Question about SanDisk Sansa e260 MP3 Player
FM radio nt working
I have read all the suggestions, making sure setting is on USA, mute not on,down loaded drivers and my fm radio works with ear buds but will not work when attached to my INmotion speakers. Songs will play but no radio-- any suggestions--- seems weird it works with ear buds.
    Sergeant:
    Champion:
  • 281 Answers
Reinstall the mp3
Posted on Oct 13, 2008
Electrohome ean 0s700 radio wont play
Check the aerial connection. Some FM radio's will mute the static and only pick up strong signals. If it is an FM AM radio check the AM radio. If that is OK and the connection's are good you might have faulty Tuner circuit, which would need a trained technician to look at.
Dec 10, 2014 | Audio Players & Recorders
No Sound
It seems to be that the antenna is at fault. If you can take it apart, you should resolder the antenna.
Nov 10, 2007 | Aiwa CR-LD120 AM/FM Radio
Fm works, am does not
Check the antenna connection. A poor connection will often be good enough for FM but make AM reception so bad the the radios auto-gain circuits will mute the output unlike old AMs that would just produce loud static in poor signal conditions.
Apr 17, 2014 | Car Audio & Video
FM radio on Sansa Clip does not work
Have you muted the radio by mistake.If you have there will be a square symbol under the FM sign.Press the top of the ring.
Jun 04, 2010 | SanDisk Sansa Clip MP3 Player
I have the Delphi MyFi xm2go. It is not the newer version, SA10113. My problem...It is no longer transmitting to my car's FM radio. While it is sitting in the cradle in the car, it 's display shows that it...
Make sure that this is NOT a "Sure Connect" version that has a very weak FM transmitter, but the older original model with a bland box. Make sure no earphone is plugged-in, then go to the menu and set the FM frequency and set the FM output level and you should be all set..
Jan 20, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
No sound
If you are getting AM sound, but not FM, its because the headphones you are using are shielded for interference. This shielding is what is causing you not to be able to pickup FM, as the headphone wires are what is used as an FM antenna for the unit. Try using a CHEAPER set of headphones (Yes, I said cheaper). Cheaper headphones usually don't have the shielding. Usually these types of headphones have both wires for the headphones bound together as one wire.
Apr 01, 2009 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
No sound in FM radio
I had same problom and fixed by connecting an antenna to fm port
Jul 05, 2008 | JVC RX-6030V Receiver
No FM Radio Available
Hi fitx-64
Every where you site this model on the web, it has an inbuilt FM tuner... you not even having that option is really weird. I take it you have been through the manual to see what is what? :)
There is a firmware upgrade for it here you could do that first and see how you go.
If that does not fix it, I suggest you take it to a Sony service center. I am sure they willl exchange it for you.
regards
robotek
May 07, 2008 | Sony NWZ-B103FBLK MP3 Player
Philips SAA7130 TV Tuner
Driver you have is not compatible! try to down load a newest version!!! and look on sound manager if mute is off
Jan 21, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
How do I set the clock???!!!
Come on, someone, pleeeeease???
It's driving me crazy.
Nov 06, 2007 | Nakamichi CD-35z CD Changer
SanDisk Sansa e260 MP3 Player Logo
114 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
