Question about Cameras
Low battery signal
I have tried changing the batteries, but my camera is still telling me that I have low battery as soon as I turn it on. I don't know if the batteries were old, but any help would be appreciated!?!
I have the same problem with my SAMSUNG S830. The solution for this is to set the cameras battery to exact settings. With S830, there are two types of batt settings you can choose. First is the Li-Ion and Second is the Ni-Mh. You should choose what type of battery you are using.. =)
Posted on May 18, 2009
  • 928 Answers
If you camera still tells you that you have low battery. It is possible that the battery that you put it was not desinged for digital cameras. Please try batteries that are specifically designed for digicams. You can ask store personnel this when you buy batteries.
Posted on Oct 04, 2008
Green light goes on when I turn camera on, but 3 red lights flash when I shoot & nothing happens. I tried changing multiple batteries, all alkaline. No luck yet. Any ideas?
The 3 flashing red lights indicate low battery power! This could be because of low battery power (all 4 batteries must be good), the battery contacts in the camera are poor, the make of battery being used (try different make of battery)
Aug 05, 2015 | Fujifilm Instax MINI 7s Instant Film...
Tip
Fuji a350. When I got the camera, it took many many photos(50-100) with alkaline...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Feb 04, 2009 | Samsung Digimax D53 Digital Camera
Hello . i bought a used 2001 saturn s series. everything was fine , the car doesnt nstart.the battery light is on the dash board p[lus "service engine soon and oil pressure light.i already changed...
First thing you need to inspect the battery.The battery warning light is coming,due to battery is low on charge or battery got weak.If the battery is low on charge then get it recharged.But if battery is very old,then get it replaced.The battery and turn signal problem are two different problems.
Turn signals not working are due to faulty hazard switch/Turn signal switch,or faulty flasher unit.But in some cases its due to faulty turn signal fuse located in the interior fuse panel.This possibilities needs to be checked.Keep updated for further help.Thanks.Helpmech.
Jan 05, 2012 | 2002 Saturn L-Series
Low battery all the time
this is not a good signal. you can make this prove. clean the internal camera contact with a specific contact spray and one cotton fioc
ore you can use normal denaturated alcohol. this is one possibilty. if you dont have any betterment. its probably that the camera have a eletronic defekt. this is not so uncommon with old camera. the camera have internal fuse the works not good and gives this problem. motherboard defekt. good luck i hope for you that is only a dirty contact faulty.
paolo
Jun 01, 2010 | Canon PowerShot A550 Digital Camera
Camera turns off as soon as it turns on...why?
The battery is either very low (or can no longer hold a charge after being recharged) or there is some sort of electro-mechanical error happening during the power-up-self-test of the camera. One such error could be caused by not having a memory card (or one capable of holding any more images) in the camera. Double check your memory card.
You'll need to either try a new battery, memory card, or contact the manufacturer of the camera (or tell us the specific name & model of yours) for more detailed help.
Mar 12, 2010 | Kodak Cameras
When i start my camera it turns the light green to red and shuts off immeditaly
Green light indicates good battery strength. Red light indicates that your camera has an insufficient or low battery power level and will be automatically powered off. . To continue using the camera, please change your batteries to new ones.
Please note that:
  1. If you don’t intend to use your camera for an extended period of time, please remove the batteries to avoid battery leakage and corrosion.
  2. Do not mix old and new batteries.
  3. Alkaline batteries are generally recommended.
Feb 13, 2010 | Vivitar ViviCam 5355 Digital Camera
CAnon indicates low batery even it is full
Clean the battery holder with a pencil eraser, otherwise go for good brand rechargeable battery AA 2700 mAh try it.
Aug 25, 2009 | Canon PowerShot A590 IS Digital Camera
Camera will not turn on
the auto turn off settings in your camera must have got reset to some other low value. check it and change it. i will pray that ur problem may solve soon.
Dec 03, 2007 | Canon PowerShot A75 Digital Camera
Vivitar ViviCam 3615 Digital Camera
i have a vivitar vivicam 3720 digital camera need sofewear
Nov 13, 2007 | Vivitar ViviCam 3615 Digital Camera
Low Battery when using screen
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Oct 21, 2006 | Canon PowerShot G2 Digital Camera
Cameras Logo
185 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
