Hard drive restoration software
How do I copy files off my non-working hard drive (or make the drive work again)?
  • 69 Answers
Posted on Oct 05, 2008
What System Restore not working. Gives a volume shadow copy timed out error when trying 2 create a restore point. if i try 2 update windows or create a system image it goes days not going anywhere.??
If system restore not working you can always try to do a repair operation with the disks that came with your machine. If you have no disks you are out of luck and will have to reload the machine with new software.
If concerned about losing data/files you can remove the hard drive and install it as secondary on another working machine, download the files you want to a usb stick and reload the hard drive and re install the files you previously saved. Good luck
Mar 10, 2015 | eMachines ET1161-05 PC Desktop
Whilst starting lap top it stopped halfway through and left blackscreen with only cursor
You may have to restore your machine to Factory Settings. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive.
Then, you could try to do a Factory Restore on the computer, and if that works, copy your personal files back to your newly restored computer. See...
Jul 27, 2014 | Sony VAIO Computers & Internet
Hi , I just copied my hard drives to my new Passport Essentials SE using the WD Smartware software, I do not like I have to manually switch between my two internal hard drives to back up so I would like to...
As far as I remember WD just copies the software into the PassPort drives and you don't have to install anything you can just run the software from the drive. If that is still the case then first take a backup of that software (basically copy that software folder to some place in your internal drives) then format the drive (make sure you select NTFS as the file system for the drive when formatting).
Formatting will erase all the files in the drive so make sure you have backup of you personal files also.
Formatting also resets the drive back to factory setting (if you want the WD software back then just copy it from the backup to the PassPort drive).
Sep 06, 2011 | Western Digital WD Passport 250GB Portable...
My toshiba 1 tb hard drive all ofa suddn says that i need to format it and i have alot for stuff on it that i need how can i make it work again
Don't be panic. you can try some data recovery software. You can see
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Aug 28, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
My gateway laptop 4540gz cant find opp system
Operating system is the main program of the computer. It can b easily detected by your computer in boot up. So if the computer doesn't detect it, this are the steps you can try :
  1. First try to run system restore if you have one.
  2. If you don't have system restore disk, or back up disk, you can remove your hardisk from your laptop and try to connect it to other computer as an external hard drive. in that, you can copy important files and back up it in other computer if it is not also deleted.
  3. Then if you have back up your file or not, you must format your hard disk. return your hard disk to your laptop and format it.
If you don't know how to format just ask again here.
Feb 28, 2010 | Gateway 4540GZ Notebook
Need to transfer copied files to x301 after full restore
create a new folder in your hard-disk and first try to copy 1-2 files from the external hard-drive to the new folder (copy any data/work/images you have stored/created not any files of windows folder or root of c: drive)
if the above copy works then copy back all except the c: root and these folders - Windows folder, Document & settings, Program Files
May 30, 2009 | Lenovo ThinkPad X301 2776 Notebook
Data Recovery
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Nov 10, 2008 | Iomega HDD External Desktop (32660) 80 GB...
Hard drive recovery, hard drive is damaged
My brother's MacBook Pro had a similar issue a few years ago. In his case the issue started when he attempted to update the OS to the then most recent version. The update failed with an error saying that the Hard Disk needed to be repaired and instructing him to restart in Recovery Mode and repair the disk. When he did this the "Repair Disk" option was grayed out as you said. From my searches then it seems that the drive entered a "write-locked" state that prevented it from mounting. I was able to recover his files and restore the computer to working order. You will need another computer that has enough free space to hold the files you want to save, and the appropriate cable to connect the misbehaving computer to the working computer.
This procedure requires booting in Recovery Mode and erasing the non-working computer's hard drive, reformatting it, and restoring the system.
1. Turn on the working computer.
2. Make sure the non-working computer is turned off, connect the two computers using the appropriate cable (FireWire or Thunderbolt)
3. Turn on the non-working computer holding down the "T" key to enter Target Disk Mode. (This worked in the case of my brother's computer, but I can't guarantee that this will work in your case, but if you could get it into Verbose mode I would think you should be able to get into Target Disk Mode.)
4. The non-working computer's hard drive icon should appear on the working computer's desktop. You may get a message that you cannot alter the contents of the external drive (non-working computer), but you will be able to transfer files from the non-working machine to the working one.
NOTE: You could connect a dedicated external drive to the working computer and transfer files from the non-working computer to the external drive using the working computer as an intermediary of sorts.
5. Transfer the files you wish to save. We will be erasing the non-working computer's drive and restoring the system so be certain you have what you need transferred before you get to that step.
6. Once you have saved all of the files you need to save, you can eject the non-working computer's hard drive, and turn off the non-working computer.
7. If possible connect the computer to the internet, if not possible you can use wi-fi, but it may take longer.
8. Connect the non-working computer to the drive with your most recent backup.
8. Turn on the non-working computer holding down the "Command+R" keys.
9. Once the computer is in Recovery Mode choose the option to Restore From Backup
10. You will then be asked to choose which backup to use, and then click "Restore". Once this process is done you should be able to boot the system. You can then transfer the files you saved to the other computer or external hard drive back to the restored computer.
Mac Data Recovery Recover Lost Data with Ease
Jun 18, 2008 | Western Digital Caviar WD2500BB 250 GB...
E Machines
In this situation I would start by testing the hard drive then the RAM.
For the hard drive find out the manufacturers name and download their test program.
For the RAM test I have used a free program call memtest86 with very good results.
If the problem is the hard drive, you may be able to install a hard drive of the same size and using an imaging program copy the old drive to the new drive. Re-run the recovery program. My suspicions are that the old drive has developed bad clusters near the beginning where the operating system is and some of the files have become corrupt.
If the RAM fails the test replace the RAM and try again.
Apr 27, 2008 | Dell PowerEdge 2500 Server
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
