If your HTC HD2 is frozen and a soft reset doesn't work, this guide shows how to restore your handset to its factory settings with a hard reset
There are two ways you can perform a hard reset on your HTC HD2. The first is best if your phone is still operational. If it has crashed and you can't get a response from it, you're better to try option two. Performing a factory reset via the settingsmenu
On the Home screen's Settings tab, select Menu - All Settings - System - Clear Storage
Enter 1234 and tap Yes to confirm
Performing a factory reset using phone buttons
If your phone has crashed and won't respond, you'll have to perform a battery pull to power the phone off. Simply take off the back cover and remove the battery. Otherwise, just turn your HTC HD2 off using the power button.
With your phone powered off, press and hold the volume up and volume down buttons
While holding the volume buttons, press the power button and then release it
When you see a warning message on screen, release the volume up and volume down buttons
Press the volume up button to perform the reset when prompted, or press any other button to cancel the reset
Performing a factory reset using hardware buttons If you can't turn HTC One V on or access settings, you can still perform a factory reset by using the hardware buttons on HTC One V. 1. Press and hold the VOLUME DOWN button, and then press and hold the POWER button. 2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons. 3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button. [img title="unlock HTC ONE V hard reset forgotten password" alt="HTC ONE V hard reset" src="http://www.hard-reset.com/images/htc_one_v_hard_reset.jpg" height="350" width="180"> will remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset. Performing a factory reset from settings 1. Slide the Notifications panel open, and then tap Settings. 2. Tap Storage > Factory data reset. 3. Tap Reset phone, and then tap Erase everything.Performing a factory reset via settings The most convenient way to do a factory reset is via the settings. 1. From the Home screen, press MENU, and then tap Settings. 2. Tap SD & phone storage > Factory data reset. 3. Tap Reset phone, and then tap Erase everything.
HTC One V not responding? If HTC One V frozen and does not respond when you touch the screen or press the buttons, you can still restart it by press and hold the POWER button for at least 10 seconds, and then release it. HTC One V then restarts.
1. From the main home screen, tap menu 2. Select Settings, then Privacy 3. Select Factory data reset 4. Select Reset phone 5. Enter the password if required, then confirm by selecting Erase everything Factory Reset on Menu Setting Hope this helps, If the phone is frozen, hard reset it through buttons
1. Turn the power off. If the phone is frozen, pull the battery out and inplace it back again 2. Hold the Home and Volume Down button 3. Press and hold the Power button until the phone turns on 4. Follow the on-screen instructions to hard reset the phone handset
The LG Optimus One P500 will then reboot to its factory fresh default state settings.
Please follow the following procedure to hard reset ( factory reset ) the phone . If that does not help Please take it to a authorized service center .
Turn the power off. If your HTC Inspire 4G is frozen, pull the battery out and reinsert it
Hold the Volume Down button
Press and hold the Power button until the device turns on
You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
Select Clear Storage by pressing the Volume Down button
Press and release the Power button
Now simply confirm your decision: Volume Up for YES and Volume Downfor NO
All data including third-party applications will be deleted from the HTC Inspire 4G. Once the wipe is complete, the phone will reboot to its factory fresh state.
Remove the battery from your phone for about 1 minute and then re-insert it. That should reboot your device. If it still doesn't work, try doing a factory reset.
Sony Ericsson . Once the wipe is complete, the phone will
First, try this:
Tap Settings, then Privacy
Tap Factory data reset
Tap Reset phone
Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
Turn the power off. If your Sony Ericsson Xperia is frozen, pull the battery out and reinsert it
Hold the Left and right buttons located beneath the display
Follow the on-screen instructions to hard reset your Xperia X10
