Question about Epson Perfection 3170 Flatbed Scanner
Soft ware problems
I've tried uninstalling and reinstalling the software that came with my scanner ( Windows XP) and I still get this error
EPSON Scan cannot be started . Please use the trouble shooting Assistant to solve the problem. I have checked all the connections and made sure the scanner is turned on , but keep on getting the same massage.Ya got any ideas?
Try this from "Tom's Hardware" worked for me!
1) RIGHT-CLICK on the MY COMPUTER icon and click on PROPERTIES.
2) Select the HARDWARE tab, then the DEVICE MANAGER button.
3) Remove the Epson Scanner from under IMAGING DEVICE and/or UNKNOWN and/or
OTHER DEVICES by RIGHT-CLICKING on it and clicking UNINSTALL.
4) Disconnect the USB cable and close all open windows.
5) Click on START, and CONTROL PANELS.
6) Double-click on ADD/REMOVE PROGRAMS. Highlight EPSON SCAN and click on
CHANGE/REMOVE.
7) Go to START, SEARCH, and ALL FILES AND FOLDERS. Select Advanced option
and ensure there is a checkmark next to SEARCH HIDDEN FILES and FOLDERS.
8)Search for files where all or part of the file named is OEM*.* and a word
or phrase in the file contains EPSON. Search location should be set to
C:\WINDOWS\INF or C:\WINNT\INF.
9) Delete all files that are found if this is your only Epson product. If
you have another Epson product, you will want to open each individual file
and determine which files pertain to your scanner, and then delete only
those.
10)Go to START, SEARCH, and ALL FILES AND FOLDERS. Search for files where
all or part of the file named twain.log . Search location should be set to
C:\. Please delete the twain.log file and repeat the process for
twain001.mtx, twunk001.mtx and twunk002.mtx. and epfb5 and escndv
Now we need to remove specific references to the product in the registry:
1. Click on START and then RUN.
2. In the Run window type in REGEDIT.
3. In the upper menu bar click on FILE, then EXPORT.
4. In the window that comes up, SAVE IN should be set to DESKTOP.
5. In the FILE NAME section at the bottom of the window type in REGBACKUP.
6. EXPORT RANGE should have a dot next to ALL.
7. Click on SAVE.
8. Look in the column on the left and Click on the "+" sign next to
HKEY_CURRENT_USER
9. Click on the "+" sign next to SOFTWARE
10. Click on the "+" sign next to Epson
11. Look for a folder name EPSON SCAN or epson twain . Right click on it
and Delete it (if you don't see it, then don't worry about it).
12. If you see a reference to your Epson product model, right click and
delete it.
13. Click on the "-" signs next to EPSON, SOFTWARE, HKEY_CURRENT_USER to
close up this branch.
14. Click on the "+" sign next to HKEY_LOCAL_MACHINE
15. Click on the "+" sign next to SOFTWARE
16. Click on the "+" sign next to Epson
17. Look for a folder name EPSON SCAN or epson twain , Right click on it
18. If you see a reference to your Epson product model, right click and
delete it.
19. Click on the "-" signs next to EPSON, SOFTWARE, HKEY_LOCAL_MACHINE to
DOWNLOAD
Please follow the steps below to download and install your scanner in XP:
1. Go to the website http://support.epson.com
2. Under the SCANNERS heading select PERFECTION SERIES and then your
scanner model.
3. Under the Drivers & Downloads section select Windows. Download the most
current version of the Scanner Driver for your Windows operating system to
your DESKTOP.
Reinstall
1) Double Click on the Epson1****.exe file that you downloaded to your
DESKTOP.
2) Click OK, Unzip, and then OK again.
3) The installer will copy the files to the system. Click on FINISH when
prompted.
4) Connect the USB cable to a different usb port on the computer. Windows
will tell you new hardware is found and complete the install.
5) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO
TESTING, click CONTINUE ANYWAY. Then click FINISH.
