Panasonic tv model# CT-27D20B
1/2" short and several horizantal line on top of the screen.
  • 124 Answers
SOURCE: sony kv-32xbr400
Hi The problem is dry joints on the vertical output ic for sure(commen fault with sony),ime in the uk and 99% of the time i get a call about sony tv its allways switches itself off, caused by dry joints.
Posted on Mar 27, 2006
  • 119 Answers
SOURCE: panasonic tv has white lines at top of screen
suspect it's 1 or a couple of bad capacitors in the vertical deflection circuit the caps are in the 400 series, c400,c401,c402, etc... check or replace c414,c418 & c417
Posted on Oct 31, 2006
SOURCE: Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Posted on Nov 09, 2008
  • 68 Answers
SOURCE: Black Screen with white line across the
the vertical IC most likely has failed
Posted on Aug 07, 2009
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Posted on May 23, 2010
My panasonic ct-32g6 has a horizontal line through the middle i can hear the sound but all that comes on the screen is the horizontal line.what is the problem?
The fact that there is a horizontal line on the screen tells you that all circuits are in operation except the vertical circuit , The virtical IC is probaly shorted or the reisitor that supplies voltage for the fly back is open in addition the negative feerback from the signal processor IC can be open also which can cause a horizantal line .You will have to check all dose circuits to seewhat is causing the line
Dec 29, 2010 | Panasonic CT-32G6 32" TV
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
10 fine white lines at top of tv screen
replace capacitor at vertical section
May 26, 2010 | Panasonic CT-27G14 27" TV
Panasonic CT-27SL15 has scan lines on top 4 inches of screen, what is problem and how to fix?
Nov 2011 - Comment
Have similar problem on a Panasonic Tau model CT-27SL15.
It's a 27" CRT TV manufactured around 2005.
Other posts / solutions on this problem say possibly a capacitor going bad in the vertical circuitry / near the vertical IC / vertical blanking circuitry. Telephone call to a TV repair person mentioned something similar - "possibly a bad capacitor in the vertical circuitry".
Found a service manual online w/schematics and board layouts.
Panasonic Service Manual
http://dl.dropbox.com/u/35219914/PANASONIC%20CT27SL15.pdf
See pg 25 (of 42) - Deflection Schematic Diagram (Main PCB)
Shows: V Output IC - IC401
Finding the actual bad component(s) may not be so easy.
Anyway ... just wanted to add this comment.
Feb 11, 2010 | Panasonic CT-27SL15 27" TV
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic CT-27SL14 27" TV
Picture on TV ''squeezed'' to center of screen horizontally
Check the horizontal trafo output voltage,the capacitors and the power supply voltage (135-155V dif.the tube diameter).
Aug 14, 2009 | Panasonic Televison & Video
Oct 07, 2008 | Televison & Video
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Panasonic tv has white lines at top of screen
Aug 30, 2006 | Panasonic CT2722H TV
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
Electro Med Services...
