Question about Bernina Artista 180
Bernina 180 Bobbin case spinning
I'll try to describe this as well as I can. There is a black arm at the top of the bobbin case that has a spring attached to it and a little piece protruding that is supposed to fit in a notched area that keeps the bobbin case from spinning. The black arm is loose and keeps allowing the bobbin case (that is what is I am calling the area that has the round center spool that holds the bobbin and it's case)
  • 202 Answers
Its called the bobbin stopper. Pop off your needle plate by pressing on the marked corner. In the back on the left you will see a small allen screw which must have come loose. Position the bobbin stopper in place and tighten that screw. If it already is tight, loosen it and reposition the bobbin stopper in the notch and tighten it back up.
Good luck.
Posted on Oct 18, 2008
The bobbin case went ajar while sewing blue jean fabric. I cant figure out to put it back in. Your help is very much appreciated :
Hi Debbie,
This type bobbin case can be a pain to get back in. On photo #1, at the top left you see a silver piece (circled in red) with a rectangular hole in it (circled in green)...take a flat head screw driver and insert it into the slot then twist to the right so the little bar/flange (circled in blue) will twist to the left past the bobbin well wall (marked in neon green). Photo #2 Now the bar/flange (marked in blue) should be on top of the bobbin well wall (marked in neon green). Now set the bobbin case in the bobbin well (marked in pink). Photo #3 as you set the black bobbin case in, kind of angle the flat part that is marked by the orange X so that it will begin to underneath the bar/flange with large orange circle. It won't go in all the way but just start it and then set the rest of the case down in the well. Now twist the entire black case to the right and the flat black are marked with the orange (X) should slide underneath the bar/flange marked with orange circle. The flat piece marked with a purple (X) should be sitting in the area marked with an (X) in the bobbin well. Now take your screwdriver and stick it in the rectangular box and twist it back so the silver piece marked in blue with go back over the edge of the black bobbin case to help hold it in. Hope you can understand my instructions and good luck!
Apr 11, 2016 | Singer Merritt 8734
How does the bobbin mechanism get assembled?
place the middle part (hook) into the machine and hold it there, take the r/h part and with the little notch facing up, overlay the part already in the machine. Two little arms flip over the ring to lock it in.
Last part l/h (bobbin case) - lift the little arm in the center, position the long beak up and into the notch and close the little arm ( it is spring loaded).
Oct 13, 2015 | Sewing Machines
Bobbin cover door is stuck on Bernina 930 Electronic, and won't open. Can you help me?
Tricky !!! I dont know why the door is stuck, but its possible that the spring-loaded plunger in the top of the bobbin door is stuck into the cover of the free-arm. If there is suficient gap between the top of the bobbin door and the free-arm cover, you could try sliding a thin piece of metal or a very small flat-bladed screwdriver between the two, in the dead-centre of the bobbin door - that's where the plunger is located. By gently manouvreing the screwdriver in, you might be able to release it - be careful, because it's possible that the retaining circlip has dropped-off the bottom, in which case, the plunger and its pressure spring might fly out when the bobbin door opens. If that doesn't work, you could try unscrewing and removing the stitch plate and, again, with a small flat-bladed screwdriver, see if you can release the free-arm cover catch that's next to the top-left-hand-side of the bobbin door, but that's a very risky approach, because the feed-dogs will be in the way and you dont want to mangle any of the hook/shuttle parts etc. You need to find out why the bobbin door is not seated properly - it may be that the bottom hinge that also carries the hook/shuttle retainer has come out of the left-hand hinge mount in the free-arm. Good Luck.
Nov 28, 2011 | Bernina Sewing Machines
I have a janome 1 step sewing machine and it keeps jaming. I have been sewing a thicker fabric recently with no problems, but now it jams after about 3 revolutions. I think something is wrong with the...
