Question about Jensen MP5720XM
Volume knob the volume knob doesn't respond to well when turning volume up or down....remote works great....kinda hard to adjust volume with remote when your driving
I contacted Jensen and got a real soluton without paying you anything....and it didn't cost me one dime!!!!
Posted on Oct 05, 2008
How do i reset radio,what is the dx/xm,as/ps buttons for and my screen is blank but radio is on?
Posted on Jul 01, 2011
Why could my volume knob be stuck on max volume and not adjusting?
There is probably grease or dirt on the contacts inside the unit. Here's a video that shows you how to fix it:
http://www.youtube.com/watch?v=y4XF9PoidJQ
Hope this helps!
Aug 08, 2014 | Marantz SR-4320 Receiver
I have a DP video car stereo on my 1999 corolla. The volume knob suddenly didnt respond when I turned it but The press down function works, switching to bass, treble etc but I cant change those settings...
Sometimes multifunction controls fail because the button cannot be fully depressed. This is caused by shaft slippage inside the knob. The bottom of the shaft cavity in the knob can be shimmed to restore proper operation.
Oct 31, 2013 | Car Audio & Video
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
I have a CDC-X504MP. How do I get the fade control. I was in the truck when I bought it. Works great.
To get to the sound settings: Press and hold the Volume knob down. Press the "Seek" button until you see "Fad" on the display It will be between "Bal" and "LPF" Turn the volume knob to adjust
Jul 23, 2011 | Aiwa CDC-X504MP CD Player
Get a lot of static when try and turn volume down low.....in fact, sometimes it is hard to get sound when you turn the volume down....it is either full blast or silent.....lots of static like noise when...
This is an easy fix with a can of volume knob cleaner i think its called. You should be able to get it at radio shack. You just spray it into the volume knob and let it dry. The instructions are on the can.
Dec 03, 2009 | Tivoli Kloss Model One AM/FM Radio
Kenwood VR-6070: Broken volume knob; will IR sensor still work?
Looks like you have several faults?
First try to fix the remote:
http://www.instructables.com/id/Repair-your-remote-controls/
May 28, 2009 | Kenwood VR-6070 Receiver
Volume Knob does not adjust volume, but remote does.
Check your owners manual for "factory reset" this will reset the main micro-processor. Otherwise the encoder (volume pot) needs cleaning, soldering or replacement. It could also be a cracked circuit board (if it has recently been hit)
Jan 28, 2009 | Yamaha RX-V1000 Receiver
Volume knob quirks
if you know how to repair, then replace the volume control switch. it is a digital type/mechanical type of switch with silicone oil on it to prevent sudden turn of volume. if i were the repairman i can simply clean the contacts of the volume control and pour silicon oil again. but i really dont know in your area if they try to clean those.
May 03, 2008 | Yamaha RX-V1200 Receiver
Volume only goes up with faceplate open
Tienes un problema con los push buttons en la carita uno de ellos esta danado.Resetea tu estereo en la carita tiene un mini orificio con un boton para resetearlo intenta esto,suerte.
Apr 09, 2008 | Dual XDMR-7700 CD Player
Remote no longer works for volume control
Guys, I might have accidentally found the problem because the fix worked for me :). I have the RX-V995 and for the last 2+years or so, I had resorted to getting up and using the knob manually for volume control. System will show 'voluem up/down' in the display, but the knob didn't rotate. Same problem as yours.
I was getting ready to buy the service manual, find the knob motor which I thought was the main culprict and replace with a new one.
So I took out the top cover (just a few screws), the front face-plate (again just a few screws. The inner details were all visible. The volume knob circuit board was vertically placed. They were all covered in a good layer of dust. I got my Dyson vacuum cleaner and gently and carefully tried to **** up all the dust that had settled down. With soft front brushes, I agitated the dust I couldn't reach with dyson wand direclty, once dust were loose, dyson did a great job even with picking up those last dust pieces.
I couldn't succeed in taking apart the volume knob circuit board, as I was still awaiting for the service manual. I put all the covers back on and guess what? I used my remote and the knob was moving again. Responding very well, the knob made the full turn, when I was on the remote. It has been working perfectly for the last few days now.
I think I know what was happening. Teh top of the RX-V (and I am sure many Yamaha receivers) are very porous to allow for good heat dissipation. Over time, this allows a large amount of dust to collect on top of the parts. Most parts are electronic (not mechanical) and hence don't get affected by the dust. But the few mechanical parts might have adverse affect if dust settles down in between the rotating mechanisms.
My volume knob had stopped responding to remote command, very slowly. Initially it worked a little, missed a little, then it missed a lot and eventually it didn't rotate. That proves the theory to some extent that if the motor had completely failed, it would stop working from the get-go, not intermittently. Dust build-up provided intermittent contact between the parts and hence the response was intermittent.
The dyson vacuum did a great job in pulling out those fine dust from such parts and amazingly, things are looking very good at present. Honestly, I hadn't the slightest hope that vacuuming would fix the problem. I had vacuumed to make it easy for me to work on the parts :).
So, it doesn't hurt at all to just give it a try. Do open the covers so that you can reach closer to the real boards and parts.
Good luck and let us know!!!
cheers
PN from San Jose, CA
Apr 02, 2008 | Yamaha RX-V995 Receiver
Jensen MP5720XM Logo
612 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
