Question about Frigidaire FGR341AC Electric Dryer
Frigidaire Electric Dryer
Will not start tumbling without manually turning.
The belt is fine. The dryer has been cleaned. Turns easily when apart. All of the felt is in good shape. Will work once you manually start it. Can only dry very small loads.
  • phstrombone3 Oct 22, 2008
    I have a Frigidaire Gallery electric dryer model # FDE437GHS0. The start button won't turn the drum unless cool or if you manually help turn the drum from the top under the hood. Also it was getting hot and kicking the dryer off but does not seem to have the problem since we started lifting the hood. Any help would be very help full.
  • 943 Answers
HI. THANKS FOR THE QUESTION . I WOULD REPLACE THE BELT .ITS STRETCHED A BIT. AND CLEAN THE DIRT OUT. AND THE VENTING THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
How do you open the Frigidaire affinity dryer bc i think the belt is broken
If the belt is broken dryer will not tumble, you can turn drum and should be resistance to turn, if turns easy then belt is broken. This is a difficult repair. If you can't see how to open dryer you won't be able to replace belt.
Aug 30, 2014 | Frigidaire AEQ6000ES Affinity 5.8 Cu. Ft....
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
The dryer drum will not turn, even manually with the belt removed
Sounds like something became wedged against the drum. Maybe a bearing?
Feb 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer turns on but won't heat up or tumble
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Nov 03, 2009 | Bosch Axxis WTA 3510 Electric Dryer
I have a Frigidaire Dryer Model GLER331AS2 it gets hot but want tumble. What's wrong?
okay, my name is Marc, whites appliance repair, manually turn the drum, if it turns easily, your belt has slipped or is broken.
Aug 18, 2009 | Frigidaire Dryers
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer hums when turned on but won't tumble
SOUNDS TO ME AS IF THE MOTOR IS FRYED IT WILL START RUN FOR A WHILE THEN STOP ? I WOULD CHECK INTO CHANGING IT OUT OR A NEW MACHINE WHAT EVER IS EASIEST ON YOUR WALLET DURING THESE TIGHT TIMES GOOD LUCK
Nov 04, 2008 | Frigidaire FEQ332E Electric Dryer
Frigidaire Dryer
If Dryer does not tumble , check the following:
" It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it."Source Repaiclinic
Sep 08, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire dryer makes noise when it tumbles
"spindle" would seem to refer to the rear drum bearing but teflon would describe the front. Have they both been done? Usually when one is worn out the other isn't far behind. Check the idler arm/wheel for wear. Also motors make a sound when the bearings are bad
Jan 03, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire FGR341AC Electric Dryer Logo
77 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
