Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv will not power up
The tv power light will come on and flash then stay solid and flash then go off without sound or picture
  • mommita Oct 05, 2008
    the tv tries three times then shuts down
  • RAYD1975 Oct 06, 2008
  • 1,030 Answers
The itc222 has a processor that shut it down for one or 20 different reasons. generally it is for high voltage safety reasons. the first thing as a technician i check are the horizontal tansistor and flyback. The first thing you can do is unplug for hour and then try again. This usally dosent work but it does elimate proscesor lockup. since the light comes on then you can elemante the main fuse. as a technician we have acess to computer equipment much like the one on cars that read error codes that tells me why the set shut down. does the set try three times then shut down.or just shutdown with one try.
Posted on Oct 05, 2008
I have a 42 " Phillips with no pic and no sound. I've replaced the Power Board and CT Board tht corrected the error blinking lights but still have the problem My Light stays solid green and I
Dear Mate
Please share us the Model # and Is that is the Plasma LCD or LED. And tell us Is your`s TV is stay on stand by or its green LED is stable.With No video and sound.
Dec 11, 2014 | Televison & Video
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
I have have a playstation 3 and when I hooked it up to my tv as I normally do there is no picture or sound. I then tried switching to my HDMI cable with the same results. Yes, I made sure I set my tv input...
Try powering on you unit press and hold the power button and the eject button for 30 sec unti the power light begins to flash thats going to reset the setting of your ps3, and if that does not work i would rec> sending it out so sony if its still under warranty or exchanging it from where u bought it.
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
It is very well possible for new lamp to be bad ?
Dec 09, 2008 | RCA HD50LPW164 50" Rear Projection HDTV
VIORE LCD TV/DVD won't turn on
19 in wont turn on. red light just solid , unplugged for a day still same , is there a reset button
Aug 18, 2008 | Televison & Video
Greeting inmiltown,
It sounds like your approaching the end of your lamp's life. Most projection televisions have internal lamp timers. These lamp timers usually give you time to buy a new bulb before it needs to be replaced.
I hope this helps.
Go Ahead. Use Us.
Apr 24, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
37 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
