Insignia Pilot MP3 Player Logo
Posted on Oct 04, 2008
Bluetooth code I'm trying to pair this device but I don't have the code that its asking me for. Please help.
  • jazzypr2003 Oct 04, 2008
  • Anonymous Nov 21, 2008
    whats the bluetooth code for the insignia pilot 4gb mp3 player
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 02, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
137
Points
Most bluetooth devices use a code of 0000
My JVC Ha-s20bt doesn't want to pair with my device.. any help would be greatly appreciated. Headset pics up in my Bluetooth list but when I click on it, it asks me to pair, I click yes and then it says...
1. Check that the power is turned off
power lamp off s20_dntxilxgecvgvp-undefined-undefined-0.png 2. erform one of the following operations depending on the connection status. When connecting for the first time
Hold down button for 3 seconds until the indicator flashes alternately in red and blue.
When there are 2 or more the BLUETOOTH devices to connect to
Hold down button for 5 seconds until the indicator flashes alternately in red and blue.
3. Turn on the Bluetooth function of the BLUETOOTH device.
4. Select "JVC HA-S20BT" from the device list.
5. The indicator flashes slowly in blue when a connection is completed.
Please note :
During the pairing process, the BLUETOOTH device may require input of a PIN code. In such a case, enter "0000" as the PIN code for the System. If connection (pairing) is not completed within 5 minutes after the indicator starts flashing, the System automatically turns itself off.
I got a Sharper Image Bluetooth speaker system and it didn't come with a manual, I can't figure out how to set anything, (radio stations, bluetooth pairing, clock etc) it asks for a code when pairing
easy put your phone or device on and the other device look for it in the scanning option and pair its normaly asks for a pin that is the pin they give you with the phone for the bluetooth option 00000 is standard
Whatis the bluetooth pin for samsung c6112
check the bluetooth in settings go into bluetooth .. turn on bluetooth and phone will scan for devices to pair with. The other device will show if it has bluetooth on and set to discoverable.
Under available devices on your mobile touch with finger it will try to pair and say boothtooth pairing request. Confirm passkey is {whatever number it generates} to pair with {whatever device it is pairing with } note what the number is and press ok. At the top of the screen is a note says visable to all nearby bluetooth devices . the box needs to be ticked and other device should have same pass code when it tries to pair. It will ask you to confirm code.
Jan 12, 2018 • Cell Phones
Trying to pair my bluetooth with my phone and it' asking for a pass code i don't have my manual so I don't know what the code is
when u connect ur phone bluetooth to any other device it need a pass code! you have to give that from ur phone manually and the other device should have to put the same code so now u use the headset option to connect to the bluetooth not the normal bluetooth conectivity !
Sep 16, 2011 • Cell Phones
2answers
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
2helpful
I cannot pair a Nokia 6700 with Samsung Galaxy s11 via Bluetooth. The Galaxy recognises the Nokia, but says problem with PIN nunber or Password. I don't know of any such PIN or Password. Cannot connect...
If you need the pairing code for Bluetooth to connect just pairing with the same code in each device
for example if your device asking for code just enter 1 in your device ( Samsung galaxy) and enter the same code (it means 1 for Nokia), the code will depend on you but the important the code must be same each other.
6helpful
How do you turn this device on and pair it with your phone?
to turn this device into pairing mode hold the power button down for 8 to 10 seconds,then a light should stay on.once you have put the bluetooth device into pairing mode you phone will find it and ask for a pin\pairing code.most bluetooth manufactures use a 4 digit pin\pairing code they are as follows ,0000,1234,9999,or 1111 and try them in that order one should work for you .Hope this helps
2helpful
2answers
How to connect to bluetooth (ant) device with lg rumor phone
Not sure if you have paired your bluetooth with your phone yet. Hold your bluetooth button down untell it flashes (usualy blue and red) continuously your phone should then find your bluetooth then it will ask for a code. Usualy the code is 0000. If not make sure your bluetooth is turned on:)
2helpful
3answers
Trying to connect motorola s9hd to the laptop
assuming you have bluetooth installed on your laptop,
1) you have to disable the bluetooth pairing of your s9 with another device that you may have paired with it earlier - like a mobile phone. disconnect previously paired devices first.
2) turn on the bluetooth feature on your pc and ask it to "search" for devices. assuming your s9 is on standby, your pc should be able to "locate" and pair with it assuming the s9 is within an arms length distance from the computer.
3) make sure that the s9 is completely charged to eliminate that power issues as well
Top Insignia Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
