Question about Samsung SGH-Z510 Cellular Phone
Connect to pc
I use to able to connect phone to pc but now it will not connect when i plug phone into computer press connect still no connection
  • emilyplunket Oct 05, 2008
    thanks but i dont know how to update the usb driver i dont have internet access on my phone
    Brigadier General:
  • 7,752 Answers
Try updating the usb driver on the phone
Posted on Oct 05, 2008
Activating android phone screen from computer without touching the phone
use ur second phone and connect it to ur computer with the android logo.
REMEMBER where the CONNECT button is on ur NEW PHONe.
Disconnect.
Connect ur phone with the cracked screen.
When u plug it in a beep roughly memorize the touch moments u made on ur NEW WORKING touche screen android phone.
make the same motions.
see if the touch sensitivity still works
cross ur fingers hope it connects.
(Alternatively if that fails) take out the SD CARD from ur old phone. put it into ur new phone. use it to upload ur old files to ur computer.
yw
Mar 16, 2014 | Cell Phones
Connection for cellph to laptop
Music, movies, photos and more can be stored on the micro Secure Digital memory card on your Samsung Galaxy S phone.
To get all those goodies on the microsSD card you need to transfer them from your computer. Connecting your Galaxy S to your computer is done with the USB cable that was included with the phone and doubles as the charging cable when plugged into the outlet adapter that also came with the phone
Plug the large end of the micro USB cable into your computer and the small end into the USB port on the top of your Galaxy S phone.
Wait for your computer to recognize the phone.
Press the "Power" button on the top right side of your phone, briefly.
Unlock the phone by dragging the padlock icon to the top of the screen.
Drag the notification pane down by touching the top of the screen and dragging your finger to the bottom.
Touch the "USB Connected" notification and then press the "Mount" button.
Your phone's microSD card will appear to your computer like an external drive.
Click on the "Start" button on your computer and then click on "Computer."
Double-click the drive icon that corresponds to your Galaxy S phone.
This will open a folder that shows the contents of your phone's microSD card.
You can copy files to and from the folder like you would any other folder on your computer.
Click the "USB Device" icon in the task tray of your computer.
Click "Eject USB Device."
Wait until you're done transferring files before ejecting the phone from the computer.
Unlock your phone and drag down the notification area.
Tap the "USB Connected" notification and press "Disconnect."
You can now safely unplug your phone.
Bluetooth
http://www.samsung.com/global/microsite/galaxys/userguide/connectivity.html
Jun 22, 2013 | Acer eMachines 520-2890 Notebook
How do I connect my Matrix m1 mobile phone to the internet?
How to Use the Pantech Matrix for the Internet1.Press the "Menu" key on your Pantech Matrix and click "Settings.
2.Click "Connections" and highlight "Modem Link." Press the "OK" key. Turn the modem link settings to "Inactive." Press the "End" key to exit to the phone's standby screen. 3.Download and install ActiveSync on your computer if the operating system is Windows XP. If you have a later version, download and install Windows Mobile Device Center. Follow the on-screen prompts to properly set up the program. 4. Press the "Menu" key on the Matrix and click "Settings." Scroll down to "Connection" and press the "OK" key. Click "USB" to "PC." 5. Open ActiveSync or Windows Mobile Device Center. Click "Device Settings." Click "Internet Sharing" under the "Programs" tab of the program. 6.Select "USB" from the drop-down menu under "PC Connection." Select "AT&T" from the "Network Connection" drop-down menu. 7.Click "Connect" and connect the Matrix to the computer using a USB cable. A status message of "Connected" will appear in the program's window when the connection is established.
Jul 21, 2011 | Pantech Matrix Cell Phone
My htc desire will no longer sync with my PC it asks to insert disk into drive E
Your solution
Setting up HTC Sync to recognize your phone
After installing, set up HTC Sync to recognize your phone.
1. From the Home screen, press MENU, and then tap Settings > Accounts & sync.
2. On the Connect to PC screen on your phone, tap HTC Sync and then tap Done. Your phone attempts to find HTC Sync on your computer. Wait for a few seconds for the process to finish.
