Question about BenQ T904 19" LCD Monitor
Monitor's led shows but no screen
Hello, my 19 inch just died on me and when i go to press power it lights up on the led but nothing on the screen. When it first happend benq logo would come up and go very quickly. Since then i took it apart and looked at the internal parts and i couldnt see no physical wear or damage. So I couldnt find anything but when i put it back together the logo does not even show.
Now I need help because i do not know what the problem may be. I am thinking its the bel 3a fuse but would have no idea. Or it also could be one of the 6 transistors.
If anyone would please help me out it would be greatly apreciated.
Tyler
    Champion:
  • 293 Answers
Tyler,
Check if there any bulged on top of each capacitors ( caps look like tiny battery) and replaced those caps... If not sure, just replaced all the capacitors. Have fun!
Posted on Oct 10, 2008
Monitor wont turn on help
Hello there, first thing you should do is to check the power cable.You can do that by changing it with PC power supply cable .It is the same. If it turns to be OK then disconnect the VGA cable from monitor and then try to power monitor on.There should be an activity on front power LED. If the power LED is not showing any light at all, then do not go further the unit is not working .Else the power led should blink a couple of times then a window pop up scrolling on the lcd saying :" no video signal" so the unit is OK ..Hope this helps. Cheers.
Dec 05, 2013 | LG FLATRON L1919S-SF 19 inch LCD Monitor
I have a 19 inch samsung monitor. suddenly it went dark. Can it be repaired?
Please be more specific about your problem:
1. Is it black or just darker by lower brightness? 2. Is the power led turned on and what color is it showing?
Sep 14, 2011 | Samsung 19" TFT LCD Monitor...
The monitor HPL1940T refuses to on
Is there a LED light on any part of the screen after you power it on?
1) If there is, try replacing the VGA/DVI cable (cable from PC to monitor). If nothing shows up, it means there is a hardware defect and you will need to send it in for warranty or repair.
2) If there is no LED light to begin with, replace the power cable and try it again.
Still no light - repair/replace it. If LED appears - See Number 1)
Mar 03, 2011 | HP L1940T 19" LCD Monitor
Screen trys to show desktop, but quickly fades to
Since the power led button is on, the problem with your monitor is the that the picture board of your monitor has develop fault, that is why it tries to show your desktop and quickly fades away.
The picture board of your monitor is bad and will need to be replaced in other for it to display.
The best thing for you to do is to take your monitor to a local repairer or any service center within your vicinity to help with the replacement of your picture board because the fault is not something you can fix on your own in other not to complicate issues.
Take care.
May 04, 2010 | ViewSonic VX924 19" LCD Monitor
Hanns-g 19" HX191d monitor blank screen. Power led is intermittent flashing green. Does not show 'no signal' when powered up alone. Has this monitor died or is there a way to fix it?
This type of issues is caused by parts called capacitors that have failed and are keeping the power supply from starting up correctly. You can rebuild the power supply board by replacing the bad capacitors and this will bring the monitor back to full working order. Here is a link to information showing what parts need to be replaced with pictures and parts list.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_31&products_id=194
I hope this helps you.
BuddyMc
Oct 14, 2009 | Hannspree HANNS.G HX191D 19" LCD Monitor
Plugged in a new 23 inch LG LCD Monitor and cannot get picture
In additio to the fine help given by Mister.
If you have a DVI output on your computer get the cable for that and this will greatly increase the quality of your display.
Your graphics card should be able to autodetect a DVI monitor and suggest the best display type.
Sep 16, 2009 | Computers & Internet
Starlogic 19" flat panel screen won't show anything.
Have you made sure that all the cable connections are screwed in tight?
You could also remove the cable to make sure that none of the pins have become bent out of place.
Sep 11, 2009 | Computers & Internet
Mag lt982s no green light no power at all
try testing it in another outlet a known good outlet if it powers on then your outlets bad if it doesnt means a bad cord or bad monitor
Feb 10, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
LCD MONITOR
check the power chords
Sep 26, 2008 | Gateway FPD1975W 19" LCD Monitor
Screen lit up, but nothing displayed (black)
Hello Frank, I have the same problem with my monitor. I don?t have the answer yet to resolve the problem. if you want the first of us who find the resolution will advise the other. I sent an email to Xerox to get the info to remove the cover without breaking it. regards Sylvain
Sep 01, 2006 | Xerox XG-91D 19" LCD Monitor
BenQ T904 19" LCD Monitor Logo
320 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
