Question about GE Microwave Ovens
We have the Advantium oven - Model SCB1000KBB 01 - Ser# ZL900080K - Purchased Mar07 - Manufactured Dec06. The interior light is generally on during normal operation. The light no longer comes on so we suspect its out. Where is it and how do I get to it?
  • GE Master
  • 9,098 Answers
Try this handy tutorial.
If this is not close enough to your oven to help, please reply back and let us suggest an alternative before you rate our solution.
If it works, then we're happy to have helped you with free advice and we'd appreciate your thoughtful rating of our answer.
Posted on Oct 07, 2008
Our Advantium 120 oven (model # SCA1001KSS 02, Manufactured June 2008)is not working. Began w/ time not coming on when cooking and just a little green microwave light shows while cooking.
Typical of a control microchip failure caused by a power surge. With a microwave as old as yours, it is safest to simply replace the entire oven rather than attempt to fix it, as older magnetrons are likely to fail.
May 05, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
Advantium 120 interior light won't go out
door switch is bad or out of adjustment I have a dometic that does this sometimes I just slam it a little harder
Jan 29, 2014 | GE Advantium 120 Convection/Microwave Oven
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 Interior light is out. How do I replace?
Here ya go... this fella did a good job and replaced the bulb for $4.95 vs $180.00 for the service call parts and labor. This is With pictures and how to steps down the page.
http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
Thanks for using FixYa.
Kelly
Apr 09, 2010 | GE Advantium 120 Convection/Microwave Oven
Model JVM1790SK 01 Where/how do you change the
This is a pretty bad design, sometimes you can just remove the upper grill and access the light assy. If the panel is to tight to work in to change the light,you get to take the whole micowave down and remove the outer wrapper to change the light bulb. This is also not a standard bulb (part #WB25X10019). You may be able to get one from Lowes or Home Depot actually Sears would be a better bet, otherwise you will need to order one from an appliance parts outlet. Hope this helps and sorry I didn't design the thing I just fix them.
Jan 24, 2010 | GE Advantium 120 Convection/Microwave Oven
INTERIOR LIGHT
You need to replace the internal light, that usually can fix the problem.
If replacing the bulb does not work, check the wiring to the light.
You can find the spare light and diagrams for your oven by entering model number here.
Feb 27, 2009 | General Electric Advantium 120 Microwave...
Button names wearing off
No, sorry. You'd have to order a new control panel assembly.
For model number SCA1001FSS001 it's part # WB07X10439 for $66.15.
You can find helpful exploded view diagrams and order it by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jan 28, 2009 | GE Advantium 120 Convection/Microwave Oven
Kenmore Elite Advantum 120 Model # 363-63694302 INTERIOR Light not working
I would suggest you look over this excellent tutorial.
If this is not close enough to your oven to help, please reply back.
Oct 05, 2008 | GE Advantium 120 Convection/Microwave Oven
Black Metal Tray for GE Advantium Oven
I just found one for $33.95
http://www.partstore.com/GetModel.aspx?MfgName=General+Electric&BrandName=General+Electric&ModelNumber=SCA1001FSS001&page=3
Aug 26, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
54 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
