Question about Kitchen Ranges
F3 on my ARGS7650SS Amana Range
Dear NJFIRE,
I have a major problem with my ARGS7650SS Amana Stove.
F3 shows up whenever I press any of the buttons: broil, bake or self clean.
sometimes I am able to heat it to 350 degrees but then in few minutes it's turns off by itself and after that happens I cannot use any of the buttons.
I replaced temperature sensor, but the problems still persists.
What should I do?
Thank you very very much in advance.
SOURCE: Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
Posted on Dec 01, 2008
jumptrout51
  • 3361 Answers
SOURCE: oven clicks to self cleans or f3, the door locks and food burns
Replace the oven temperature sensor.
Take your model number to any appliance parts store for a replacement sensor.
Posted on Apr 20, 2009
VtToolMan
  • 704 Answers
SOURCE: My stove is not allowing to bake. The broil works
It would appear that the electric ignitor isn't functioning as it should and might need to be replaced.
You can remove the oven racks and the bottom oven floor to observe the ignitor. now turn the oven on and see if the ignitor glows, if not, the ignitor is faulty and needs to be replaced.
You can enter in your full model number at the following site and get the replacement part number (and price). If you're going to do the repair yourself, be sure to turn off the power or unplug the range from the power outlet before doing any work on it.
You'll need to pull the oven out so you can get at the backside panel where the electrical connections are located. There is also a screw on the inside of the oven that holds the lower iginitor in place. Simply remove and replace the faulty one with the new one and you should be fine.
If you want to confirm that the ignitor is the only issue, you can swap out the broiler ignitor with the oven (lower) ignitor, as they should be the same part for your range. If you swap them and the oven doesn't ignite, then the faulty part is probably either thermocouple that tells the gas inlet valve control, which lets gas enter into the oven. The thermocouple which tells the gas valve to open, once the ignitor has reached the proper temperature, so if the thermocouple isn't working, the gas valve won't open.
Here's a link that you can enter in your model number and get the parts list and a line drawing for your range. I think you're missing a few letters or numbers in your model#.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=JGBP90
My bet is on the ignitor as the faulty part, but the swap test will confirm that, and if the swap doesn't work, then the thermocouple is bad.
Hope you find this Very Helpful and best regards!
Posted on Sep 10, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Posted on Jan 13, 2010
SOURCE: I have a maytag gemini stove. If you set the
definently a bake igniter
Posted on May 11, 2010
My Amana gas range spark modules won work, none of them four
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Oct 10, 2010 | Amana ARGS7650SS Gas Kitchen Range
Oven cleaning
Before you use that feature read this tip that I wrote about that...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Mar 31, 2010 | Amana ARGS7650SS Gas Kitchen Range
Describe your amana arg7800ww Gas Kitchen Range
can't get the oven to go on to bake. can you help me solve this problem thank you.
Mar 11, 2010 | Amana ARGS7650SS Gas Kitchen Range
Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Feb 09, 2010 | Amana ARGS7650SS Gas Kitchen Range
Bad electronic contral panel on Amana gas range
On the Amana: Several Ebay stores carry panels like this. Problem is, once you open electronics they usually are hard to send back.
The stove is ten years old. You'll likely spend more than it is worth finding the right part and repairing it. It might be a good time to consider buying a new stove and selling this one for parts or scrap.
May 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
Mar 18, 2009 | Amana ARGS7650SS Gas Kitchen Range
I have an Amana glasstop electric stove and i was cleaning it by just wiping it off with a cloth and i think i may have pressed too many buttons at the same time.now my oven door is locked and it was...
F3 Oven temperature sensor or circuit malfunctioning
F9 door lock or lock circuit mal functioning.
Diconnect electrical supply for a couple of minutes.
It should clear. If not contact an authorized service dealer.
Dec 13, 2008 | Amana ACS7270AS Electric Kitchen Range
Stove issue
HOW TO LIGHT THE BOTTOM OF THE STOVE (THE OVEN PART)
Jun 26, 2008 | Amana ARGS7650SS Gas Kitchen Range
F2 on Amana ARGS7650SS
well the f2 code on an amana is an over overheat fault code. the best thing to do is replace the oven temperature sensor.
it looks like this
http://www.partselect.com/xq/aspx/Inventory.1508183/qx/PartDetail.htm?SourceCode=5&ModelNum=ARGS7650SS
they cost around 40 dollars but that should eliminate your problem
Jun 20, 2008 | Amana ARGS7650SS Gas Kitchen Range
Kitchen Ranges Logo
41 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
