Question about Mitsubishi VS-45605 50" Rear Projection Television
How do i add the rest of the channels
I only can get channels 1 through 11 but nothing higher. How do I add in more channels? Thanks.
  • 927 Answers
Good Day;
It sounds like the TV is in the 'TV" mode (antenna), Go into menu and change signal setting to cable, and go through the auto scan. Good Luck, big IRISH.
Posted on Oct 28, 2008
I want to save the channels and turn my antenna to another direction and scan I loose the channels that I had can I save them some how?
The only way that I solve this issue is to write down the channels available from one direction on paper. Do the scan in the second direction. Return the antenna to the first direction and then manually add the rest of the channels. Depending on the TV, you either type in the channel number with the remote control or find a Add Channel option in the TV Channel sub-menu.
At least with my TV that doesn't have an Add Channel option in the Channel section, going to a digital channel with the remote doesn't store the channel number if the signal isn't strong enough for the tuner to resolve. Analog channels can be added when the signal is poor.
If you know all of the local channels in each direction from AntennaWeb ( http://www.antennaweb.org ) or TvFool
( http://www.tvfool.com ), you can use that documentation to add the channels at each antenna direction.
I hope this helps. If you use an electronic antenna rotor with a remote control, you may be able to program turning the antenna automatically when you change the channel. Check the documentation for the device to program this.
(Note: on my TV that adds channels only when I type in the channel number, recorded digital channels can disappear from the list if if I visit a channel with poor signal strength. Until the antenna is directed towards that transmitter, I can't add the channel back into the list.)
Nov 03, 2017 | Televison & Video
Tuning problem KV-21CL10
try to setting your tv in menu! and you can see the menu has air cable tv mode then select the ADD or ERASE mode! you select all channels to ADD mode! or you can auto search the program!
Oct 06, 2007 | Sony FD Trinitron WEGA KV-21CL10 21" TV
I would like to add higher channels
You should be able to go into the set up menu of the TV and do a channel scan. This will program all channels available for you.
Nov 29, 2015 | Insignia Televison & Video
Channel 2 gain is way higher and channel 4 is acting weird too
Send it down to Caracas, bro, I have fixed a bunch of these issues.
Seriously, now, I would check and lubricate your INSERT jacks at the back. These become corroded and let little or nothing pass. Peace.
Mar 21, 2014 | Ecler NUO5 5-Ch Mixer
I have an RCA F31672ET and it works perfectly on channels 51 to 98 but will not recognize the rest of the spectrum. I am on cable. Thanks.
Depends on how your cable provider is distributing the TV channels.
Channel 100 is the line into the Jumboband, and most providers don't distribute analog cable beyond channel 99 since it requires a different type of amplifier. They will generally use Digital Cable for higher number channels, which would require a converter box.
http://en.wikipedia.org/wiki/North_American_cable_television_frequencies
Who is your cable provider?
Apr 24, 2011 | RCA F31672ET TV
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
Belkin f5d8635-4 Router connection problems
Open the working pc open internet explorer and type 192.168.1.2 in the webaddress bar. this will open your belkin router settings page. On the left choose channel and ssid. If it asks for a password leave the password box empty and just click submit. The channel is the frequency your wireless network operates on. Some channels are more stable than others, but its just trial and error until you find the most stable for your area. Change your wireless channel to a different one (any channel is fine, personally 1,11 or 8 works best for me) and click apply changes. Hope this helps.
http://www.thinkbroadband.com/hardware/reviews/35-belkin-f5d7630-4a.
Apr 15, 2010 | Computers & Internet
Add subtitles samsung
Must tries mutilple channels,pushes the remote button CC 1,2,3 on every channels.Sometime channels don't have captioning.
Feb 24, 2010 | Samsung LE37B550A5 37 in. HD-Ready LCD TV
Can you add channels to the box-t like channel 5 or any good sport channels
yes you can go into manual scan check which codes are working for you /either the low code ie 366.00/ or the high one 745.00 select only the ones that you have signal on add 300 to the ones that you have signal on ie.366.300 the same on the higher ones you will receive more chnls unfortunatly you will not receive chnl5 doing this
Jan 26, 2010 | StarTech.com StarView SV211K 2-port KVM...
Want to record a television program on a channel higher than 16.
there must be a setup feature on the sony for channels that you get in your area?
Dec 18, 2009 | Sony SLV-D370P DVD Player/VCR
Open Questions:
See all Mitsubishi VS-45605 50" Rear Projection Television Questions
Mitsubishi VS-45605 50" Rear Projection Television Logo
251 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
