Question about GE DBSR453EBWW Electric Dryer
Dryer stopped heating, replaced coil. now drum not turning
  • 958 Answers
Have you replaced every wire socket that you un hook when you replaced the heating element? specially the door switch if it was removed.
this switch if not properly close will not run the dryer at all.
let me lnow what happen,
tnx 4 using fixya,
drcool
Posted on Oct 04, 2008
Dbsr463eg7ww no heat
First check to see that the exhaust venting line is clear (not full of lint) as well as the path in the dryer to the line. This is the most common cause of no heat.
Second set the knob to heat turn on dryer with the lights off and the door open but the "open door" switch so that it still rotates with the door open. Look at the back of the rotating drum for a orange/red glow behind the drum (the heater coils). If there is no glow the heater coils are probably broken.
As the dryers age, the amount of thermal cycles the heater elements go through until the point when the coil wire breaks. There usually two heater coils behind the rotating drum (one hotter than the other and when combined the hottest heat temperature setting. You will need to pop open the top where you see the belt that turns the drum. The belt is removed from the spring loaded tensioner pulley at the base of the dryer. Then you can lift the drum out to get to the heater coils. Since no heat, both should be broken and will require replacement.
Nov 05, 2013 | GE DWSR463EG Electric Dryer
Dcvh660ghbb dryer wont heat
Sep 05, 2013 | GE Dryers
No high heat in dryer
This type of dryer has 2 rows of elements. If one is out then you will not have high heat.
Basically to get into ge dryers your start by popping the top then removing the front. Then the drum comes out.
Dec 05, 2012 | GE Dryers
The Kenmore 110 87880800 gas dryers starts up, ignites the gas initially, then 15 min later the dryer stops heating but continues to turn the drum. If we let the dryer sit for 20 min and turn it back on,...
Your dryer is heated by gas and what is happening is,when the coils that open the gas valve work when they are cool but once the dryer is running and the gas valve coils get warm they wont work,this is pretty typical of a bad gas valve coil.Replacing the coils will fix that.To replace the gas valve coils,UNPLUG THE DRYER, use a putty knife and place in the seam between the main front panel and the small lower front panel AT the corners and depress the clip that holds small panel to main panel.On the right side of the base frame behind the small panel is the burner asm. the coils are held to the gas valve by a bracket remove that bracket and replace the coils, they are black round shaped and one has 2 wires and one has 3 wires the plugs pull off and can be push onto the new coils with just a small amount of pressure.
The part # for the coils is 279834 They can be purchased at your local appliance parts store or online at;
apdepot.com
searspartsdirect.com
repairclinic.com
appliancepartspros.com
assuredparts.com
I hope i have helped you to be able to repair your dryer,
Gene
Aug 07, 2011 | Dryers
Not generating heat and dosnt stop automatically
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101 ,..,
Apr 03, 2011 | GE Dryers
Dryer blowing cold air . No heat!
Check the "Bias thermostat" for continuity with a multimeter. IF it is bad, replace with this part.
Nov 29, 2010 | GE DBXR463EDWW Electric Dryer
Our gas dryer takes a long time to begin heating then it stops heating midway through the cycle. The drum continues to turn. We have had a slight smell of gas.
It sounds like the safty coils on top of the gas valve are not working properly. As the dryer heats up the coils expand creating an open curcuit in the coil. There is a repair kit to replace the coils. This should be done by a licenced gas fitter.
Dec 29, 2009 | Dryers
My whirlpool dryer stopped working today and will not put out any heat, do you know what might be the cause? Model # leq9858pwo
Short answer if the dryer drum still runs, but there is no heat: 90% it's one or both of the heating coils. 10% it's the control switch or relay.
If the dryer will still start and the drum will still turn, find instructions for how to test the heating coils. The test for the coils must be done with the dryer UNPLUGGED! It will involve taking a panel off the dryer.
Nov 24, 2009 | Whirlpool Dryers
Heating coils are not broken and will not turn of
check the capacitor next to the motor it will have 2 wires coming off it this can stop the drum turning
shaun
Feb 02, 2009 | Kenmore 98702 Stacked Washer/Dryer
Motor does not turn
if coils is heating are you sure motor isn't running or just the drum not turning ? if drum not turning suspect belt ..if motor not running but element still heating suspect element is contacting outer case ..with coil touching case 110 volts is present even without motor turning if timer is turned to heat position element will not heat to capacity but will get hot enough to eventually blow element fuse
Dec 19, 2008 | Dryers
GE DBSR453EBWW Electric Dryer Logo
71 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
