2004 Pontiac Grand Prix Logo
Posted on Oct 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuel gauge moves back and forth from full to empty
When the gas goes down to half a tank the needle on gauge moves back and forth so you don't know when tank is low
  • Anonymous Mar 31, 2014
    gas gauge is not working properly, all in the same hour it will go from empty to half full to full please help
  • Anonymous Apr 01, 2014
    i put half a tank of petrol and the needle has not move
Anonymous
Level 3:
  • Master 958 Answers
  • Posted on Oct 05, 2008
Anonymous
Master
Level 3:
Answers
958
Questions
11
Helped
445065
Points
2548
You have a bad sending unit inside your tank.
the resistance of the potentiometer inside is broke on the half tank part.
you have to replace it.
tnx 4 using fixya.
drcool
2answers
Have a problem with gas gauge on a 2004 Chevy SSR
fuel gage sender unit-undefined-undefined-0.jpg You could use two resistors, Two different ohms specs for full and empty. Place resistor between proper wire colors in diagram. Turn on the key, If gage reacts properly to full and empty resistors, then I think the problem is the sending unit in gas tank. If not, the problem could be almost anywhere, wiring circuit--pcm--instrument cluster. I did see trouble codes relating to fuel gage sending unit. I hesitate to get into that? good luck
3answers
Town and Country Van running out of gas and guage says half a tank what could be the problem?
If your fuel gauge is showing you in accurate readings this is normal to all vehicles that are not used to fill-up gas full regularly but sometimes the cause of the inacuracy is due to faulty float valve in the gas tank you need to replace it
2005 chevy uplander fuel tank
This problemis always caused by a defective fuel level sensor. The level sensor islocated of course in the gas tank. To change the level sensor you must remove the gas tank from the truck.
12helpful
6answers
Gas gauge stuck on empty
Adam, I like your solution, but this is easier:
1. Get a strong magnet
2. Use the magnet to move the needle into the top half of gage (don't take anything apart)
3. Test it by turning the car on.
2helpful
2004 Pontic Aztek gas gauge
probably you got a problem with your fuel gauge sender that goes inside in the fuel tank, that sender is only a coil that works together with a fuel lever,if you want to save some money buy it separate from the fuel pump.
1helpful
Gas guage moves back and forth from emty to full with gas in it
it sounds like the level sensor on the sender (fuel pick up pipe in the fuel tank) is getting stuck. the level sensor is a float that is attached to the sender, and you will need to remove the fuel tank to get to it.
hope this helps.
If you remove the sending unit in the gas tank, move it manually by hand as u saw done earlier, the gauge on the dash should also move. As long as the sending unit in the tank isn't 'stuck' at the half full level, the gauge should register empty to full as it moves. To be honest, I'm not sure if I would bother taking the sending unit out. 1st, u must be very careful not to blow yourself up when working on the gas tank (no sparks, etc), all u really need to do is fill up your car, see how many miles a tank of gas will go (carry a can of gas with u to see how many miles before u run out). If it's 350 miles, just set the trip gauge to zero every time u fill up, and get gas every 300 miles so u don't run out. If the sending unit moves freely, everything (wiring ) is connected properly, then it probably is the fuel gauge. good luck!
Top Pontiac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