Do you have a manual for this machine? You need to follow the cleaning instructions and remove the needle plate, and clean under the bobbin holder. I've attached an image from my Janoma 6500 manual, I think yours has a top loading bobbin inside a magnetic bobbin case so this info should work for your model. There may be a little triangular shaped tool in your kit but any short flat blade screwdriver will remove the two setscrews. (always good idea to unscrew off the pressure foot and take out the needle first so you've got room to work).
PLEASE NOTE: If you've never pulled this bobbin area apart before, good idea to snap pics with your digital camera as you go to refer to and for reference next time!!
This uncovers the bobbin holder area, you'll see there is a black plastic holder which your bobbin goes into which has the tension device on the side and this then sits inside an outer metal casing which is the hook race. The bobbin holder is held there by a magnet underneath it and sits up against another little stopper. Look at the bobbin case and the stopper, there should be two red marks that must line up. Are they???
If the answer is no, then you need to remove the bobbin case, clean out any lint and fluff using your little brush that came with the machine, and you may also have pieces of thread caught in here too. Once clean, place the bobbin case back into the outer surround, under the other piece and lining up the two red marks. This is where photos are so helpful.
Now replace the needle plate and screws, pressure foot, pop in a new needle and thread everything up again.
If the thread continues to catch then you may have managed to damage the bobbin case; as they are plastic if they move out of position the needle can catch and burr or pierce them. If this has happened you could try to smooth out the burring with an emery board or similar. Or you may need to replace it if damaged badly. I've changed mine twice so far because I've pierced it with the needle several times.
I hope that this helps you out, good luck with your machine.tally_girl_3.jpg
Apr 13, 2011 | Sewing Machines
I was cleaning my bobbin case and the cutter and blade came off. Can you send me a picture so I can put it back together?
I don't think I have a picture but let me see if I can describe it to you.
The metal cutter has a black plastic piece. The blade fits in the black plastic with the longest point on top. The black plastic piece slides back onto the metal cutter, riding on the ridge. Fit the metal cutter back on the unit, being sure to align the "stubs" in the holes of the black pieces attached to the cog wheel. Make sure the "stub" of the black plastic piece with the blade fits in the parallel groove so that only the metal piece moves out and brings the thread to the blade when the cutter is activiated.
If you are still unable to fix, make a comment back and I'll go take pictures of my machine's cutter system.
Good luck.
Sep 03, 2009 | Husqvarna Viking 1
I have been using the zig zag stitch for appliques and all of a sudden the bottom thread which is a different color is showing on the top. I have rethreaded top and bottom threads, changed needles, cleaned...
it sounds like no bobbin thread tension. there should be some resistance when you pull on the bobbin thread. if there is none or too little you may have some lint or thread caught behind the bobbin case tension spring.
very carefully try and push the tip of a thin pin into the bobbin case tension spring and pick any accumulated thread or lint out.
if the bobbin case spring is clean, try tightening the bobbin tension a little at a time until your zig zag looks ok.
of-course all this is done after checking needle threading and needle for damage.
scott.
Jul 29, 2009 | Janome Sewing Machines
Bobbin case is disassembled. how do I put it back together?
It should be in your manual.... but if you don't have one, I'm gonna try this out. I don't know the official names, so bear with me.
There should be two plastic arm-lookin things that are turnable. Make sure these are turned outwards.
You should have three silver pieces. The one you need first is a half-moon looking thing with a knob comin out of the middle. (it also has some holes in it)
If you turn the big knob on the right hand side, there should be a moving piece on the inside of the bobbin case.
The half moon needs to fit in with that piece. Don't force anything cause we don't want the machine to break. >< The knob thing needs to be facing the outside, otherwise it's not gonna go in at all.
Once you get the half-moon thing in there, you have two more left. There's a big circle. WOO! CIRCLES! ANYWHO, The big silvery circle.. it has a knotch in it, and a little pokey-outie thing comin' out of it.