3. If your phone displays a message indicating that it's unable to find HTC Sync, try disconnecting and reconnecting the USB cable, and then repeat step 2.
4. When the Phone Connection Wizard is displayed on your computer, click Next.
Enter the name you want for your phone, and then click Finish.
Check the HTC Sync icon at the bottom-right side of your computer screen. If it appears green in color, that means your phone has successfully connected with your computer and HTC Sync recognizes your phone
If still no go try this .
Unplug the phone from the PC, restart both the phone and the PC. When the PC is done booting, plug your phone in and see if the autorun box pops up.
still if nogo try this .
you have to select disk drive (when plugged in via notification area) to be able to view the drive in windows and htc sync to use htc sync.
May 27, 2011 | HTC Desire Cell Phone
How to upload my picture from galaxy S to my computer
you can try connecting your phone to the PC through USB port, or if you have blue tooth support on your pc you can send your photo via blue tooth
May 05, 2011 | Computers & Internet
Ok you need this ?
Hello
If the phone and the computer both have bluetooth you could try to connect both with the bluetooth and if the connection sees each other then you might need to get another cable to tr to connect the computer and the phone.If it doesn't connect still then both devices are not compartible.Better still you could check it out with another phone so as to be sure or if your computer has a card reader and your phone has a memory card you could connect using your memory card.
HAVE A NICE DAY
Jun 27, 2010 | Acer Aspire One PC Notebook
How can i connect my samsung rant to my pc
Samsung does not offer a Data Kit software package, for the purpose of transferring data between the handset and a personal computer or for using a Sprint handset as a modem for a personal computer. However, depending on the model, there may be a media card slot located on the side of handset or in the battery compartment that allows information to be transferred to a personal computer with the use of a media card reader.
USB (Universal Serial Bus) is a type of plug-in connection that is used to connect devices, including some handsets, to desktop or laptop PC's. In a handset, USB is useful for quickly transferring files to and from phones, or for synchronizing information with a PC application. The only USB setting needed for data transfer is the Mass Storage Connect to PC setting.
To access the USB setting follow the steps below:
  1. From the standby screen, press the Menu/OK key
  2. Select Tools (0)
  3. Select Mass Storage (6)
  4. Select Connect to PC (1)
  5. Connect the data cable to the PC's USB port and the handset Charger/Accessories jack
Note: No USB driver is needed for Windows 98 or XP. Other operating systems may require a USB driver that can be downloaded from http://www.samsungwireless.com/ usbdownload
Jun 28, 2009 | Samsung Rant Cell Phone
Ku990 mobile to pc connection fail.
Yes janne_y_ang, I would have to tell you that from my own personal exprerience from using this phone has lead me to the conclusion that using BLUETHOOTH or the SOFTWARE CD are not the best or fastest ways to sync or transfer files from your computer to your phone or vise versa, so Im going to tell you the safest, fastest, and Easiest way to do it, using your USB ,but it may require you to change settings manually on your device first. Make sure you have a Memory card,
Choose settings for USB connections
1.Find "USB connection mo..."
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press USB connection mo....
  • 2.Select setting
  • Press Mass storage
  • Press OK.
  • 3.Exit
    Once you've done this and have your memory in your device, Open the MY COMPUTER folder in your computer and connect your device to your computer using the USB cord, a new Icon will appear containing the folders from your device's memory card, that way you will easily be able to transfer files back and forth without the NEED of any sofware Cd's or use slow Bluethoot.
    And Welcome to the Viewty Family! Enjoy...!
    Dec 07, 2008 | LG KU990 Viewty
    Unable to connect LG Viewty to PC via USB
  • 2.Select setting
  • Press OK.
  • 3.Exit
    Oct 23, 2008 | LG KU990 Viewty
    Phone not showing connected
    If you are a Verizon user...after connecting your phone to your PC with USB cable....go under Get It Now....select Muic & Tones....select Sync Music. You should connect. Then on your PC look under My Computer and you should see your phone as a drive. You can then copy music from your PC to this drive....this adds it to your cell.
    Mar 09, 2008 | Samsung SCH-u740 Cellular Phone
    Samsung SGH-Z510 Cellular Phone Logo
    221 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
