Question about Compaq Computers & Internet
I would like to see what i can do to upgrade my 1.1 usb to an 2.0 usb.
    Scholar:
  • 76 Answers
I am not sure of how you can do this without doing further research. Perhaps there is a jumper type adapter (USB hub) that will function on the male end as a USB 1.0 and the female end as a USB 2.0.
Right off hand, I know that you can purchase a USB 2.0 PCI card and install it on the back of the computer. This may not be as convenient, but it will enable you to run USB 2.0 devices.
Posted on Oct 05, 2008
My pc does not recoginze it any more. Power do not come when plucked but only flash once
1 have you change OS (operating system0 that is have you upgraded to Windows 7
2. Have you upgrade or changed anti virus software.
3. check the " Device manager" for corrupted USB ports.
4. make sure the contact for the male end of the USB are making contact to the female input of the USB port.
Sep 08, 2011 | Alesis IO/2 Portable 2-Channel/ 24-bit/96k...
Polycom is frozen while doing usb download. Has 3 red lights on. I have disconnected the battery with no result. It says SS2W USB Download ready to start download on the screed. Not responding after...
Just had a similar problem. Steps to fix:
0. use a better USB cable (that was my main issue)
1. start upgrade software
2. click 'upgrade'
3. if there's an error message like "can't connect" or something like this, wait a bit
3a. message window should open, with two options. Go with the second one - unplug USB cable, plug it again, and click "application upgrade"
4. lean back for a few minutes as the upgrade will follow.
Apr 19, 2011 | Office Equipment & Supplies
How do i transfer my avertar and saved game data onto a usb stick on a xbox360
Ensure your Xbox 360 is equipped to handle your new USB driver. Microsoft urges USB driver users to upgrade their consoles to a spring 2010 version or better. Use Xbox Live, a flash drive or a CD burner to perform the firmware upgrade.
1. Configure your USB device after your console's upgrade is completed. With the console on and connected with a working television, plug the USB driver into an available USB port on your Xbox 360.
2. Use your controller to choose "My Xbox" then "System settings." Then choose "Memory."
3. Pick "USB Storage Device" from the "Storage Devices" menu. Choose "Configure now" to ready your device for its first download. Follow the remaining prompts to configure the driver.
4. Save individual game files to the USB driver by accessing the "Memory" folder.
Hope this informnation will be helpful. Thank you for using FIXYA.
Apr 19, 2011 | Microsoft Xbox 360 Console
Stuck in safe mode
1. Remove the batteries. While holding the 2 button down, connect the USB cable. The remote will boot into normal mode.
2. Update the firmware. Update the configuration.
3. There could be a stuck button on the remote causing the symptom. Remove the batteries from the remote. Push in, and massage each button ensuring it is not stuck down. Replace the batteries and Update the firmware. Update the configuration.
4. Remove the batteries from the remote. Manually place the remote into `Safe Mode` by holding off and plug in the USB. Upgrade the firmware in the remote. Update the configuration.
FIRMWARE:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Jan 27, 2010 | Logitech Harmony 520 LCD Remote Control
Upgrade from SB 1.1 to USB 2.0
You'll have to add an expansion card. The motherboard indicated has PCI expansion slots. You can install a 4-port USB 2.0 expansion card. You can find them at local electronics retailers including Wal-Mart and Radioshack. Or, you can get online at places like www.newegg.com.
Bret
1-2-1ComputerServices
Oct 05, 2009 | ASUS PU-DLS Server (PU-DLS/LAN/PA/SC)...
UPGRADING USB 1.1 TO USB 2
I searched and found a 1/2 height PCI card with 2 USB ports, plus a internal connector for two more ports. My little NetVista will not hold a full-height PCI card. Get out your tin snips.
Works like a charm !
FYI: I disabled the BIOS USB support for the old ports, and plugged the old MB cable into the new PCI card. I now have two 2.0 ports on the front, and two 2.0 ports on the back. However, I lost the ability to boot from USB
Aug 31, 2008 | IBM NetVista X41 PC Desktop
Can some 1 help me with my fta
Loading Viewsat Ultra Via USB Flash Drive
1. Load File(s) to your USB Flash Drive. (eg.. PFTAUSW-070911U.PGM)
2. Take USB Flash Drive and insert it into Viewsat Ultra USB Port (behind right
side door flap)
3. Using remote Hit Menu. Then Go to System Information -> Receiver Upgrade
and Hit OK
4. Go to USB and Hit OK.
5. You will now see a list of all the files located on your USB Flash Drive. Find the
file you need to load. (eg. PFTAUSW-070911U.PGM) and select it and hit OK.
6. Your Receiver is now being upgraded.
7. It will come up showing you not to power off the unit.
8. Once it has finished the receiver will reboot and you have upgraded your Viewsat
Ultra.
Dec 28, 2007 | Computers & Internet
Can't upgrade the USB ports to Version 2.0
Hi cogilbert,
I had a similar problem with my PC which had older version 1 USB. I purchased a USB 2 PCI card with USB Hub, installed and problem solved. It really not a very expensive proposition. The card comes with the necessary software and drivers. It works great.
--RoadHawk
Nov 29, 2007 | IBM NetVista PC Desktop
Formatting the player memory
This process worked for my m25:
1. Download v1.11 firmware file from http://broadband.motorola.com/consumers/support/default.asp?supportSection=DigitalAudio
2. With USB cable disconnected, turn off the m25.
3. Press Power while holding Menu button until UPGRADE is shown.
4. Connect m25 via USB cable.
5. Run the firmware downloaded in step 1.
6. Disconnect the USB cable, and the m25 should start a normal.
Dec 24, 2005 | Motorola Mobility M25 MP3 Player
Computers & Internet Logo
22 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
