Just click the link below and enter the approtiate model number of ur printer and download drivers.
www.lostmydrivers.com
Please follow the following steps.
1) Turn off the printer.
2) Shutdown the PC to which the printer is connected.
3) Remove the USB/Serial cable through which the printer is
connected to the PC and reconnect it back.
4) Now switch ON the PC(only PC and not the printer)
5) Let the PC boot up and login to windows.
6) Now switch on the printer, PC should detect the printer
automatically now.
Now Please be informed that any
Printer Driver software depends upon the hardware make and Operating System.
You need to know all these information's to do get going.
Please find the Driver software's of your printer inside the installation disk
provided with the Printer at the time of purchase. However you
can download the same by visiting the website of the company that manufactured
the Printer.
Even here you need to be careful
to download the correct software for your PC. You need to be exact with the
Printer Model number and the OS that you are using.
To install just Double clock on
the driver setup.exe file and go on clicking 'Next' until you get the 'Finish'
option and restart the PC.
Connect the USB cable to PC through which the printer is connected to
the PC Please be informed that any hardware device needs a driver software to run within a PC, and the driver software depends on the Hardware Make/Model and the Operating System software you are using in your PC to operate it.You will get the Driver software of any hardware within the CD provided with the hardware part at the time of its purchase. The hardware may be an entire PC,Laptop,VGA card, sound card, LAN card,webcam,printers etc. If you feel that, my answers have helped you getting solution to your problems then please give a vote.
Now switch ON the PC(only PC and not the printer)Login to windows and now switch on the printer.Now PC will ask for the Driver as new hardware found wizard. Here you need to install the Driver.
If you do not have the CD or misplaced it somewhere then you need to download the driver software to get going. Thus you need to know all the above information to get the exact software your PC needs. As you have not mentioned the Operating System you are using, i am unable to give you the direct download link.
However you can download the same by visiting the 'software downloads' section of the website of the hardware brand you have purchased. You just need to Google the name of the brand and visit their website and search for the download section.
