeter to checkthis part.Let me know I'll try to help. cooltek Feb.16/08
Feb 05, 2008 | Panasonic CT-36D32 36" TV
Power light comes on, followed by a high pitched whine
Hi, If after trying the TV again later and problem persist, repairs are in order. A high pitched whine is an indication of a fault at the horizontal section of your TV. The horizontal provides the high voltage for the picture tube. Your best bet maybe to seek the services of a qualified professional TV repairman since this involves component level repair, soldering/desoldering, use of soldering iron and VOM (testers) and knowledge of circuitry. Good luck and kind regards.
Aug 20, 2007 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
High pitched whine coming from the back of the tv, inside
possible coil vibration look around the yoke plug try to isulate the noise to a section of the board the is acommon fault/if not call for service not pricy.
Dec 30, 2006 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Sanyo DS31520- high pitched whine, picture is fine
sounds like bad solder connections on ground of the inputs radioshack has a cheep solred gun and solder make sure set is unpluged
Dec 03, 2006 | Sanyo DS31520 31" TV
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
