Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner III
The normal cycle light keeps blinking and theres a line in the time remaining window but dishwasher will not work. Please help
  • 5 more comments
  • Anonymous Apr 23, 2009
    lights blink dishwasher stopped working need solution or help.
  • Anonymous Apr 28, 2009
    Light on 'normal' cycle flashing; machine won't start.
  • astrasale Apr 30, 2009
    I have a similar problem. The clean light continually blinks and all the lights on the console work but the dishwasher wont start (whirlpool gold)
    Help! Please!
  • Anonymous Mar 15, 2014
    qquiet partner iii blinks 7 times and right side buttons unresponsive
  • Anonymous Mar 20, 2014
    PWER TO IT NOT FROM IT
  • Anonymous Mar 23, 2014
    When I start it on normal cycle it takes alittle while for the time remaining to show up. It shows lines until time remaining shows up. Any advice
  • Anonymous Mar 30, 2014
    lock light is on and will not go off
  • 750 Answers
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
Posted on Oct 05, 2008
I have a Whirlpool gold Quiet partner III. The Normal button of the cycle is blinking and I can't start the dish washer. What is going on?
most likely the door switch is not making contact or is faulty. Shut the door tightly and see if it makes any difference.
Please provide the full model number of the dishwasher in case you need further help.
Aug 26, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher takes 3 hours to wash, even on the light cycle
whirlpool Quiet partner 3 the clean light is flashing 7 times what does this mean
Mar 12, 2010 | Whirlpool Dishwashers
The
usually means u need service if u got your manual see if it mentions it, try to flip the breaker or power to it maybe it willl resets..... if u can find the tech sheet or wiring diagram on the unit maybe below behind kick panels somwhwere it might mention it,,,,,, i beleive sometimes that means ur heating element as gone out on some models,,, also some had 5 year part warrranties on the heating element... do not remove once u do u must replace that element.....hope this helps
Jan 31, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Whirlpool quiet partner III clean light blinking green
you have to hit heated dry and normal and toggle these till all the lights light up. then hit cancel . you are going to have to turn the power of and slide the dishwasher out and look directly behind the dishwasher you will see that a wire off of the heater is more than likly burned of repair the wire you should be fine. replug dishwasher in after wire is repaired. if you do not have a burned wire you have a bad heating element replace the element.
Apr 14, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gold- quiet partner III
An angel of mercy on another blog posted this solution and it worked for me as well. My Whirlpool Quiet Partner Dishwasher would not work due to the CLEAN light flashing in 7 interval sequences. I followed these steps and my dishwasher is not working perfectly...hope it works for you:
"Well for mine which is a Whirlpool Gold Model # GU2400XTPS3, I found the seq of buttons that I had to push to reset the curcuit board. I think it may of been in this forum somewhere. But I had to push - Sani Rinse, Heated Dry, Sani Rinse, Heated Dry, and then the dishwasher went through it's diagnostic cycle and then after that the light stopped blinking and the dishwasher works great. Supposily, there is a Product Tech Sheet behide the kick panel of every dishwasher, but mine was gone so I had to find the information on the internet. You might want to do a serach for the correct seq of buttons you have to push to reset the curcuit board. If you know for sure that the heating element is bad, you will have to order one. "
Mar 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,360 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
