Question about Eureka Vacuums
Need to replace belt on Eureka Powerline 12.0 vac. Screws look like Torx head or something on bottom of vac. Are those the screws that need to come out for changing? If so, what size do I need?
    Problem Solver:
  • 10 Answers
No, do not remove the torx head screws for a belt change. If there are any screws that need to be removed for the belt change, they will be phillips head. What is model # of vac??
Posted on Oct 24, 2008
Need to replace belt in eureka envirovac model 4470
You must remove the screws that hold the top cover onto get to the belt. Remove top cover then remove brush roll to install new belt. Replace belt at least twice per year for proper cleaning.
Oct 26, 2013 | Eureka High Filtration s Mighty Mite...
How do you replace the belt? Can't find anyplace to open the bottom to replace belt.
You don't actually have to turn the vacuum over for this. The two screws you need are on top, above the brush roller. It is the top cover that comes off instead of the bottom on this vac. You'll see everything once you lift it off.
Sep 24, 2010 | Eureka 2991AVZ Bagless Upright Cyclonic...
How do I replace the belt on my mom's Eureka Whirlwind litespeed 12 amp 15" ?
take the cover off from the bottom there should be clips or screws on the bottom.and work the old belt off and new one on
Aug 12, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
Eureka Fantom Thunder 12V/older model Need instructions on how to change belt and headlights.I could only find 1 screw on the bottom plate none on top plate. Thanks N J
there are two screws on the Fantom Thunder (It was not made by Eureka though) on the back of the unit just above the rear wheels. Remove these two screws and the top cover can be removed to get to the brushroll, belt and headlights. I believe the light bulbs in this unit are 12 Volt, not 110 volt.
Jul 18, 2010 | Vacuums
HOW DO i CHANGE THE BELT ON MY EUREKa powerline
turn the vaccum upside down and unscrew the screws in the bottom, pop that cover off and you should be able to remove the wheel assymblie. take the old belt out,slide knew one over the shaft and replace the cover and screws
Mar 25, 2010 | Eureka Powerline LiteSpeed 5845 Upright...
I have to check the belt in the ereka powerline plus. how do I do that?
Below I have listed a link that will open the owners manual that has step by step instructions on how to change the belt. Also I have listed links for the replacement belt you need. Eureka recommends replacing your belt at least every 12 months.Hope this helps you.
Eureka Powerline LiteSpeed Owner's manual
Eureka Powerline LiteSpeed Replacement Belts
Oct 29, 2009 | Eureka Powerline LiteSpeed 5845 Upright...
My brush is no longer working on my bissell healthy home vac. when i try to turn it on it makes a high pitched squealing sound. I'm pretty sure it needs a new belt but my husband is having trouble getting...
According to Bissel, they should be standard phillips screws. Nowever - things change.
This is a general guide from Bissel for belt change -
BELT CHANGE _ CLICK HERE
Check your model number on that site for exact details.
If the screws are Torx (star) or other security screws, tool bits are available from Screwfix -
SECURITY SCREW BITS
That fit standard loose-bit screwdrivers.
Hope that solves your problem.
Thank you.
Sep 22, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Vac is supposed to have auto height adjustment but it doesn't
If the brush isn't working then its maybe because the drive belt is broken. Locate cross head screws on top of the hood of the Eureka vac (two at the front usually and one below the duster or at the left hand side if looking at the vacuum from the front) Once the screws are undone check to see the drive belt is intact. If its not then replace with a new one and check at the same time that the roller brush is properly put in. If the drive belt is ok then check the brush roll - something may have jammed it if it isnt the belt. Dont forget to rate please.
Mar 20, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Looking to replace vac belt on eureka altima bagless upright
Hi Jim You should find the cross head screws on top of the hood - look below the duster and there should be a screw there, also another screw on the other side and two either side of the main floor head.
Mar 05, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka 4870 hose assembly replacement
Boy, it's been awhile since I took one of these hoses off, but I think at least one of those plastic hose guide things has to come off in order to remove the hose. Those screws that look like they cannot be removed are probably torx screws which need a T20 torx scredriver that you can get at any hardware store. That is the most common size torx screw that Eureka uses.
Here is a link to the owner's manual in case you need any diagrams for getting the clear tubes off:
http://www.eureka.com/service/manuals/70750.pdf
Hope this helps. :-)
Oct 17, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
Vacuums Logo
195 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
