My pc cdrom/dvd drive failed to read my recovery cd
My windows xp load abnormally. I've tried safemode , stil did'nt work, restart from last working configuration, still didn't work. so i wanna run my master recovery disc(packard bell) but my cd couldn't be found from both drives(cdrom and dvd drive). I've ordered another master recovery cd, coz i thought that was a cd problem but it still the same result..drives failed toread my master cd..
I've tried removing battery from my CMOS but still no effect..
what's the best thing to do?
I bought a new cdrom drive (set as slave). still did'nt work.
Re: my pc cdrom/dvd drive failed to read my recovery cd
Are you attempting to boot from a bootable disc? A failed drive can cause the other on the bus not to work. Try each one separate set as master or cs (cable select).
It could be the drive failed, can you boot to BIOS at all? I'd recommend a USB Drive adapter, then pull the drive from the laptop, connect to the adapter and then plug into a working PC USB port (Be sure that PC has good/current antivirus and firewall software and it has been backed up itself). The disk should then come up and look like a regular flash drive. Recover the critical files, then back up onto something like a CD or DVD that is set aside for safe keeping. Now you can be a bit more adventurous - potentially the BIOS settings changed, or the on board battery is dead and needs changing (can be complicated). There are also bootable drive recovery utilities that you can spin onto a CD. But data recovery is always first.
Hi
First you need to make the USB CD-rom Drive as the first boot device by going to BIOS setup by tapping F2 when the system turns ON , after changing the boot order insert the first disc and restart the computer it should run from the disc.
Also, it could be "bad" RAM in the computer that is creating "random" problems, which could be reported by the B.S.O.D.
If the computer has multiple sticks of RAM, remove one, and try again.
Your optical drive is not reading the disk properly - a common issue as time goes by. Replace drive with a good known working unit and your recovery operation will take place.
ok you wouldn't have been supplied a recovery cd, you have to create it, to create one have 2 blank dvd discs ready and go to start menu and select help type in a search for recovery cd, this will explain how to create one....if your computer won't load into windows you will have to re-install windows again, cheers, any other probs please get back to me.
If you are getting a Blue screen repeatedly and you can't start up to
windows in any custom setting ( from f8 start up menu ) one way to
solve the problem is to Use the restore disc or windows installation cd
or dvd to install
windows into the computer or perform a repair installation if a windows
already exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.When
the Press any key to boot from CD message is displayed on your screen,
press a key to start your computer from the Windows XP CD.
if
not then the computer is not set to start up from a cd, you can either
enter the setup / bios to change that setting OR right when you power
up the computer look at the screen it will say what button to press in
order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones
windows is working you will need the drivers for your computer, they
are at the makers website, for hp and compaq. www.hp.com for acer
http://support.acer-euro.com/drivers/downloads.html for all other
brands go to google and write Brand drivers. Should get you to the
right place. Dell is most likely www.dell.com and so on.
it is probably the hard drive failing as all of the items you have tried are on the hard drive
take it to a computer repair shop for a proper diagnosis
my dvd drive cannot read any thing and it is not visible, what do i do?
i have the same problem
