Question about Cameras
Nikon Coolpix S51 power cannot be on - Cameras
  • mexgopher23 Apr 24, 2009
    My camera was woking fine, then a prompt cam up saying my memory card was locked. So I un-locked my memory card and then the camera froze, where it would not shut off or close the lens. I then removed and replaced the battery, that made it able for me to turn the camera off. However, now it will not turn back on.
  • Anonymous May 15, 2009
    my probem is big im hamering my camera i now is no working
    tanksl
I have the same problem, so I called Nikon and they diagnosed that my grey-market memory card is not compatible with the camera, causing the black-out problem.
Posted on Oct 13, 2008
Nikon COOLPIX S51 Digital Camera Charge usb
The S51 does not charge via the USB. Connecting the camera to a computer merely drains the battery faster, since the camera has to expend power communicating with the computer (even if it's only to say it has nothing to say).
The S51 comes with an MH-62 charger, which plugs into a wall outlet. This allows you to charge one EN-EL8 battery while using another in the camera.
If you need a charger, you can order one from Nikon at
http://shop.nikonusa.com/store/nikonusa/en_US/pd/productID.213504000
or a third-party one for about half the price at
http://www.overstock.com/Electronics/Dolica-Nikon-MH62-Charger/3540124/product.html
Jan 03, 2011 | Nikon COOLPIX S51 Digital Camera
I cracked the screen of my nikon coolpix s51. Approx how much would it cost to replace it?
Hello
OK, the total cost for the replacement screen and the labour will be about $30 -$50.
Kind regards
Andrea
Sep 18, 2010 | Nikon COOLPIX S51 Digital Camera
My nikon coolpix s51 show message memory card is
For the message that show's on your camera here's is what your need to do. 1. Remove the memory card and check for the physical lock toggle.
2. Toggle the lock on and off.
3. Try blowing on the memory card and the memory card port so it will be cleaned somehow. here is the picture of the lock toggle of the SD memory card 919a7e0.png
Apr 13, 2010 | Nikon COOLPIX S51 Digital Camera
Coolpix s51
The camera should have come with an MH-62 battery charger. Put the battery into the charger and plug the charger into a wall outlet.
If you acquired your camera without a charger, you can order one from Nikon at http://www.nikonmall.com
Mar 01, 2010 | Nikon COOLPIX S51 Digital Camera
My Nikon COOLPIX S51 will not turn on.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 07, 2009 | Nikon COOLPIX S51 Digital Camera
How do I use my panaramic setting on my Nikon coolpix s51?
It's on page 40 of my S51 manual.
Basically, you select the direction, then take one pic. The camera displays a faint rendition of a portion of that frame so you can line up the next one, and so forth.
Oct 13, 2009 | Nikon Coolpix S51c Digital Camera
Cameras Logo
128 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
