Question about Pioneer SD-P6091K TV
Picture problem on my sd-p6091 projection tv
I recieved a SD-P6091 projection tv from a relative. I don't know how to describe the problem, but i will do my best. When the tv is turned on, the pic shrinks down into the middle third of the screen and bows a little bit. I've removed the front panel of the tv, and started fiddleing with stuff, just pressing on it a little. The whole panel on the left side, if pressed down a little will fix the picture untill the set is turned off. There is a transformer on that panel that clicks whenever I press on things and the screen gets back to normal. Also, if i pull lightly on a set of wires connected to a vertical panel on the board on the right side the screen will go normal again. Any ideas as to how to fix this problem? I really love this tv and can't really afford to get another big screen tv. can someone help me with this prob?
5 Suggested Answers
SOURCE: Pioneer SD-p5073-K Shuts off
it is the power supply board an know problem with pioneer. If you have any soldering experience you can remove the powersupply board and resolder the tracks and as many parts as you can. I had the same problem and not the power supply works great. You will soon have other problems like pic and sound going intermittant where you have to hit the tv to get it back on. more solder problems on video main board. best of luck
Posted on Dec 02, 2008
  • 4234 Answers
SOURCE: Pioneer SD-532HD5 - Picture Bowed on sides only on 1080I
The problem you are describing is known as a pincushoin problem. I'm a bit surprized that you only see it on the 1080i signal though. I've inquired at my Pioneer contact about this and will update this soon.
Stay tuned...
Dan
Posted on Jan 07, 2009
  • 15 Answers
SOURCE: Pioneer projection tv SD-582HD5
I had the same problem, try running the TV on Mute, if it is a bad solder joint the sound can vibrate the solder point and trip the relay, if the TV doesn't trip off with the sound on mute then it is probably the big power transformer's solder connection needs resoldered. sound vibration from those big pioneer speakers may loosen the solder joint over a period of time because the transformer is heavier and bulky and vibrates a lot.
Posted on Sep 13, 2009
  • 608 Answers
SOURCE: Pioneer SD-P6091 Projection TV - TV turns off by itself
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
No picture on my pioneer TV model SD-582hd5
The problem is on lamp try to replace it to get back the picture..
Feb 23, 2012 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer 52" projection TV, SD-533HDS,
It is likely that the CRT's (picture tubes or bulbs) are weak. It is a major job to change and all three should be changed to make the picture like new. However, it is not costwise to repair this old of a TV even if you can get the tubes. I estimate the cost of each tube is at least $200 each. I would call Pioneer and give them your model number and see if they are available. Only a trained technician should change the tubes because it requires a lot of time and setting up of the tubes and other things.
Jun 04, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
I CAN GET PROPER COLOR ON MY WS-55411 MODEL
Try to describe better, is picture 3d looking or what is your problem?
Make a comment here OR IF YOU RE-POST THE QUESTION MARK IT "attention SD TECH" AND I will assist you.
I know the model indicated very well.
SD TECH
Sep 06, 2010 | Mitsubishi WS-55411 55" Rear Projection...
Cannot use convergence on remote for Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-533HD5 53 in. Rear...
Ur convergence it dead.Must know how to solders.Tries these Websites.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit.
Dec 29, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Solutions?
Hope this helps
Jan 20, 2009 | Pioneer SD-P6091K TV
Stay tuned...
Dan
Jan 07, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer rear screen projection tv model #sd p6091-k when i push the standby button in on the front the little standby light glows red like it should but when i push the on button it should turn on and glow...
wait a minute you wanted me to pay you to tell me how to fix it... now you want me to tell you how i did it ...no thanks ...well for 9.99 a month ill tell you...no thanks
Nov 08, 2008 | Televison & Video
Pioneer projection TV vertical lines on screen
do you have full picture and did this set have any faults before this,possible image burn on crts.from previous horizontal fault.
Aug 17, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Help
Hi tedski have a tech look at your tv the problem is in the power supply or related circuit.good luck
Apr 26, 2007 | Pioneer SD-P50A3-K TV
Hd ready?
On any High Def TV, the reciever you need for this set, which does not have a HD receiver in it, is half the equation. Most HD channels have some HD content mixed with SD content on the same channel. SD content on HD signal from cable or satellite tends to be slightly blocky due to the native signal resolution and the resolution of HD (1080i/p or 720i/p).
Apr 30, 2007 | Akai PTH5498 54" Rear Projection...
Open Questions:
Televison & Video Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
