My mitsubishi tv ws-65511
The main board did not get wet.but if thats it what could that cost to have someone fix? model #ws-65511
    Master:
  • 479 Answers
If the main board did not get wet then its a normal power shorting in the power cord wire coming from the tv and going in to the electric outlet that will be even more cheaper to get repaired.any local technician can check the power cord wire of the tv and replace it.it will not cost you more then $30.
just call the technician and get it replaced nothing to worry.
keep me updated.
Posted on Oct 05, 2008
Tip
Bypass Mitsubishi WS-65511 Front Lock
Bypass Mitsubishi WS-65511 Front Button Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65511 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65511 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
________________________________________
Mitsubishi WS-65511 Manual Download
Reset Mitsubishi WS-65511 VChip Password
on May 03, 2010 | Televison & Video
The picture on my Mitsubishi WS-65511 TV suddenly went blurry (looks like a 3D movie without the glasses). Is there a menu option that I can use to fix it myself?
No,tv have a problems known as a convergence problems,it is dead.This problems it is the tv board that call the convergence board it is dead.This convergence board must require to be replace 2 STK convergence ICS and some or all of it resistors too on the convergence board too.To fixed the tv convergence board to solved the tv convergence picture.The shop,will cost u like $300-350 for parts and labors.
Apr 19, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi WS-65511 has flashing timer light but will not turn on.
I used to have a WS55909 and had this problem. The light is supposed to blink for one minute while the DM (digital module) boots up after a power loss. If the light continues to blink indefinitely, there is a problem with that board. The DM power supplies are known to have faulty capacitors on these models and will need to be replaced. If I remember correctly, there are (7) 1000uf 25v capacitors and they should be desoldered from the board and replaced with 35v ones. Note that my TV model already had 35v caps but changing them solved the problem: electrolytic capacitors have a much shorter life than other components.
The DM is on the left side and is where ANT-DTV and the IR repeaters plug in. The power supply is the board above the main DM board inside the DM case.
If this sounds too technical for you, get a new TV because a repair guy will charge you more than the TV is worth. In other words you could get a (30-46") LCD TV for the same price.
Oct 21, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tip
Bypass or Reset Mitsubishi WS-65511 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65511 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
Tip
Download Mitsubishi WS-65511 HDTV Manual
Have you misplaced your Mitsubishi WS-65511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
My Mitsubishi WS-65511 won't turn on.
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Feb 22, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Tip
I hope that helps.
on May 03, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tip
I hope that helps.
Tip
I hope that helps.
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
