Question about Philips Magnavox 27MS343S 27" TV
Tv preset got some tvs when tore down a store and channels are preset 1-22 and all the rest are unavalible. didnt get remote bought a universal. i get some channels not all. buttons on the front are also disabled. now can i fix this. any help would be great. thanks
Uh...it's a stolen TV. that's the problem
Posted on Oct 07, 2008
I dont have the origional remote to my 27AF44 toshiba tv and i need to get to video/tv mode. i need to know how to do that or what is the universal remote code for this tv?
Ur tv have manual button that said VIDEO on the tv frame bazel.Push that VIDEO button u will get into Video 1 or 2 modes.Tries the tv manual buttons Channels up or down buttons like a few times,some Analogue tv models will let u to get into Video modes that ways.Not try website like Remotes.com to buy the tv original remote to used.This video modes funsctions are optional for tv useages for most or all of the tvs universal remotes.Tvs universal remotes are basicly only work for like for a power buttons on/off,channels up/down and volume up/down that it not more.
Aug 19, 2011 | Toshiba 27AF44 27" TV
I bought new universal remout control, we have tried to program this and it doesn't work. The frist problem is that it does not trun Off/ON, unable to change the channels (does not respond to any...
Return the tv universal remote where u bought it,u only used a universal remote when u must have too,because universal remotes are very strangely and react differencely each models of tvs u tries to programming it codes to it CPU chip.Norcent tvs are recent tvs in the market,have many spare original remote.Try website like Remotes.com to buy the tv original remote.
Jun 18, 2011 | Norcent Technologies LT-2723 Television
I have a TRUTECH TV that I bought with no remote, I have this Onkyo Chad remote and I need a number code for it to connect. Where is the number code???
This tv brand name TRUTECH tvs are specially made for Target Stores only merchindise,very limited brand name tvs,so there no universal codes exit for most of the tvs universal remotes out there.Try website like Remotes.com to buy the tv original remote.I bought one of this tv too from Target Stores.I did some research for this tv before,tvs was made for Target to trying to corner their own brand name for a little nit in the LCD tvs market.
Jun 17, 2011 | TruTech PLV16190 Television
I bought a element 32 inch tv from someone which didnt come with a remote, i went and bought a universal remote but i cont seem to get it to program
best bet is to get a direct tv remote and program that to the TV will work to put code in just switch the top switch over to TV hold select and mute till lights blink then press 9, 9, 1 lights will blink then channel up till the TV turns on if you miss the code same steps and channel down till you turn tv off
Oct 16, 2010 | Televison & Video
The tv that i have is a old model and does not have a hook up for a dvd player so i bought a s video cord but i don't have the remote for the tv to switch it to video so do i have to buy a converter
Maybe. What tv do you have? Does it have any buttons on the tv itself (other than the power button)? (Some older TVs reached the "change source feature" by scrolling up (past all channels) or down (below channel) with the channel up/down buttons. Unfortunately if you can't reset the channel skip list from the TV itself, this may not work - if that source is currently skipped.)
You may be able to get a replacement of the original remote or a universal remote that has a compatible source/input button code. (This may take a higher end universal remote.) Try remotes.com for a direct substitute remote (search on the tv model without including the brand).
If neither of these suggestions work out, then you should consider the RF modulator (video to RF converter) and setting the TV to channel 3 or 4, as needed.
I hope this helps.
(if you provide the model, I'll check my pile of manuals to see if there was a channel down/up option for changing the source. I can also check if remotes.com has a compatible remote for you.)
Sep 17, 2010 | Video Game Consoles & Games
H25W35DT Zenith Tv locked
can you open set ups or main menu using your universal remote? if yes try to find presets, or auto program. if no, then you really have to secure the oiginal remote.
May 31, 2008 | JVC AV-20220 TV
Diagram
ok i am typeing this right out of the book/
operating your tv: Once you have connected your tv to an anntenna or cable system,plugged the tv in, and put batteries in the remote, you are ready to use the tv. the first thing you should do is program your tv so it memorizes all of available analog& didgital channels.PROGRAMING YOUR TVS CHANNEL MEMORY: your tvs memory determines the channels thet are available using the "up ch down" buttons. if a channel is not in memory . you can tune to it with the numbeer buttons, but not with the up and down buttons . follow these steps to program your tvs memory:
1) Preset
press the MENU button twice to enter preset menu
To memorize all available analog and didgital channels
press the ch down button to highlight FULL SCAN then press VOL.+ to begin channel scaning, the channel scanning starting with analog channels then to didgital channels. after your tv finishes memorizing the channels, it will return to normal tv viewing. I hope that this fixes your problem thats just the main section on the programing part so if you need further info just ask!
May 21, 2008 | Disney DTD1363-CAR 13" TV/DVD
Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Jan 14, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Panasonic tv channel reset
Unplug your tv for 24 hours and replug. This should set your tv back to ch 3
good luck----------------tomtaso
Nov 11, 2007 | Televison & Video
Philips Magnavox 27MS343S 27" TV Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
