Question about Refrigerators
Replying to your answer
"compressor is tripping. un plug it.
let it cool and inspect the relay of the compressor. see if it is bad. if it is not then the comporessor is bad.
tnx 4 using fixya,
drcool"
Hi, thanks for the response but i do not know exactly what the relay is supposed to look like or how to see if it is bad, though I know where the compressor is. Care to elaborate?
Thankyou again!
KenFlo
  • 958 Answers
Te relay is located at the side of the compressor. it is covered in a plastic cover and the wires are attached to it.
if you can take a snap shot and post it here, i could help you check it. also if there is a capacitor near the compressor and the wires are attached to the relay also, then check the capacitor also. if you have a bad capacitor, the compressor would not start also.
tnx again for using fixya,
drcool
Posted on Oct 05, 2008
I have a Rheem rpmc-042jaz heat pump (scroll) that has a bad defrost board (47-21517 - 16) The defrost board was bypassed by a service tech to allow cooling but no heating and I'm now trying to install a...
trace the wiring of the reversing valve.. its an electromagnetic relay in the middle of a cluster of tubing near the compressor. depending on its normal state when un-powered (normal heat or normal cool) the tech may have simply disconnected the relay (normal cool), or connected it directly to the call-for-cool line (typically yellow) (normal heat) regardless of heating or cooling, the compressor always runs the same direction
Oct 31, 2013 | Heating & Cooling
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
Refrigerator model bx21vl does not cool. I can hear the compressor kick in but it kicks out in 5-10 seconds. Then after about 102 to one minute it kicks in and out again,
Compressor is tripping on overload. You may just need the overload and relay replaced due to a bad compressor relay. The relay is what switches the compressor from it's start winding to it's run winding. If you pull the relay off, shake it to see if you hear lots of rattling inside, that's a sure sign of a bad relay. I would replace both of them.
Here is the overload relay to order.
Here is the start relay to order.
Nov 27, 2012 | Refrigerators
Everytime i plug in the ac the relay switch trips
That is because there is a wire shorted in the unit or the compressor is locked up and has gone bad...
The most likely thing is that the compressor is bad... it will cost more to replace it then the unit is worth...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air ConditionerTrouble - Review the Possibilities
heatman101
Jun 21, 2011 | Fedders A7Q08F2B Q Chassis Room Air...
RS652 fridge stopped working overnight tripping circuit breaker
Turn it off completely and let is cool over night and then plug it back in and see if the fan runs and if the compressor runs...
If the compressor runs but not the fan then check for voltage going to the fan and replace as needed...if there is no voltage then trace bad to see if the main board is bad...
Start relay and capacitor may be bad if the compressor does not run after getting completely cooled down...
Check out these tips that I wrote about that... it is a greatplace to start trouble shooting your unit...and something that you can dorather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 09, 2010 | Refrigerators
Not cooling/freezing
"Pop" My friend, you already know the answer. "POP" relay, relay, relay..........You have a good sense of humor..
Jul 22, 2009 | Whirlpool GS6NBEXR Side by Side...
Flashing display and ticking coming from the back
The clicking noise you hear is the compressor trying to start but the overload is tripping that is hooked to the compressor. Either you have a bad start relay which I would replace first or your compressor is locked up. If the unit is under five yrs old but older than January 08 then the compressor not the relay is under warranty. Jan 08 manufactorers have put a one yr warranty on compressors. Its real easy to replace the start components on the compressor. Unplug first then take back panel off. If the compressor is hot more than likely the compressor valves are bad and wont pump which overamps then trips overload. Then resets and tries again. But if compressor is cool then you should be able to replace start relay and compressor should start up. Those relays usually get too hot from dirty coils and/or a bad fan motor by the compressor that blows air across it to keep it cooler. But the cost of new fridges is an incentive to try the relay. Hope this helps.
Jun 10, 2009 | Refrigerators
Overload relay
The relay mounts on the compressor and has a sliding start switch inside it. If you shake it you should feel the sliding switch within it. I fyou hear nothing or it sounds like a salt shake then it is bad. Newer relays have no way of telling other than you can visably see the relay is burned and can smell it as well. If your compressor is hot as the devil then the relay is stuck in start and both windings are going at once. This will cause the overload to trip and kill the compressor till it cools back down. otherwise the compressor will cool the box albeit intermittantly. If the contacts are disentergraded within the relay the compressor will not run.
Mar 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore side by side not cooling after a move
go to the back of the fridge see if it has a white relay on the compressor that's the piece that plugs onto the compressor if it does un plug the unit take it off and shake it if it rattles and little black stuff falls out of it replace it with a three in one relay from an appliance repair parts store just follow the instructions on the part its easy don't worry about water in the ice maker it will fill when it starts cooling if it doesn't have the relay try turning it off for 24 hours to give the oil time to run back down to the compressor and advise me further
Mar 30, 2008 | Kenmore 53642 / 53644 Side by Side...
Maytag skybox cooling
Is it cooling at all? Do you hear the compressor start or just a buzz for a few seconds? This sounds like a compressor or compressor start relay failure. Unplug the machine. Access the compressor and remove the relay that is plugged to the side of it. Shake it and see if it sounds like there are a lot of loose pieces in it. Inspect it for burned spots. If you find either one of these, it is bad. If it doesn't rattle or appear burned then the compressor is probably bad. Even if it seems ok, I would try a new one on it anyway. They aren't usually very expensive. If the relay is not the problem, check your owners manual for the warranty info. The compressor may still be covered by warranty even if the rest of the unit is out of warranty.
Oct 10, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
