Question about SMC2870W 802.11g/b Wireless Bridge
SMC2870W What is wrong when the wireless signal LED won't glow? What is the solutio? And what is wrong when there is an unsteady glow in its POWER LED? If this is fixable, how can I fix it?... Thanks in advance for the answer.
  • SMC Master
  • 6,487 Answers
Thos light only telling you that there's a problem with the router , because the wireless light should be always ON and the power should not be blinking, first thing to do is to reset the router by pressing the reset button for 30 seconds while the power is ON then unplug the power for 5 seconds.
If still the same problem the router can is bad already and better contact the manufacturer for further troublshooting and if its still under warranty have it replace with them.....
Hope that helps...........
Dont forget to rate the solution FIXYA thank you....
Posted on Oct 05, 2008
Is there an smc2870w driver for Mac os x?
You can access the SMC2870 without a driver, you just need to plug into the Ethernet port.
The default IP address is 192.168.2.25
and the manual is here.
SMC Networks SMC2870W User Manual Network Settings
Mar 07, 2015 | SMC2870W 802.11g/b Wireless Bridge
Is there a driver for the SMC2870W and Mac OS X?
This is a standard wireless ethernet bridge and does not need a special driver for MAC OS. It is a Plug n Play device and should self configure using TCP/IP . Here is the manual : http://www.manualslib.com/manual/154817/Smc-Networks-Smc2870w.html?page=20#manual. Your Mac should see the wireless signal. You could use Safari browser to configure if needed. Apparently the Configuration utility is for older windows systems up to XP. You may need some networking skills to do the configuration without it. Good luck.
Mar 07, 2015 | Office Equipment & Supplies
Wireless LAN button won't switch off.
Most Netgear routers have a recessed button on the back or bottom panel, marked "Reset" or "Restore Factory Settings". Because the button is recessed, you will require a thin tool to press it. Most people use a straightened paperclip.
  1. Power up the router, and wait for it to complete booting up, typically about one minute.
  2. Press the Reset or Restore Factory Settings button until the test or power led starts blinking. This takes about 20 seconds. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the reset was not successful, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the Reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Apr 17, 2013 | NetGear N600 Wireless Dual Band Router
M-audio Fast Track Pro Signal & Clip LED Always ON I have a M-audio Fast Track Pro, I'm facing this weird problem. As soon as I switch the M-audio Power on. I can see the Clip & Signal LED...
I have the same problem. Here is what it looks like. Any ideas? This happens without any inputs. I'm using a macbook air on yosemite but I have tried it with ealier macs and still.
Apr 26, 2012 | Computers & Internet
Am using Linksys WRT300N v1.1 wireless router but all LEd are glowing except power led. and i am unable to connect through wired ethernet ports and also wireless is not working.
Try to reset the configuration of your router from the reset button and try that you getting the console with its default username and password.
Jun 18, 2011 | Linksys WRT300N Wireless Router
3 lights o right hand side of laptop what do they mean
The user manual will supply an in-depth explanation of the led-indicators, aswell as there are normally small icons assigned to each light, sometimes engraved in the plastics, normal lights to be active at average usage are the Power led indicator, will glow as long as device is turned on, the Wireless led indicator will glow when the wireless network module is active, the CPU led indicator will flash occasionally when system is idle, and rapidly when system is active under load, and the Battery led indicator will be active when device is running on battery power. When device goes into sleep or hibernate mode the sleep led indicator might continuously glow or slowly switch on & off varying between systems.
May 27, 2010 | Dell Inspiron 6400 Notebook
I have an older RCA home theater proformer amp has a model # of PA4500 I cannot get any remote to program to use it, it has no volume dials and you cannot control the volume without a remote and we have...
The PA-4500-M does not have a wireless remote control. The amp turns on when there is an audio signal present at one of the inputs. The power button on the front is the master power, when the amp is ready the front LED will continuously glow RED, when the audio signal is sensed, the LED will glow GREEN. The audio signals must be variable otherwise you cannot control the volume.
Jan 19, 2010 | RCA Audio Players & Recorders
I need help setting up the SMC2870W to my gaming system...
You need to run the software provided with the unit. Connect the unit using the provided "crossover" network cable to a PC, this is wired slightly different to a standard network cable so make sure you have the right one - there are many sites that will explain crossover cables and give wiring diagrams.
Go through the setup program and choose the option to use the device as a bridge.
Jan 16, 2009 | SMC2870W 802.11g/b Wireless Bridge
Motherboard not starting!
try to set the jumper setting of the cmos battery in *********** board.you set the jumper setting 1 and 2 with in 3 mins.then try to set back the original setting the jumper seting in 2 and 3.
kira_ryuk99@yahoo.com
Jan 11, 2009 | ASUS K8V-MX Motherboard
Pc will not power on .Press main power button on the front of the server,all fans work and front Disk LED glows yellow. Power LED at rear glows green but LED on the front(light bulb symbol) not lit....
Open the case and check the connection between the case power button and the motherboard. unplug that connection and short out the pins on the mb. The computer should start up. If it doesn't, there is something wrong with the mobo. If it does, there is something wrong with the switch, or the connector wasn't tight.
Sep 06, 2008 | Compaq Computers & Internet
SMC2870W 802.11g/b Wireless Bridge Logo
242 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
