Case and switch
How can you set the action that occurs when nothing else is matched?
1998 blazer 4x4 cannot get it into 4 wheel high when i pus the button th4x4 and low range lights both blink and it goes back to 2 wheel high
Transfer Case Shift Control Switch Indicator Flashes and Returns to Original Mode.
Circuit Description
This symptom usually occurs when a shift into or out of 4LOW will not occur. When the transfer case control module (TCCM) receives a request to shift into or out of 4LOW, the TCCM must see the following parameters before the shift routine can start:
The vehicle speed must be below 3 MPH.
The transmission must be in neutral.
If the TCCM does not see these conditions the shift control switch indicator lamp will flash for approximately 5 seconds and then return to the original gear.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
  1. This step tests the operation of the transfer case shift control switch to help determine if the system is operating properly.
  2. This step determines if the vehicle speed sensor reading is correct.
  3. This step determines if the park switch reading is correct.
Switch Indicator Lamp Flashes and Returns to Original Mode
Step
Action
Value(s)
Yes
No
Schematic Reference: Transfer Case Control Schematics
Important: The transfer case shift control module is not a class 2 device, and therefore a scan tool can not be utilized on this transfer case.
Did you perform A Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check
  1. Start the engine.
  2. Place the transmission into NEUTRAL.
  3. Set the park brake.
  4. Depress each of the shift control switch buttons.
Does the transfer case range change with the press of all of the shift control switch buttons?
Go to
Testing for Intermittent Conditions and Poor Connections
Go to Step 3
Use the scan tool in order to read the vehicle speed sensor on the transmission control Data Lists.
Is the vehicle speed within the specified range?
0 km/h (0 mph)
Go to Step 4
Go to
Powertrain On Board Diagnostic (OBD) System Check for the 4.3L engine
  1. Put the transmission in neutral.
  2. Observe the current state of the transmission on the scan tool in the transmission control Data 2 List.
Does the scan tool indicate the transmission is in Neutral?
Go to Step 5
Go to
5
Replace the transfer case shift control module. Refer to Transfer Case Shift Control Module Replacement .
Did you complete the replacement?
Go to Step 6
6
Operate the vehicle within the conditions for causing the symptom as specified in the supporting text.
Does the symptom re-occur?
Go to Step 2
System OK
Feb 12, 2015 | 1998 Chevrolet Blazer
It burns thru the glass trray and melts the wheeled tray holder...
There are two possible reasons for this to occur.
1.there was dirt on the turntable and that carbonized and got so hot that it melted the tray. That heat would've melted the plastic spider as well.
2.the microwave oven was turned on with nothing. or almost nothing, in it: the glass turntable is what is known as "a matching load". That means it is there as a safety precaution, protecting the magnetron, in case there's nothing in the microwave oven when it is energized. As such, the glass turntable can get hot enough to melt. That, in turn, will melt the plastic spider.
If either of those is the case, it is OK to buy a new spider & turntable.
Mar 10, 2011 | Microwave Ovens
The problem occur in my kyocera FS2020D switch envelop matches appear how can i handle it?
the problem occur in my kyocera FS2020D switch envelop matches appear how can i handle it?
Feb 24, 2011 | Kyocera FS2020D ECOSYS Monochrome Laser ...
My wireless connection , says "Limited or no conectivity" I have excellent signal strength. This occured when i plugged in a second lap top with cable. Now only port 2 works and wireless is restricted. I...
Usually this is caused because the security settings on the laptop or PC do not match what is setup on the wireless router. Login to the wireless router and look at what is setup for security, WPA, WPA_PSK, etc, also the passphrase, it is case sensitive. The setup on your laptop must match.
Jun 22, 2010 | D-Link DIR-655 Wireless Router
DISC ERROR OCCURING TIME AND AGAIN
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropylic alchool to clean up the cd lens manually. In case this don't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 09, 2010 | Sherwood VR-652 Theater System
Photo r340 no ink comming through new set of ink instaled ?????
Nothing at all ? Two possibilities : badly clog of nozzle, problem with head or board. Open case. Dismantle outlet pipe of head cleaning mech. Do Head cleaning procedure. Is there ink out from outlet? If no : badly clog, if yes : problem with head (lost electricity, short circuit, or board damage. Head cleaning is mechanical action, printing is electrical action.
Jul 15, 2009 | Epson Office Equipment & Supplies
I recently cant connect to any matches in gears 2, it finds teammates but then nothing. Ive waiting for at least 30 minutes and nothing happens. It just continuously searches for an opposing team and gets...
Can't help too much without knowing the type of router you have but, when the dashboard update occurred some xbox IPs were changed (last # in the sequence). Double check that this wasn't what happened, as it sounds like you previously did all the work for port forwarding. Check your network settings and compare it to your router settings.
May 16, 2009 | Microsoft Gears of War 2 for Xbox 360
Remote control settings
There's two options, depending on the brand of remote. The most common is that the reciever located in the fan ceiling canopy has the same switches. Check how they are set and match it on the remote. The other option is that the reciever matches the frequency of whatever the remote is set to. To set this you have to turn off the circuit, wait a minute or so, turn it back on. Then on the remote, hold down the "stop" button for a few seconds. It should be set. I'd check the receiver first though. I should mention also, that when they come from the factory, the switches are usually all in the OFF position (or possibly all in the ON position). Unless they were changed on installation (which may be the case if you have more than one remote controlled fan) they are probably set that way. Try that first.
Dec 24, 2008 | Fantasia Viper (110927) Ceiling
I need advice on how to take Ice-hockey action pics...
Pictures get blurred because of several reasons:
Low shutter speed - occurs in low lightning conditions.
Auto focus not focused - occurs when pressing the shutter button all the way without waiting for the auto focus ready signal (green box)
To speed up the shutter do the following:
In Camera menu-Quality- Set ISO 100 for outdoor, ISO 400 indoor.
To avert focus problems, set camera menu-Rec- Focus-Infinity, Rec-Quick shutter-On
Hope that helps.
Dec 28, 2007 | Casio Exilim EX-S500 Digital Camera
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