6) Your scanner is now ready to use
Posted on Apr 14, 2009
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
Will not scan. Error C:\ProgramFilesEPSON\escndv\es006c is displayed. Shows also ESCNDV.Exe
Do a complete reinstall.
1. Click Start, go to Control Panel, click System.
2. Click Hardware > Device Manager (XP). Click Device Manager (Vista and 7)
3. Look for Imaging Devices, right click on your Epson scanner and click uninstall.
4. Disconnect the usb cable from the printer.
5. Go to Control Panel > Add/Remove Programs (XP) Control Panel > Programs > Programs and Features (Vista and 7)
6. Look for Epson Scan and click Change/Remove/Uninstall.
7. Restart your computer.
8. Download the SCANNER software from the Epson website. If you have the disc, you can also run it.
9. Connect the usb cable back to the printer and computer.
10. Try scanning.
If that does not resolve your issue, you might need to remove Epson Scan from the Registry and reinstall the software again.
Nov 22, 2010 | Epson Stylus Multifunction Inkjet Printer/...
My Epson RX650 scan software will not start up. The printer works and the copy feature works. When I double click on the Epson Scan icon on my desktop it appears that it wants to start up but then...
Install another scanning software, if you have photoshop or any imaging software, you can use the scanner by going to the menu, then choose File, Import, TWAIN, Acquire and the scanner control will appear.
Or just go to My Computer and double click the scanner icon (in XP) to start the scanning assistant.
Nov 09, 2010 | Epson Stylus RX650 All-In-One Printer
Scanner will not scan an item into My Documents
try to uninstall then reinstall the driver. to do that go type device manager in run box in XP and start search in Vista/ Win 7, and look for the scanner. right click and uninstall. then load the driver from the website or from the cd that came with your device..
Mar 29, 2010 | Computers & Internet
File Names Limited To 7 Characters
Suggestion:
First update your PC to Windows XP service pack 3 and then update all patches after that. The problem will most likely still exist as this limit was an old MS DOS limitation so I'm leaning as the root cause of the problem lies with the Epson Software. After XP is fully updated and patched try the Scanner again. If still limited - uninstall and reinstall the scanner software.
Keep me posted.
Jan 31, 2010 | Epson Perfection 2400 Photo Flatbed...
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
Can't use the ''Film selection on epson V700
Make sure the transparency light cable that comes from the lid is plugged in to the back of the scanner. If the cable is unplugged for any reason, the transparency/film options will not be available.
Nov 18, 2008 | Epson Perfection V700 PHOTO Flatbed...
Epson RX425 multifunction
Just cracked it, had same prob...printer would print but wouldn't scan
lost original CD...tryed epson downloads but not the older versions...
i needed the 2.6 version
TRY THIS
http://driverscollection.com/?file_id=24466
Sep 13, 2007 | Epson Stylus RX425 Multifunction...
EPSON CX3810 "scan cannot be started" error I have this error when I try to use the scanner. I updated the Twain driver for Epson and it still happens. For some reason this Epson works for my brother's...
I suggest scan from MS Paint first - if this works proceed to step 1, if not, proceed to step2.
Step1, check device manager - update driver.
Step2, check if there are other scanner installed or software installed under C:Windows/twain_32 folder. Delete any files there except for wiatwain.ds and folders that has "e" at the beggining. Re launched Epson Scan. If it fails check step3.
Step3, trash and reinstall driver, you can download the driver for this on the epson site, www.epson.com, select your regio of course, go to drivers and support, select your product and select the appropriate system that your using.
Step4, Optional step, on the properties of Epson Scan (you'll see this if you right click Epson Scan icon), make sure that the compatibility corresponds to your system, you'll see a check box there that says "Run with..."
If this steps fails, perform registry adjustment by removing Epson Scan software under the HKEY_CURRENT USER and HKEY_LOCAL_MACHINE, reinstall software again.
Jul 16, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Epson Perfection 3170 Flatbed Scanner Logo
506 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
