Question about Onkyo TX-DS575 Receiver
Will not power up but stand by light is powerd up
My onkyo tx-ds575 when pluged in the standby light is on but when you press power t turns on for a second and then turns off. i checked the fuse inside it is good. any other solutions?
  • 3 more comments
  • dududur Dec 02, 2008
    I have the exact same problem
  • kj9953 Jan 23, 2009
    Same problem. Just began today. Absolutely no idea how to solve this.
  • msmith1973 Jan 31, 2009
    worked fine friday night now wont stay on! turn it on shuts right off standby light just blinks.disconnected everything unplugged it let it sit overnight still not working. is this expensive to get fixed? maybe get a new one? it is about 9 years old with heavy use.
  • Anonymous May 08, 2009
    Got exactly the same problem :(
  • bmxrocksforl May 08, 2009
    same here
I have onkyo tx-ds575 and i need to conect it to my tv and have audio from a LCD flat panel.
Posted on Oct 25, 2008
  • miguel sandoval
    miguel sandoval Oct 25, 2008
    the LCD flat panels have "audio outputs" and the reciver none, where should i put the rc cables on the a/v reciver?
SOURCE:
How to you change an ac fuse in an onkyo ds575
Remove the top covers after the mains power was disconnected. Now check on the rear panel left corner for the fuses. Remove them and test using a multimeter in the continuity range. replace only with the correct rating and if this blows off the set has a short within and an isolation test will confirm the stage. check with the secondary voltage and check the outputs.
Oct 11, 2011 | Onkyo TX-DS575 Receiver
OWNERAS MANUAL TX DS575
You can get the manual on the link below.
http://www.intl.onkyo.com/downloads/manuals/pdf/tx-ds575x_manual_e.pdf
If that is not the right on then go to this link below and click where it says it is free
http://safemanuals.com/user-guide-instructions-owner-manual/ONKYO/TX-DS575-_E
Good Luck and please rate 4 thumbs up for the free answer
Sep 03, 2010 | Onkyo TX-DS575 Receiver
How do you reset the controls on an remote control for my onkyo tx-ds575
See the manual you can download on this site on page 39
1. Open the battery cover and remove the batteries.
2. While pressing and holding down the ON button and the
STNBY button, insert the batteries in the correct direction.
After inserting the batteries, release the buttons. The SEND/
LEARN indicator flashes slowly.
3. Press the ENT button.
The SEND/LEARN indicator lights up for about ten seconds,
then turns off. All programmed codes are erased and the button
memories return to the factory presets
Jun 30, 2010 | Onkyo TX-DS575 Receiver
Onkyo TX-Sr603 goes back to standby when press On button - help!
does not sound like the fuse.
its easy to check. unplug unit and remove the cowling / shroud of the unit. the internal fuse will look like a car fuse. the old round style about 1" long and 1/4" round.
sounds like a bigger problem. hope this helps.
Feb 19, 2010 | Onkyo TX-SR603X Receiver
Won't turn on.standby light on,fuse under cover is good.what next? onkyo tx-sr605
The only thing to test would be to disconnect all speaker wires at the receiver then turn it back on. If it still won't turn on, it's an internal power supply issue and will need service. If it turns on, post a comment and I can walk you thru further troubleshooting. Hope this helps
Dec 19, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-DS575 - intermittent audio
You have a problem that was inherent with all Onkyo receivers from this period. You need to contact Onkyo because the microprocessor needs to be replaced. Last I checked, its about $80 from onkyo.
This is NOT an isolated incident as darn near every Onkyo receiver model had this problem.
Good luck...
Rob
Nov 15, 2008 | Onkyo TX-DS575 Receiver
Onkyo TX-DS777 Problem
man I think i have the same problem....
i push the power button but immediatly the LED turns off. I cheked the fuse but thats not the problem. Please if you solve your problem let me know...
my e.mail adress soy_robertog01@hotmail.com
sorry if you dont undersatnd me in some parts..im not very good writting english haha sorry..
Jun 22, 2008 | Onkyo TX-DS777
Power works but receiver will not stay on
The outputs are blown and will require repair.
Dec 17, 2007 | Onkyo TX-DS575 Receiver
TX-DS575 reciever
Normally you hear a clicking sound coming from the inside when you turn on your amp. That's the sound of the magnetic circuit breaker (switch). If you tap your amp to turn it on, and if the amp gets turned on after you did it:), then I suppose the problem is on the relevant switch.
Jul 04, 2007 | Onkyo TX-DS575 Receiver
TX-DS575 reverts back to standby mode when turned on
You can find it out by yourself. I have the same device; therefore, I know that this device has a "test" function. Just unplug rear (surround) speakers at first, then test the rest of the speakers if the amp lets you do it. Hook up one of the rear speakers you regularly use to rear left or to rear right in order to test each rear channel. If one of them turns off the amp, you'll be able to understand which side feeding resistor does not work. However, if the amp goes to standby mode as soon as you hook up one of those speakers, you can alternatively invert the relevant rear speaker's input ports for a while. (+ to -, - to +) Don't forget that you have to hook up the other rear likewise. This will allow you to cheat your amp for a while, and let you test your channels without taking care of ohms.
Apr 20, 2007 | Onkyo TX-DS575 Receiver
Onkyo TX-DS575 Receiver Logo
741 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