It needs to be positioned so that the knotch (on the inside of the circle) is up and the pokey-outie piece (on the outer side of the circle) is on the bottom. On your machine, there should be a place where the pokey-outie piece would fit perfectly into a little hole-type-thing. Put it in. :O
Now it's time to move those little black plastic arms towards the center. On your circle, there should be little grooves that they fit right on top of. ^_^
The only silver piece left should be the actual bobbin case deal. This should be a smaller circle with a movable arm and a silver thing pokin' out of it. (I told you, I'm bad at names!) Before you put this guy in, we need to have your plastic bobbin threaded. (I'm assuming this has already been done, correct me if I'm wrong.... they also have pre-threaded bobbins for sale, but hey, whatever works.)
Your bobbin needs to fit inside this last piece. (my first bobbin didn't, and I freaked out and ran to my dad... LOL) You need to make sure there is a trail of thread coming out of your bobbin that's about two to three inches long. Place your bobbin in the silver guy and there /should/ be a little niche where you can play with the thread and pull it through the silver guy's parts. (Your thread may break, don't worry, just try again)
When you move the thread around, it should come out where the little arm that sticks out is. Keep the 2-3 inch trail goin' on, you'll need it. Remember that first half-moon silver guy? Well, we're gonna stick our little assembly onto his pokey-outie piece.
The silver arm-thing on our assembly needs to go into the knotch that's in our circle, and push in so it clicks. (Sometimes mine clicks twice...) Make sure you have that trail of thread, and go ahead and flip the white plastic up, because you're DONE assembling it.
I'm going to assume you have your top thread in already (again, correct me if I'm wrong..) make sure that your top thread is through the hole in the needle, otherwise we're thoroughly screwed. Pull that thread until you have another 2-3 inch tail, and twist the big white knob on the right side of your machine (same one as before...) TOWARDS you. KEEP HOLDING your top thread, otherwise it'll disappear into the abyss that is your bobbin assembly.
When you turn the knob towards you, your needle should dip down into the abyss and come back up- with your bottom thread! HUZZAH! it SHOULD be a loop around your top thread. (I'd use contrasting colors for practice.. so you know what it'll look like)
The manual says to "grab the bottom thread" but seriously, I can't get me fingers down in there, so I just slide some scissors under the foot and between the two sides of the loop, and just slide 'em left. usually works just fine. Unless my tail for the bottom thread is too short, cause then it'll be hard to grab. You should be good to go!
I know this is pic heavy and kind of long, but I like to provide as much info as possible! Let me know if it helped!!
Jul 19, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bobbin compartment trouble
Put the needle in the up position. Tilt the machine back with one hand and lay the hook in its position on what is called the hookrace. The little ledge inside the the circle opposite the other part that moves. Then take the outer ring and lay that in over top of it. There is a small pin on the bottom that fits into a notch. The two small nubs should be on the outside, then click the two black knobs over those. Put the bobbin in the case and the thread through the notch up under the tension spring on the case. Looking at the back of the case, pull the thread and in most machines the bobbin should turn clock-wise. Now snap it onto the post.
Your good to go.
Good luck.
Jul 31, 2008 | Brother XL-5130 Mechanical Sewing Machine
Bobbin casing for elna 8000
There is one small metal piece 3/4 inch long and shaped like the letter "T" that fits under the right hand needle plate snap one screw. Attach to underneath square nut and can be seen sticking out from the top holding the bobbincase in place after the top plate is replaced and everything is back together. If this is not it, a picture would help as I have repair 100's of Elna 5000 to 9000's.
SewTech
Apr 16, 2008 | Sewing Machines
Kemore sewing machine
Practicly impossible to "describe" how to do it, you need to be shown, other added problem is there are numerous different types of bobbins etc. Unless you can get someone to show you the next best option is to get hold of a copy of a user manual for your machine. Best of luck
Mar 25, 2008 | Sewing Machines
Sewing Machines Logo
374 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
