SOURCE: 2002 Toyota Sienna cabin air filter??
Unfortunately, no.
Toyota began installing the cabin air filters in the Sienna product starting in 2003.
SOURCE: Setting the timing in a 2002 Toyota Sienna.
there are marks on cam gears and t-belt cover that will only line up on # 1 fire. Here you leave the belt and start tearing down. The new belt has marks that can only go one way and the crank does not have to be aligned perfecltly.
SOURCE: 2002 Toyota Sienna A/C Problem...
Being 2002, its probably has original feon in the systems, you sysytem may be low and needing recharging, recharge the sysytems will tell you exactly what your problems is. If your compressor is not kicking on, mean you either low on feon Or the presure swicth may be faulty, if not than it would be your compressure, ect....., have it rechage first before anything, that may solve your problems..if the system is low on feon the systems will not run period.
SOURCE: 2002 toyota sienna change transmission fluid and
hi,
I had transmission fluid drain and fill last year and had not driven more than 6K since the transmission fluid replacement andfound out that the fluid color getting dark.
My question is now how I should change it now, should it be completely flush or regular drain. I have heard that complete flush makes the transmission seals weak, that is why not recommended, is that true
please help
