Question about Brother HL 1240 Printer
Printer Problem My printer no longer picks up papers when I try to print
  • 286 Answers
Try cleaning the large roller at the front. Use a q-tip and alcohol.
What exactly happens when you "hit print"
Posted on Nov 04, 2008
I have hp 1280 A3 Inkjet printer . When I give print it pick up paper and out the blank paper without printing . a4 printing is ok. But A3 Is majour problem
May 20, 2010 | HP DeskJet 1280 InkJet Printer
Tip
Dell 1700 1710 series printer. Paper not picking up trick....
Here's a quick tip. If your Dell 17XX series (not confirmed for newer than 1710dn printers) is no longer picking up paper from the tray, it MAY be from worn out rollers. Try this tip to get it going while you wait for a replacement roller to get to you:
1 - remove the paper tray
2 - remove toner
3 - flip printer upside down (exposing the rollers)
4 - remove the rubber on the roller
5 - invert it. (turn it inside out)
6 - replace rubber back onto roller (still inverted)
7 - test print.
If this doesn't work then the problem is likely a paper setting (set to legal or something) Good luck.
on Aug 27, 2010 | Office Equipment & Supplies
How to cancel a print order
use the control panel on your computer, pick the printers, double click on your printer and it should list documents currently in Q. Highlight the print jub and pick the documnent ta b at the top left of the window and pick cancel.
Nov 03, 2009 | HP DeskJet 3650 InkJet Printer
Printer won't pick up the paper in the tray to print. Keep getting out of paper message
First check if the feed rollers are 'Slick" with paper dust, if they are ,clean then with 409 on a cloth rag, and scrub till u dont see the white paper dust on the rollers, let the rollers dry, then reset the printer, by turning it off. then turn it back on ,reinstall the paper and begin printing again.
Jul 15, 2009 | Office Equipment & Supplies
Load paper
To resolve this issue pick one blank sheet and insert it in the tray and try to print self test page. If the printer prints self test page then load the paper properly and try to print. If self test page won't print then check the paper settings.
May 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
My printer stopped picking up/feeding paper. If I
try cleaning the pick up rollers , they must be a little sticky
Apr 03, 2009 | HP DeskJet 5550 InkJet Printer
Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
Jan 29, 2009 | Epson Stylus CX3800 Printer
I have an Easy Share printer dock series 3 that has paper loaded
Dirty rollers? I had the same problem and think the rollers are no longer sticky enough to pick up the paper due to a coating of dust... maybe cleaning the rollers would work?
Jan 28, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
My printer no longer feeds in Epson Premium Glossy paper S041624
Try to clean the paper pick rollers with a cloth, dam it with little water and try to hange the paper settings by going into printer preferances.
Regards,  raj_p5983
Jan 20, 2009 | Epson Stylus Color 1160 InkJet Printer
Paper jam light is on with no sign of a jam printer wont print.
1-paper is most likely stuck in the fuser, (where it exits and gets hot) you will have to remove it
2-it would be better to clean the rollers w/ alcohol then inside out.
Oct 09, 2008 | Dell 1700n Laser Printer
Brother HL 1240 Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
